Audio Builds Audio projects and builds from my350z members
Pics from my stereo install
Old Jul 28, 2003 | 01:09 PM
350Z-RED's Avatar
350Z-RED
Talking Pics from my stereo install
Installed 2 Fosgate 10" HE2, Punch700s, Punch200XI, (2) 6.5 Punch HPC for behind the head, here are some pics of during and the finished product, i hope you like:[IMG]c:\audio\Audio_install-1.jpg[/IMG]
THE CUSTOM MADE BOX
[IMG]c:\audio\Audio_install-2.jpg[/IMG]
THE AMP RACK W/ THE "Z" EMBLEM ENGRAVED
[IMG]c:\audio\Audio_install-3.jpg[/IMG]
MY WHOLE CAR TORN APART, I WAS SAD TO SEE IT IN PIECES
[IMG]c:\audio\Audio_install-4.jpg[/IMG]
THE BOXES ARE IN
[IMG]c:\audio\Audio_install-6.jpg[/IMG]
FINSHED PRODUCT
[IMG]c:\audio\Audio_install-9.jpg[/IMG]
IT SOUNDS SWEET W/ THE APEARENCE OF STOCK
[IMG]c:\audio\Audio_install-10.jpg[/IMG]
I HOPE YOU GUYS LIKE IT
NEXT ARE THE VOLK GT-7'S ON ORDER
SHOULD BE ON THE CAR BY THE END OF AUGUST, WILL POST PICS
Old Jul 28, 2003 | 01:23 PM
nrc motorsports's Avatar
nrc motorsports
can't see them
Old Jul 28, 2003 | 01:29 PM
350Z-RED's Avatar
350Z-RED
SRY FORGOT TO ATTACH PICS
Old Jul 28, 2003 | 01:30 PM
350Z-RED's Avatar
350Z-RED
Custom BOX made 2 of them 1 for each side
Old Jul 28, 2003 | 01:31 PM
350Z-RED's Avatar
350Z-RED
Here is the amp rack wit the Z embelem
Old Jul 28, 2003 | 01:34 PM
350Z-RED's Avatar
350Z-RED
MY car is in pieces
Old Jul 28, 2003 | 01:35 PM
350Z-RED's Avatar
350Z-RED
Here it is with the boxes in place ALMOST DONE GETTING EXCITED
Old Jul 28, 2003 | 01:37 PM
350Z-RED's Avatar
350Z-RED
Finally, AMP RACK
Old Jul 28, 2003 | 01:39 PM
350Z-RED's Avatar
350Z-RED
Made to look STOCK, Sounds incredible
after the first couple of days i had to turn it down while driving cause my ears were ringing so bad they were hurting me
Next Mod will be VOLK GT-7s which i had on order, should be installed by the end of august
Old Jul 28, 2003 | 02:17 PM
jbjam02's Avatar
jbjam02
Nice job, that’s what im debating to do at the moment…
You wouldn’t happen to mind telling me the dimensions on those boxes, or anyone know the size of the compartment?? I recently tore mine apart and built a box but used the bottom and top of pre-existing sub area w/ MDF around the sides and foam w/ silicone to seal it up... I cut a new metal face plate to bolt on top of the existing sub mount and sealed that also... But now I’m getting a vibration of some sort whenever the base gets really loud. Not sure what it is, I think it’s because I didn’t build a full box.. I don’t really want to tear out my sub etc until I have a new box to put in and being dumb I didn’t write down the measurements.
Old Jul 28, 2003 | 05:16 PM
sal1's Avatar
sal1
Default sub box
Great sub box. I would like to build one just like it. Do you have the measurements???
Thanks
Sal
Old Jul 28, 2003 | 05:51 PM
jak's Avatar
jak
Nice install!
What is the gross cubic footage you ended up with in each of your sub boxes?
Jeff
Old Jul 28, 2003 | 06:04 PM
350Z-BoomZin's Avatar
350Z-BoomZin
The guy who built the box for me used the measurements from the plastic insert from the (what i call glove box) behind the pasenger seat, he made it exactly that size so that it would fit like a glove, one thing with the install, there were some metal brackets on the top of the compartments that needed to be bent in order to fit the boxes. i used metal brackets to hold the box in place (i attached a pic)
there is less then 1/2 a cubic foot inside each box, Rockford suggests .375 as the mininum and maxim of 1.75 for a sealed box
Old Jul 28, 2003 | 06:06 PM
zand02max's Avatar
zand02max
Default RF Power 10 Question
Do you know if a Rockford Fosgate Power 10" will fit in the factory location. Here are the dimensions. Please advise
Depth Bottom mount - 6.6875 in.
Cutout - 9.1875 in.
Displacement - 207.36 cu in.
Enclosure Sealed box -
Recommended Volume (Cubic feet) - .625
Power handling(RMS) - 1000 Watts
Power handling(Peak) - 2000 Watts
Impedance - 2 Ohms
Sensitivity - 83 db
Vas - .6
Fs - 28
Qts - .313
Xmax - .74
Old Jul 28, 2003 | 06:18 PM
350Z-BoomZin
zand02max
are you planing to put 1 of those subs???
i have (2) HE2 400W RMS 800W max and it pounds, it pounds so hard that my lights dim and my ears hurt. I think with a little creativity you can fit that sub in the glovebox, my boxes were less then .5 of a cubic foot each all you need is another .13 to keep it into spec.
good luck, i hope you bought ear plugs
Old Jul 30, 2003 | 04:23 PM
nrc motorsports
I LIKE THAT
Old Jul 31, 2003 | 05:08 AM
jhagan's Avatar
jhagan
Nice box...but the measurments would be nice... There are probably over a 100 people on this forum who would love to have them....
Old Jul 31, 2003 | 05:27 PM
BFG10's Avatar
BFG10
350Z- RED...
Dude, you are one brave individual. You stripped the inside of thing and I'll bet you were hoping it would fit back together. Well I'm pretty amazed! Awesome job!!
Where are you getting your GT-7's from? I'd like a set but worried about the bucks.
Old Jul 31, 2003 | 05:39 PM
350Z-RED's Avatar
350Z-RED
i'm getting the GT-7's from Town Fair tire near my home for 2200
for the rims and center caps, tires where extra
Old Aug 1, 2003 | 06:46 PM
orhanz33's Avatar
orhanz33
did you have to remove the spare for the amps?
