oil pan (N/A) and track use
Old May 1, 2005 | 12:48 PM
350zippy's Avatar
350zippy
Default oil pan (N/A) and track use
Any opinions or experience with aftermarket (jwt,aps,arc) oil pans for track use?
If so, what is your recommended make?
TIA
regards
Old May 1, 2005 | 05:22 PM
GY-Z's Avatar
GY-Z
are you experincing oil level drop during your track sessions?
Old May 1, 2005 | 05:55 PM
350zippy's Avatar
350zippy
GY-Z
no problems with oil level.
my questions are: would a larger oil pan improve oil cooling (APS pan )and oil starvation(under lateral load)? Any experience with those pans?
regards
Old May 1, 2005 | 05:58 PM
John's Avatar
John
I don't of anybody having oil starvation issues with the VQ35DE. Only starvation issues I've ever had have been with the OEM fuel tank...
Old May 1, 2005 | 06:02 PM
350zippy's Avatar
350zippy
john
how about oil cooling?
sent a pm.
regards
Old May 1, 2005 | 08:50 PM
GY-Z's Avatar
GY-Z
there's Nissan Motorsports Engine Oil Cooler, if this is what your looking for.
Old May 1, 2005 | 10:46 PM
EnthuZ's Avatar
EnthuZ
I don't think that oil starvation is a problem with our Z's. A friend destroys Hoosiers at HPDE's, and he has never had an issue with his engine. I also don't think high oil temps are an issue if a quality oil is used. In fact, over cooling your oil would probably cause more damage! Now, FI engines would probably need a oil cooler.
Knowing the above, I am waiting for my JWT oil pan spacer to arrive, along with a Defi oil temp gauge. Better safe than sorry!
Old May 2, 2005 | 06:51 AM
350zippy's Avatar
350zippy
thanks GY-Z and EnthuZ
i think oil cooler may be unnecessary for N/A engine, but larger oil pan (like spacer or aps) may add a marging of safety. Anybody using it? (APS pan or jwt oil pan spacer)
regards
Old May 2, 2005 | 07:19 AM
Redfoot's Avatar
Redfoot
I have an APS oil pan waiting to be installed when I do my next oil change. I have no track days scheduled in May so it won't get done for about a month.
Old May 2, 2005 | 03:51 PM
zillinois's Avatar
zillinois
My engine blew at a recent track event. Dropped a rod.
The final conclusion as to why is not known. But I have
ordered rod bolts and an APS oil pan as just a little
security. The rod started knocking coming out of tight corner.
I don't know if I'll ever get the exact results, because
the dealer warrantied the motor. But better safe
then sorry.
Old May 4, 2005 | 09:53 AM
scubasteve's Avatar
scubasteve
zillinios,
I have began to hear this weird noise from the engine at the past 2 or 3 track events. Anything lead up to this? The reason I ask is my engine is consuming still about 2 quarts every 3500 miles with Mobil 1 5/30. I'm going to send for an analysis with Blackstone.
-Steve
Old May 4, 2005 | 08:17 PM
zillinois's Avatar
zillinois
Originally Posted by scubasteve
zillinios,
-Steve
I noticed two things. A droning on the highway which didn't put me to sleep. I know that sounds really vague, but its the best way to describe it. You know how when you drive at the same speed for a while the car drone can put you to sleep. Well I could have driven forever at 75 mph and the accompanying drone.
The other thing was a noticeable occasional loss of power.
I think the analysis sounds like a good idea.
