Power steering cooler and tracking the Z...
Old May 22, 2007 | 05:29 PM
thinking's Avatar
thinking
Originally Posted by tmak26b
How do you guys know you overheated the ps fluid?
Loss of power steering was my clue. It became significantly more difficult to steer the car. Stopped, opened the hood and saw the ps fluid was leaking out around the cap.
Old May 22, 2007 | 06:31 PM
PDX_Racer's Avatar
PDX_Racer
Originally Posted by merlot350Z
Autocross uses the steering significantly more than road racing????? Where did you get that idea. Try Lime Rock or Summit Point for 35 to 40 minutes with lap times in the 1:04 or 1:25 for 20 laps. And thats with significant heat in the engine compartment.
How many laps do you do in a row where you autocross in your area?
Just pulling your chain, but the statement seems pretty far out.
Over time, you generate more heat on a road course, but you have those looooong straightaways to cool everything down, check your gauges, cool down the tires, rest your hands, call your girlfriend...
Seriously though, in a sixty-second course, there are probably 30-60 turns, some of which are fairly low speed and require more PS boost, while running with very little airflow through the engine compartment. It's enough to get the fluid working. I've noticed several times during summer events, especially those that end in longer slaloms, that the fluid is "bubbling" in the reservoir. Removing the front plate (even on the same day) seems to help by uncovering the almost quarter of the grill that is covered by the front plate.
Old May 22, 2007 | 07:12 PM
tmak26b's Avatar
tmak26b
I never had a problem losing power steering. I just change the fluid every year and bleed the system each year. I drive hard usually too
Old May 27, 2007 | 10:24 PM
dmoffitt's Avatar
dmoffitt
nismo ps cooler helped a lot for me... "cheap insurance" at the worst, i used to cook the fluid at autox's without it...
Old Sep 29, 2007 | 11:26 AM
DMK's Avatar
DMK
Originally Posted by Axelerate
Yep, thats it.
Very easy to install, I just used the zip ties that came with it, and just bled it when you are done.
So that 11/32 barb fitting is the correct size for the stock lines?
Old Sep 29, 2007 | 04:40 PM
tmak26b's Avatar
tmak26b
I never had to use any, I just change my fluid with the stock stuff once a year.
Old Sep 29, 2007 | 10:24 PM
terrasmak's Avatar
I'm running a $30 one from Summit that's a little bigger than the Nismo. Havent had any problems since.
Works great , hooks up to the stock lines and i used the zip ties that come with it into the stock brackets. Well one day at the track and one autocross with and , and no burned fluid smell.
apex locator
Jul 23, 2021 02:27 AM
