So...I need a hitch and I own a NISMO 350Z
Old Sep 24, 2007 | 08:41 AM
  #41
coachk's Avatar
coachk
I know I was just messin around with you guys...
Old Sep 24, 2007 | 12:05 PM
  #42
first350's Avatar
first350
If you want to race your Z:
it's either buy a small tire trailer and build a htich
OR
buy a big truck/trailer and Tow your Z.
...most of us don't have the $$ to make the Z into a trailer queen.
Old Sep 24, 2007 | 12:30 PM
  #43
tomzz's Avatar
tomzz
I have had very good results with a disaapearing hitch I had installed on my 350Z to haul my track trailer. It is welded to the frame of the car, not the aluminum bumper for a much stronger attachment. It did require the use of an Injen type exhaust that took out the stock muffler element and left a lot more room to weld the hitch bracing onto the frame. This was a custom weld job with a 90 degree drop down (removable) hitch connection. It was not very expensive ($300) and nothing shows when the connector is off the car. I have had it for 3 years and have hauled the trailer behind my Z to many DE's as with regular 600- 1000 mile RT hauls. It has made tracks days so much easier and enjoyable.
Happy to send some trailer and hitch pics if you send me your e mail at tdchristensen@comcast.net
Tomzz
Old Sep 24, 2007 | 06:22 PM
  #44
I1DER's Avatar
I1DER
This is a good thread. You guys that already have trailers are the word. Thanks for breaking the ice.
Old Oct 1, 2007 | 04:52 AM
  #45
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Good picture I got under the rear of my Nismo for hitch owners. Looks like it will work. What do you guys think?
Old Oct 1, 2007 | 10:13 AM
  #46
gixracer's Avatar
gixracer
yep
the one from roark will do just fine
when you do the extenstion/ball just make sure its out another 3-4 inches to clear the diffuser.
also on roarks design i would put the bottom two bolts closer to the bumper reciever to help reduce any flex toward the front of the car from the bumper.
i have made one for my car but just of the lack of something better to do i will be making a second one on a new bumper with the different bolt placement. no nothing was wrong with the first one, i just have nothing better to do.
good luck and see if he is still making them
Old Oct 18, 2007 | 05:05 PM
  #47
laze1's Avatar
laze1
AND..if you have a 2006 or later Z with LED tail lights, you will need this type of wiring harness:
http://www.etrailer.com/pc-VWH~118176KIT.htm
Circuit Protected Modulite 4 Pole Harness with Hardwire Kit (Includes Testers)
Code: 118176KIT
Price: $64.95
Capacity: 8.4 amps. This kit uses the 118176 circuit protected Modulite powered converter and includes everything necessary for installation on your vehicle.
Circuit Protected Modulite Vehicle Wiring Harness
Features:
* Short circuit protection safeguards itself and the tow vehicle against harmful electrical shorts and mis-wire situations.
o Module automatically resets itself once tripped
* Virtually eliminates draw on the vehicle's taillight circuit
* Powers the trailer's stop, turn, tail and running lights directly from the tow vehicle's battery
o Maximizes trailer light brightness
* May be used on 2 and 3 wire systems
o When used on 2 wire systems, brake wire on harness must be grounded
o Adapts a 3 wire system on the towing vehicle to a 2 wire system on the trailer.
* Includes circuit tester and (5) scotch locks to aid in installation.
* Also includes 4-pole trailer connector cover with LED test lights.
Specs:
* 4-pole trailer connector is 60" long from converter box
* Pigtail leads measures 18" long - passenger wire (green) measures 72" long
* Will work on vehicles with LED taillights
* Capacities: 4.2 amps (tail); 2.1 amps (stop/turn)
Warning:
Overloading circuit can cause fires. Do not exceed lower of towing manufacturer rating or:
* Max. stop/turn light: 1 per side (2.1 amps)
* Max. tail lights: (4.2 amps)
Old Oct 18, 2007 | 06:20 PM
  #48
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Originally Posted by joeygill
Anyone know how similar the rear bumpers (or hitch mount points) are between the Z and G?
I have yet to see a G owner, install a hitch like you guys have on your Z, but I definitely am getting to a point where a small trailer would come in handy.
I've got a hitch on my 05 G35C. I use it to tow my race trailer with race wheels and tools to the track. However, I have been told the bumper supports are much stronger on the 2005+ G's compared to the 03-04. Not sure of the truth of this. I'll try and get some links to where I got the hitch from, i think it was the curtis one. Maybe some pics, as well.
As for you retards who keep saying "hitch FTL", well, I say people who don't undertsand racing their sports car FTL
Old Oct 18, 2007 | 09:04 PM
  #49
PDX_Racer's Avatar
PDX_Racer
Code: 118176KIT
Price: $64.95
I use that on my 2005 Z -- the only difficulty is running the 12V line from the battery to the tail. You will learn about how to take off (and put back) quite a bit of the right side inside plastic. I basically ran mine almost directly alongside the rear washer fluid line -- at least around the door area. Just make sure that you "wrap" the 12V line inside some of that plastic auto wiring conduit -- you don't need to have a short on a live 12V line!
JjL
East Canada
Jun 12, 2019 03:04 AM
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
hardkicks
Sep 20, 2015 12:28 PM
350zrn35
Photoshop
Sep 14, 2015 06:53 PM
