Current Stance Owner, Should I switch?
Old Apr 15, 2008 | 08:12 AM
  #61
n1cK!'s Avatar
n1cK!
Infiltrator!
Originally Posted by Grip_corners
It happens on mid, and corner exit. I only test at the track twice a year. So i dont want to change my allignment based on street cornering becouse its a diffrent animal. I find if i get on the gas as i enter the turn i can get the rear to stick better.
How would i check for shock bind, or bumpstop travel. the car is not super low...
Would a limited slip be something i would enjoy, I.E. help fix my problem?
Someone mentioned when you lift it should be "loose" and when you are on the gas your car should push. Thats what it did, But the RA-1's will change that. I think i will keep the stagger though. (If im wrong, I will need new fronts first anyway)
put a zip tie at the top of the shock body. twist and turn a little, and then check to see where the zip tie is. if it's all the way to the bumpstop, then you've got contact.
a clutch type LSD is something everyone would enjoy. it may MASK the problem that you are having, but it may not necessarily FIX it. you may think you are gripping better, then start pushing harder and find yourself in the same predicament.
why do you think the RA-1's will change the behavior?
Old Apr 15, 2008 | 11:56 AM
  #62
Grip_corners's Avatar
Grip_corners
so much more grip, and taller sidewalls will roll over more, using more camber??? thats what i thought, I figured that dispite the smaller width, they will grip much more.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Mattg350z
Oct 2, 2015 06:51 AM
