G35 roll cage build
Old Sep 14, 2008 | 04:23 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
Thumbs up G35 roll cage build
not to steal anyone's thunder...but i finally got my car back from the shop and snapped off some pics. i just installed the fire system and am putting in roll bar padding (just a couple of pieces left). i am planning on racing with the NASA Performance Touring group (PTC).
i am happy with the cage overall...i think the welds came out really well and the shop owner really took his time with it (3 months, but there were some major delays). the paint shop could've done a little better. there were parts that weren't prepped correctly, some rough spots (especially by the roof line), and some evidence of over spray in some areas.
for those with a fire suppression system, how did you guys route the lines and mount the nozzles? i'm using three in the cabin will use three in the engine bay. currently, my Dekabon lines are attached to the cage with zip ties, as are the nozzles.
also, i'm currently trying to decide where i should mount the master switch and the second fire suppression activation handle. my current ideas are to drill holes in the trunk and to mount them on the hood cowl (near the wipers).
anyway, enjoy the pics!
Old Sep 14, 2008 | 04:26 PM
D350Z10's Avatar
D350Z10
one of the cleanest cage setups on here, nice job
Old Sep 14, 2008 | 04:28 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
Thumbs up
thanks
Old Sep 14, 2008 | 05:38 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Whoa!
Damn good job Nick!
Old Sep 14, 2008 | 06:58 PM
FabZ's Avatar
FabZ
Wow, nice job, let's see some exterior pictures!
Old Sep 14, 2008 | 07:58 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
sure, why not
Old Sep 15, 2008 | 05:12 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
wow...sick setup man
Old Sep 15, 2008 | 05:51 AM
lgear080's Avatar
lgear080
Perfect... And spotlessly clean. Nice bead on the welds too!
Old Sep 15, 2008 | 10:15 AM
mojojojo's Avatar
mojojojo
Hi Nick,
You might want to mount your fire bottle on the floor (get the weight low) and do you really want that system going off in your face? On the race cars we generally put the nozzle on the lower dash cross bar facing your jewels and call it good. Nice looking cage!
Joe
Old Sep 15, 2008 | 11:20 AM
racerbob4's Avatar
racerbob4
Joe in Portland is right. We mounted our bottle in the trunk and its larger than yours. We have one outlet in the motor area and one near the drivers and very close to the shifter. When you actuate the system with all those nozzels your bottle will empty very quickly and possibly too fast to put the fire out. If you have a fire it will probably come from the engine bay due to broken fuel lines. We had a huge fire in our Camaro at VIR with a speed of about 135 mph and it melted all the plastic, rubber and came thru the firewall and scorched the drivers fire suit at the knee.
We run the lines from the trunk along the driveshaft tunnel into the cabin and then into the middle of the motor area. I would consider only 2 nozzels so you get a longer duration of extinguisher chemical.
Old Sep 15, 2008 | 11:40 AM
sfarrah's Avatar
sfarrah
Congrats. Cage looks great, very clean install. I'll have to get some pics of the nozzles in my car.
Old Sep 15, 2008 | 12:43 PM
mojojojo's Avatar
mojojojo
Bob you're everywhere! looming in the shadows. Thanks for the extra input on the placement. I shouldn't have given the impression that the driver nozzle is the only one we install. See you in Topeka next month. " We're going hunting wabbits" ( solstices)
Old Sep 15, 2008 | 05:15 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
Originally Posted by mojojojo
Hi Nick,
Joe
joe, the nozzles aren't pointing at my face they are pointed toward the dash, toward the opposite side of the vehicle (like a criss-cross). i've got another one pointed at my "jewels" and will install three more in the engine bay.
Old Sep 15, 2008 | 05:19 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
i didn't know that the more nozzles you had, the quicker it would discharge. i figured it would be slower since the pressure in the bottle will decrease slowly over a larger "area" (more nozzles) the system came with six so i figured you had to use all six to meet the intent of the specs of the bottle.
i appreciate your insight though and it is something i definitely have to look into. i may just end up using a smaller number of nozzles (two in cabin, one in engine bay). where would the most likely source of the fire be - the fuel lines or the oil pan?
Old Sep 15, 2008 | 05:22 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
thanks! and some pics of those nozzles would be great!
Old Sep 15, 2008 | 05:26 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
i was going to mount my bottle low on the floor, but after looking and looking on the best possible place to drill, there would either be something blocking, or there would be some cross member of some sort that would be getting in the way. the bottle itself is only 15-20lbs, so it's not that big of a weight hit (i hope).
i was more concerned with it ripping off whatever it's mounted to in the event of a crash (knock on wood), but it's pretty secure with four bolts (two of which use the stock welded in tabs while the other two are secured with bolts on the other side).
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
