First HPDE event!
Old Mar 28, 2009 | 09:04 AM
sektor 11's Avatar
sektor 11
Default First HPDE event!
Just joined NASA in the Great Lakes region and signed up to volunteer at the Mid-Ohio event on April 11th.
I hope to do my first event June 6th at the new Bluegrass Course in Ky.
I hope to do at LEAST some new stainless brake lines and some super blue fluid. Any other recommendations?
Also, helmets....anyone know the regulations on those?
Old Mar 28, 2009 | 09:18 AM
Slow*Jim's Avatar
Slow*Jim
See you there! I'll likely be one of the only Z's there - Carbon Silver 04 in HPDE3. Feel free to ask if you have questions.
You'll need to upgrade your brake pads too - I hear Bluegrass has a really long straight.
Old Mar 28, 2009 | 10:13 AM
sektor 11's Avatar
sektor 11
I've already done a few laps on Bluegrass (not open to the public yet) and the front straight is very long! Should be fun!
I'll have to look for you up there at Mid Ohio! Do you know the regulations for the helmets?
Old Mar 28, 2009 | 01:38 PM
Slow*Jim's Avatar
Slow*Jim
Snell SA2000 or better
http://www.nasaproracing.com/rules/ccr.pdf
Old Mar 29, 2009 | 06:44 AM
sektor 11's Avatar
sektor 11
great! I'll look into one....thanks!
Old Mar 30, 2009 | 08:03 AM
reserved's Avatar
reserved
Watch out!!!!!!!!
This stuff is more addictive than crack!!!!!!!!!!!!!!!!
Old Apr 2, 2009 | 08:09 PM
zettahertz's Avatar
zettahertz
^+1 it's addicting, too bad it seems like not many Zs do this.
check your brake pads and make sure they're not almost gone. change engine oil and you're set besides the ATE super blue brake flush. And probably painters tape if you plan to tape up your headlights/front end or tape on your car #.
Old Apr 3, 2009 | 05:20 AM
sektor 11's Avatar
sektor 11
tomorrow (sat) I plan on changing the oil and checking the brakes and tires to make sure. can't wait.
Old Apr 3, 2009 | 10:00 AM
Z3305's Avatar
Z3305
Default Welcome To Track Addiction
Hey Sektor- hope you enjoy NASA. I go to track days at Putnam Park in Indiana (2+ hours from me in Louisville) and I'm real eager to get to Bluegrass as close as it is. They've had to cancel some April events but hopefully they'll be ready to go for their May dates. If you're not too busy with NASA check out the schedule through the summer for Bluegrass. A Cincy group called 1010thsmotorsports.com has a bunch of dates scheduled (I'm up there May 11th with them). You'll have about 5+ hours of possible track time during the day. Also, be sure to follow Slow Jim's advice and get track pads. I use Hawk HPPlus from Tire Rack and some of my friends really like Porterfield R4 pads. Both pads work well with stock rotors. Put on stainless lines if you already have them, but I've used the stock lines going into my 4th year now with no issues. You'll definitely want to upgrade your brake fluid to ATE or Motul as mentioned.
Old Apr 3, 2009 | 10:21 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
hey man i have a hpde event tomorrow at limerock...prepared my car last night, hopefully the weather gets better here for the event. Anyways good luck and im sure you'll enjoy it and like the post before me said it is truely addictive after you do your first one.
Old Apr 6, 2009 | 10:37 PM
garage-c's Avatar
garage-c
I reccommend Carbotech XP-10 pads, Goodridge SS lines, and ATE fluid. I use this combo on my '03 track model and have yet to get the brakes to fade. This is with a stock suspension on 19x9 255/35f and 19x10.5 285/35 SSR SP1's & Pilot Sport PS2's.
Old Apr 7, 2009 | 07:11 AM
sektor 11's Avatar
sektor 11
I ended up going w/ some AXXIS Ultimates (a noobie pad), stoptech lines, and motul 600 brake fluid.
Next purchase is a helmet.
Old Apr 7, 2009 | 08:04 AM
mw9's Avatar
mw9
So what is involved in joining NASA and how much is track time?
Old Apr 7, 2009 | 11:04 AM
Stack's Avatar
Stack
I'll have a novice group at the event I'm doing at Bluegrass in late July (hopefully by that time they'll have all the kinks worked out)
https://www.asphaltventures.com/2009...ass_Event.html
FYI
Old Apr 7, 2009 | 11:20 AM
laze1's Avatar
laze1
I highly recommend the Carbotech pads.
Old Apr 7, 2009 | 05:31 PM
sektor 11's Avatar
sektor 11
I've heard nothing but good things aboutt he carbotechs. My only concern with those is the noise and brake dust as I will be driving the Z on the street on occasion. I'm sure eventually I'll end up with a set
Old Apr 13, 2009 | 05:33 AM
mhoward1's Avatar
mhoward1
Since it's pretty easy to change them out and after a few times you can do it in about 20 minutes it worth having two sets of pads, a street and a track set. If for nothing else at least to have something to drive home on if you burn through a set.
_bit
Oct 2, 2015 07:49 AM
