REAR Tow hook question
So i know we have the front tow hook that screws in, but some events require a rear tow hook as well, any recommendations on where and how to install it on the z? thanks
Last edited by JasonZ-YA; Aug 25, 2009 at 02:57 PM. Reason: title update for searching
I, too, was wondering what to do about a rear tow hook. Are you folks sure that's a tow hook down low on the driver's side rear?
It certainly looks like it could be, but it seems a little on the flimsy side. If the car is being pulled straight back, it looks like it would be fine. But, if any side load is put on it (as in getting you out of gravel trap when the tow vehicle cannot line up directly behind you), it looks like it will bend pretty easily.
And a second problem is that it looks like the hook is low enough and recessed far enough back that any tow chain or rope attached to it will rub pretty severely on the lower part of the bumper cap.
Anyone out there have any experience getting pulled out of trouble at an awkward angle...did the hook bend? Did the lower part of your bumper cap get get torn up?
NismoZ 840, I'd sure appreciate it if you'd post a picture or two.
I heard of one owner who cut a small access panel in the rear bumper cap directly behind the license plate, then welded a threaded receiver to the structure that is right behind the cap. When at the track, he'd remove the licence plate and screw a front tow hook into the receiver and, voila!, a rear tow hook. I didn't see this myself, but I heard about it from someone who supposedly saw it with their own eyes.
Any opinions on whether this is a viable solution? It seems like it would be if the structure immediately under the rear bumper cap is strong enough.
The rear tow hook works fine (I know) if you add something like this on your track days:
http://www.mcmaster.com/#3709t26/=2d08y6
How would adding a connector link do anything? The link would, in effect, just be the first link in the tow chain. If my concerns about the OE hook bending under side load and damage to the bumper cap are valid (I don't know if they are), how does a connector link change things?
No, rear tow hooks are purely functional units that tend to be big and beefy. Carbon fiber won't be the material of choice. I had a 3/8" aluminum tow hook fabricated for the rear of my Z. But it still snapped when being towed out of the gravel trap at last years' June Sprints at Road America. Then the front end loader had to use the OEM rear tow hook. With the tow strap hooked up, they had to lift the entire rear of the Z out of the gravel trap. Bent the rear bumper upwards and actually creased the LR fender as it put so much pressure on this area.
Now I have another large tow hook welded to the RR aluminum bumper brace. I hope to not use it this year...
That is slick. Where did you get it?
I take it, then, that in your experience side loads do not bend the OE hook? And what is your experience regarding the tow chain/rope damaging the bottom of the bumper cap? Thanks for any info.
Also, Has anyone fabricated a rear lift point? I use the drivers side oem tow hook to lift the rear of my Z at drift events where i want both rear tires off the ground at the same time.
I have been wanting to fab a piece that mounts in the center that i can use to lift the car evenly.
I have an aftermarket exhaust so i have room in the middle......I have been thinking of using some of the existing structure points back there to mount a block that protrudes down to serve as a lift point.
I cant get to the diff with my jack and now i have a nismo finned cover, so that wont work.
-J
-J
-J
-J
My car is pretty low on TC Kline DA Coilovers.
