help for suspension set up
Old Sep 18, 2009 | 06:54 AM
sasquatch308's Avatar
sasquatch308
Default help for suspension set up
I need to figure out my suspension finally on how I want it for track driving but also for street.
I came across Hotchkiss sways as they are fully adjustable.
then coilovers I've heard KW V.3 are too soft, but looking at clubsports but are a little pricey. as well as Tein, Cusco, HKS hypermax Sports, Stance...
any light you guys with experiance with these coilovers that can lend me some quick advice would greatly be appreciated.
Alex
Old Sep 18, 2009 | 08:11 AM
ldstang50's Avatar
ldstang50
search, there's TONS of information already on here
Old Sep 18, 2009 | 09:06 AM
sasquatch308
already looked through this thread for track, and the suspension area. got information, but not towards a comparison. as most of the coilovers seam for better feel for DD or what not or full out race prepped cars. I'm not naive enough to not search first. now I'm here asking for answers
Old Sep 18, 2009 | 10:29 AM
ldstang50's Avatar
ldstang50
here's what a search of kw coilovers brought up
https://my350z.com/forum/brakes-and-...d-reviews.html
https://my350z.com/forum/brakes-and-...coilovers.html
Wow that took 2min and 31 seconds, to search, click, copy then paste
You're right, that was so hard to find, I'm not sure how other people have done it.
Anything else we can do for you??? You need a search done for a local gas station, insurance agent, GPS so you can find your way back home?
Old Sep 18, 2009 | 11:59 AM
guitarist's Avatar
guitarist
Hello, welcome to OnStar. How may we help you today?
OnStar Forum Service: helping noobs since 1998.
Old Sep 18, 2009 | 02:10 PM
Gsedan35's Avatar
Gsedan35
Take it easy on the guy fellows, he was pointed to this section (not by me) because it was thought this was the section of the board with the most knowledge on the subject.
To me this section is just what it's titled, so he would have to take any advice gained here with a gain of salt when it comes to the "Street" part of what he wants. Lot's of setups being run here aren't going to be the greatest on the street. And that is not to say we'd want to send him out on cheap generic stuff.
For what he want's I would consider Kw Variant 2 or 3. And then if much tracking actually get's done, a consideration for deleting the progressive rear springs that come with the setup. Yes, trackside comments do exist about the Kw Variant 3 that's it's too soft. I see that as a plus for the street and in any event no matter what your doing you don't want things so stiff that it doesn't allow the suspenison to do it's job.
Concerning the other brands mentioned based on your needs.
Monoflex: Too much spring and too much damper
HKS sport: Too much rear spring and too much damper (would only consider if you've kicked the VLSD to the curb and installed something that actually limits slip and I still think its not going to be too friendly on less then smooth roads in the street).
Stance: show me a dyno and I might raise a eyebrow
Cusco: Liked by people I trust to know good and bad behavior, default to Kw however
Kw Clubsport:Overkill for your needs. Another problem, Ohlins DFV isn't that much more. Granted you trade up to pillowball upper mounts, your choice within a range of spring rates, and different valving along with fatter piston rods and pillowball upper mounts vs the variant 3. However, it's still a twin tube and I would not trust it with spring rates much higher then the V3. I'm not clear on what the bigger piston shaft means for total oil volume.
Old Sep 18, 2009 | 02:31 PM
betamotorsports's Avatar
betamotorsports
That's true but there is always a price to pay when on a quest for knowledge:
Old Sep 18, 2009 | 04:02 PM
sasquatch308
thanks for the help. Idstang I appreciate the concern and will let you be the first to know of I need anyother help . Come and collect your toll...
Thanks Gsedan35 that is What i was looking for.
Alex
Old Oct 14, 2009 | 07:47 PM
wulfgang's Avatar
wulfgang
Rather than starting a new thread, I'd like to also get suspension input for just a strut/spring combo (no coilovers) from track guys. For the occasional track day (4-7 per year), would you shell out $1.5k+ for coilovers, go with something like koni struts and/or Eibach springs, or just keep it stock?
Again, I have no interest in drop, just what you think might be nice for track days and a bit of fun on some mountain roads.
Old Oct 14, 2009 | 08:35 PM
guitarist's Avatar
guitarist
The answer will come down to what you want to get out of your track days, and/or how much compromise you can live with on the street.
Do you mind putting up with 358 days of too much noise/minor discomfort (good shocks will make even very stiff springs pretty OK to drive on) for 7 days of seriously improved performance? Are you competitive about your track days? Do you have aspirations toward time trials?
Would you rather have a comfortable but still fine-handling car for the street? Do you already have dedicated track wheels and tires (this is the single biggest improvement over stock, in terms of sheer performance and lap times)? Have you reached the limits of the stock suspension and actually need to upgrade in order to continue progressing?
If you answer these questions for yourself, you'll likely come to an answer. Higher performance springs and dampers will likely mean a bit more noise, depending on how they attach. Setups that don't create more noise and stiffer ride characteristics (even if well-damped) probably won't offer much in the way of a performance boost over stock either.
Old Oct 14, 2009 | 11:37 PM
ADMAN's Avatar
ADMAN
What he said.
Old Oct 15, 2009 | 07:16 AM
betamotorsports
Here's what's on my 2006 250Z and it was good enough for a pro driver in my car (not me) to match the NASA TTC lap record (1:56.xxx) on the Cal Speedway Roval course and run 150mph through turns 1 and 2:
1. Koni sport shocks.
2. Nissan Motorsports adjustable ARBs.
3. Custom machined Hydlar front UCA bushings.
4. 18 x 10 RPF1s with 285/30-18 BFG R1s.
5. Stock 2006 350Z spring package.
6. OS Giken LSD.
7. Stock engine, trans, rear gears.
8. Stock base mdoel brakes with Hawk DTC70 pads and air ducting.
9. Big, giant brass *****.
Old Oct 15, 2009 | 07:57 AM
mw9's Avatar
mw9
6. OS Giken LSD.
What is #2, ARB's. Thanks
Old Oct 15, 2009 | 12:03 PM
guitarist's Avatar
guitarist
Anti-roll bars.
But imo, #9 was the most important item on that list
Old Oct 15, 2009 | 01:12 PM
sektor 11's Avatar
sektor 11
+1 on #9. wow. 150mph?
Old Oct 15, 2009 | 04:07 PM
betamotorsports
Yup. The best I could manage was 135 even after riding with Erik in my car about 3 feet from the outside wall at 150.
My ***** are little marshmallow ones.
