disabling abs?
Old Feb 22, 2012 | 08:26 AM
  #61
christoc's Avatar
christoc
Originally Posted by EvilCrayon
Why would you care about your brake lights on the track anyway?
Oh boy this should be good
Old Feb 22, 2012 | 08:30 AM
  #62
sig11's Avatar
sig11
The only place where a driver can utilize the brakes sans ABS is on the track. Why would you care about your brake lights on the track anyway?
So the fella behind you doesn't plow into you?
edit: OOh. Beaten. :P
Old Feb 22, 2012 | 09:15 AM
  #63
mhoward1's Avatar
mhoward1
Not to mention almost all track safety inspections require the lights to be working. I know we will pull you from the track if your brake lights are not working.
Old Feb 22, 2012 | 09:47 AM
  #64
KingBaby's Avatar
KingBaby
Hardest Setting
you can kill the control box
Old Feb 22, 2012 | 11:00 AM
  #65
str8dum1's Avatar
str8dum1
No, you just unplug the abs motor under the hood next to the brake booster. Its the top grey connector.
Originally Posted by tougeracing
is disconnecting the brake fuse the only way to disable ABS? Kinda sucks to know the brake lights don't work if you disconnect the fuse.
Old Feb 23, 2012 | 08:28 AM
  #66
tougeracing's Avatar
tougeracing
The one from behind the steering column? or the g/yaw sensor box behind the ash tray? I might just go with the unplug at the engine bay. Before I had the Z I had a 240sx without a speedo, so I think I can get use to that.
I have a 04' Perfmance trim Z; I'm not sure if the plug is anywhere different than the other trim models. I should probably take a picture so you guys can see and for future reference for others.
Old Feb 23, 2012 | 10:44 AM
  #67
str8dum1's Avatar
str8dum1
yaw sensor has nothing to do with ABS.
he means the ABS controller behind the steering wheel. Much easier to just unplug the ABS motor under the hood.
Old Mar 7, 2012 | 09:07 AM
  #68
tougeracing
I attached a photo. Is this the grey plug I disconnect under the hood? Any special instructions like make sure the car is off first before I unplug?
Thanks for the helps everybody
Old Mar 7, 2012 | 01:58 PM
  #69
dnguyent's Avatar
dnguyent
That's not the one I unplug. The one that I unplug has a locking lever on it, and to see it, you need to take off the plastic shroud. Just remove a few more of those tabs, and lift up the shroud. You should see another plug that is elongated...it's located near the side wall. I've put a box in the area where you can find the plug. One caveat to my comments...your ABS unit looks different than mine. I have an '04 Enthusiast.
If you still have a hard time finding it, PM me your cell phone number, and I'll try sending you a photo of it via text messaging.
-Don
Old Mar 7, 2012 | 02:10 PM
  #70
tougeracing
-Don
Yeah I have 04' Performance trim. I'll take a look at it later and see if I can find it. Thanks for the help.
aarrgghh
May 1, 2022 11:04 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
Stone Z
Nov 30, 2002 04:13 PM
