Gutted doors - lexan alternative
Feeling kind of chuffed with myself.
My car is getting more and more track oriented so decided to shave a little weight and gut the doors. I've seen a few threads on using lexan in the doors to keep out the rain but I think this is a good alternative.
I took out the mig and welded a few tabs to the doors. Used the existing window bolts and hardware to secure the glass to the tabs. Job done. Cost - virtually nothing. Seals up almost like OEM (except that weird adjustment when you close the door). They can be removed in 2 minutes with a 10mm wrench.
Man, that is freakin' awesome!!!! My passenger window motor died last week and I want the exact setup you've got goin'. I'm having trouble removing the window, any tips on how to separate the window from the 2 metal attachments and motor?
+1 on how much weight you saved......
How does this compare to stock when you close the door do you hear more rattling and noise from inside and outside the cabin? Or would you say the noise has decreased?
Nice job man. I just gutted my doors over the winter and did the lexan window approach attaching in a somewhat similar way you did yours.
I know the window motor, the door trim and the window tracting saved a decent amount. When I removed mine I think the tracting weighed the most. Also, that black metal panel, window motor and trim add up to a decent amount. I don't have any exact numbers though.
Get a pdf of the factory manual on line (google should find you a source). With that you can see the drawings of the door mechanism.
I weighed the black panel and glass on a bathroom scale and it was about 20lbs for one side. Obviously not super accurate but I think for both doors, with trim, gaskets, wiring harness, black panel and glass you are looking at 40-50lbs.
The doors feel significantly lighter when you close them.
How is the interior door handle bolted/welded? I think the answer is obvious, but I want to be sure - you simply unbolt the window for events but it's otherwise always in the up position? Or does it just slide into those holders, allowing you to simply slide it in and out? Also, can you lock/unlock the doors only with the key fob now?
For others asking - the weight is significant after you include the interior portion of the door, all the bolts, the aluminum panel that holds it all together, the window motor, the window guide, and the window itself. Easily 25# per side.
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
NOLAGG
Misc.
Sep 28, 2015 04:14 PM
