New NASA Class for 2012: Spec Z
Old Mar 21, 2012 | 05:24 PM
  #441
laze1's Avatar
laze1
Alright Kids...Call Kelly Strandmark @ 478-781-8440 with Paul Walsh Nissan in Macon GA to get your Spec Z NISMO parts...and other OEM stuff. He will be giving discounts to racers...call kelly for a quote...AND buy a couple of cars when you are there...
BTW: The owner is a Racer, and a soon to be Spec Z racer in NASA-SE!!! He runs a SpecE30 now
I have ordered my suspension kit parts from Paul Walsh Nissan and they should be in this week
Old Mar 21, 2012 | 05:25 PM
  #442
laze1's Avatar
laze1
...and I am still working on a Enkei wheels deal...
RPF1 18x9 +35
RPF1 18x10 +38
Old Mar 21, 2012 | 05:36 PM
  #443
laze1's Avatar
laze1
Tires can be purchased from Jackson Motorsports...as well as some regular NASA tires suppliers...and others. But these guys can also provide your BFG stickers/patches/Blig
Jackson Motorsports Group in partnership with BFGoodrich has a racer program that allows us to offer these tires at a discount to racers. Our price for the tires you’ll be running (MSPN 74887 – 275/35-18 – BFG R1) is $285.00 each plus tax and our shipping cost is only $10 per tire. We also offer Michelin and BFGoodrich race and Ultra High Performance tires at discounts to our racers. If you have any additional questions about pricing or availability, you can call us at 800-RACE-BFG.
Paul Hanna (Paul.Hanna@JacksonMG.com) is the BFGoodrich Pavement Manager who works specifically with those running R1’s in series’ like NASA and SCCA. Should you have any questions about setup recommendations for the tires you can contact him via email.
Old Mar 21, 2012 | 06:03 PM
  #444
laze1's Avatar
laze1
RacerBob4 recommends 20mm front spacer and a 10mm rear with these wheels
RPF1 18x9 +35
RPF1 18x10 +38
Want a spacer, not need.
Old Mar 21, 2012 | 06:52 PM
  #445
AznSky's Avatar
AznSky
so the rules aren't changing for wheel sizes then?
Old Mar 21, 2012 | 07:10 PM
  #446
Neimad's Avatar
Neimad
What wheels were they using on the development car? Of all the parts they could have just spec'd or recommended they chose nuts over wheels.
Old Mar 21, 2012 | 08:27 PM
  #447
terrasmak's Avatar
RPF1 18x9 +35
RPF1 18x10 +38
Rules say 13 mm max , so pretty much 10's unless you have 13's made.
Old Mar 22, 2012 | 01:47 AM
  #448
laze1's Avatar
laze1
They haven't changed yet...I will make one more attempt to get a final answer before I purchase wheels...and spacers
Old Mar 22, 2012 | 02:31 AM
  #449
laze1's Avatar
laze1
yep...And 20MM in the front seems too big ...but I trust Racerbob4...
having said that, stock 18/19-inch Track and GT wheels V2 wheels are:
• Front
• Size: 18x9.0
• Offset: +30mm
• Weight: 21 lbs 4 oz
• Tire: Bridgestone RE050A 245/40/18
• Rear
• Size: 19x10.0
• Offset: +30mm
• Weight: 29 lbs 8 oz
• Tire: Bridgestone RE050A 265/35/19
Old Mar 22, 2012 | 08:17 AM
  #450
G-Nite's Avatar
G-Nite
Cool!! pics when they arrive!!
Old Mar 22, 2012 | 12:52 PM
  #451
scotts300's Avatar
scotts300
Originally Posted by mhoward1
Your Z can't be that fast...there are hardly any stickers on the hood.
Excellent observation!
AN 18x9 +35 RPF1 didn't come close to clearing my stoptechs....the brembos are roughly the same physical size.
I'll probably run a 10mm and a 3mm spacer, which I have on-hand, until I can get some 13s made.
Got my tires lickity-split from them. I also ordered the stickers and suit patches, which are shipping soon. If we get 3 Zs, JMG also handles the BFG contingency portion for us.
From words posted on the NASA forum, it sounds like they are only lowering the weights slightly, with no other changes. This is not official.
Right.
• Front
• Size: 18x9.0
• Offset: +30mm
• Rear
• Size: 19x10.0
• Offset: +30mm
20 would work on the 9 +35 for sure. Even a 25 would fit, but we're limited to 13mm anyway as others have said. I currently run 25mm spacers all-around on the 18x10 +38 set-up, and there's still room.
Old Mar 22, 2012 | 03:23 PM
  #452
laze1's Avatar
laze1
List of things I will not do unless forced:
1. Check Lug Nuts
2. Check Spacers
3. Check for heater core/blower fans
4. Check Wheel weights
5.
Old Mar 22, 2012 | 03:29 PM
  #453
laze1's Avatar
laze1
Anybody notice this in the Spec Z contingency document?
"Product awards are only available for the first points race of each regional racing weekend"
But I also notice the the HPD has the same language...
http://www.nasaproracing.com/conting...gency_Info.pdf
http://www.nasaproracing.com/conting...ency_Info1.pdf
Old Mar 24, 2012 | 03:31 PM
  #454
laze1's Avatar
laze1
Got my Spec Z Suspension today...looks like high quality stuff. But looks like setting this up will take some "test & tune" days...my other dampers where only single adjustable...
KW uses a two springs per damper both front and rear...that is the 1st time I have seen that setup...
photobucket-4315-1332631439952.jpg?t=1332631441
photobucket-4403-1332632114916.jpg?t=1332632116
Old Mar 25, 2012 | 04:56 AM
  #455
laze1's Avatar
laze1
Scott...will you share you base setup with us? With you starting F & R settings for the Sway bars and dampers
PLZ!
I know you said it was loose on the first time out...
Old Mar 25, 2012 | 07:08 AM
  #456
laze1's Avatar
laze1
Scott, what rear upper shock mount did you use?
Stock OEM Nissan mounts? Or Aftermarket?
Old Mar 26, 2012 | 04:33 PM
  #457
N80's Avatar
N80
It looks like the sways have three adjustment holes. Do both the front and rear have 3?
Old Mar 26, 2012 | 04:43 PM
  #458
laze1's Avatar
laze1
Yep, 3 hole F & R...
On a related subject...anybody want to purchase my Hotchkis swaybars??
Old Mar 26, 2012 | 08:31 PM
  #459
scotts300's Avatar
scotts300
PLZ!
I didn't have the sway bars yet when I was out last time, so I ran the NISMO sways that were on the T2 car already. The R/C were set at the middle setting; I'll be doing some toying around and adjusting Friday-after-next in prep for the first event. I have the wavetrac going in now, too.
Stock shock mounts. Let me know what you think about that silly helper spring. My box also only had one adjustment tool instead of the two. What are you doing about the wheels? Waiting for the "OK" on the 9" RPF1s?
Old Mar 27, 2012 | 02:58 AM
  #460
laze1's Avatar
laze1
My Tool kit had one spanner, one "***", and one 2MM tool...and a crappy instruction manual...with nothing better available on the KW web site.
For wheels, I purchased 4x RPF1 18x10 ET38...to run as a square setup until the rules are locked in, and if needed I will buy some 18x9 for the fronts...I will run spacers as needed.
Also ordered a set of BFG tires this week...
So I should be ready to run no later than the June NASA-SE event @ Road Atlanta
http://nasa-se.com/2012Jun15.php
