New NASA Class for 2012: Spec Z
It does, so you have a classification for regular 350Zs using NISMO provided parts (different than Spec Z) , and a classification for Spec Z...using the NASA Suspension package...these are basically diferent cars in ZSCCA eyes....
and a class for the 370Z...
Hey, it is all good!
Selling my sti to buy a Z and had a question about calipers. The rules state pads are open and rotors must be the same size and type. If I get a base model can I upgrade to any caliper as long as my rotors are with in spec?
Also - you'll need rotors specifically for the Brembo's. Much larger than your base model brakes.
DE: 258HP(mx) wt 3175#(min) wt/power = 12.3
DE rev-up: 265 wt 3250 wt/power = 12.26 (!)
HR: 275 wt 3400 wt/power = 12.36
Also remember, one can have more HP (at Nationals), but must offset each HP with a 15# weight, essentially making one's wt/power even worse, i.e.:
HR: 290HP requires 3625#, wt/power = 12.5. Now you're at 450# heavier than your 03 competitor, that's 450# more on your tires, brakes, etc.
Gents,
Some clarification requested on the following topics. From the NASA CCR:
15.16.1 Racing Seat
Some series require an approved racing seat. It is strongly recommend that a racing seat be installed in all vehicles....
So a race seat isn't required, but if we had a fixed-back seat, it doesn't have to be FIA...
15.6.21 Seat Back Support
A seatback support must be made to hold the seat from going back in the event of a crash. A plate should be used to distribute the load. No bolts, corners, or sharp objects should be placed in such a manner that could lead to a possible puncture of the driver in a high impact crash. Seat back support need not be attached to the seat itself. Proper design and installation is crucial to safety and it is recommended that the driver employ the services of a professional race car builder for this, as well as all other vehicle safety items. An exception may be made for those seats homologated to, and mounted in accordance with, FIA 8855-1999 or 8862-2009 standards. Those seats that qualify for the aforementioned exception must conform to the entire FIA 8855-1999 or 8862-2009 set of regulations, as applicable. This includes a mandatory seat replacement, or use of a seat back brace, for any seat more than five (5) years old (8855-1999) or more than ten (10) years old (8862-2009). Please reference the FIA regulations. http://www.fia.com/
Seat back brace required on non-current FIA seats or any non-FIA seat. .
15.8 Master Switch
An electrical master switch is recommended on all cars
15.10 Windows / Window Nets
Window nets should be used on the driver’s side window.
Recommended and SHOULD, not required. . . ? See language when required:
15.12 Tow Eyes
It is required that all race vehicles, except open-wheel (formula) cars, have at least two (2) ...
A kill switch is not required, nor is a left side net?... A center net is clearly required for seats that don't have tight halo bolsters.
I'm not saying I won't have these items, but if we are scrutinizing the rules, they aren't required. I started looking closer into this because I got some guff over my seat back brace during inspection, and my kill switch failed and gave me a huge headache with the alternator failing.
15.16.1 Racing Seat
15.8 Master Switch
15.12 Tow Eyes
My understanding is CCR phrases like "should" and "recommended" are to be read with the phrase "if you want to be allowed on track, not black flagged or DQ'd by some officials"
But they could certainly use tighter wording to make it black & white in many if those cases.
The window net one depends if you have a window (open wheel) but they could specify that as well.
Gents,
15.16.1 Racing Seat
15.8 Master Switch
15.12 Tow Eyes
15.16.1 Racing Seat
15.8 Master Switch
15.12 Tow Eyes
Be aware the 350z tends to put a lot of load on the front brakes (more than average it seems) to the point that heat management can be an issue. Brake ducts are allowed (see rules) and a good idea (on my to do list) but 2 ways to help this are:
1. Use a pad that is rated for higher heat (not all race pads are created equal). I had to experiment for a while to find pads that had the bite and durability I wanted (KNS was quite helpful). I started by going through front pads very quickly 1-2 track days) now getting much longer life (relatively speaking)
2. Learn to brake less
actually this one really helped me too, though I still have a lot of room to improve.
As for rotors, my experience has been (so far) that every rotor I have tried gets heat stress cracks from thermal fatigue requiring replacement long before any significant wear....
But perhaps you know all this already.
I would do the Z in a heartbeat - but so far the market is soft.
The car is not quite as hard on the rotors as the aforementioned cars so the advantage might be less obvious.
Damn! Now I need to track down some upper control arms. :P
http://www.nasaforums.com/viewtopic....5fbaed5#unread
Originally Posted by JeremyC@nasaforums
8/9/2013
Rule Addendum
Effectively Immediately
NOTE: Underline= Items Added / {Bracket= Deleted items}
14.1 Suspension
D) Front upper control arms (A-Arms) may be replaced with aftermarket components for the purpose of adjusting camber on the front wheels. Factory mounting positions must be retained.
19 NASA National Championship Event
b) NASA will impose a maximum horse power limit for each Spec-Z engine classification.
• Horsepower readings will be measured utilizing a Dynojet Dynometer with the SAE correction factor and smoothing factor of “5”.
• NASA may impound all competitors and require certain competitors to report to the dyno located trackside for dynojet dynometer testing immediately following any on track session.
• Any competitor found to be competing over the allowed maximum horse power limit for their particular engine classification will be disqualified from their previous session unless they are found to have an additional {15lbs} 20lbs for each horse power they are over the maximum limit for the duration of the event.
• NASA may also utilize data acquisition systems to measure real time acceleration rates during competition to supplement the trackside dynometer testing.
Rule Addendum
14.1 Suspension
8/9/2013
Rule Addendum
14.1 Suspension
8/9/2013
Rule Addendum
14.1 Suspension
I'm curious about this change....and I don't know anything about racing, but was it pressure from racers for better performance or was it a tire wear issue? Or both?
I'm just wondering because I assume the point of a spec class is to keep things competitive, but also to keep costs down. More performance parts cause costs to creep up. I guess if it improves performance and tire wear then it would help keep costs down. And I guess the A arms are pretty cheap anyway.
Sorry if this is a dumb question or has already been discussed.
Both!
A Spec Z setup car wants to understeer, and burn up front tires. So the adjustable A-Arms allow for more camber, better tire temps and wear, and happier drivers.
A Z-car is SO MUCH better to drive with more front camber...the rear is less impacted by increased camber.
Good A-Arms are <$800, tires are ~$350 each. I doesn't take long to recoop any mony spend on the A-Arms.
And every 350z on the street that is lowered has them...
