New NASA Class for 2012: Spec Z
Old May 30, 2012 | 04:30 PM
  #741
laze1's Avatar
laze1
I don't care what brand...and I am low HP and TQ...
This is what one of my local Shops/Sponsors offered me at basically wholesale costs. Anybody have experience with these?
Exedy Stage 1 Max Wheel Torqe 307 ft-lb.
Exedy Stage 2 Max Wheel Torqe 355 ft-lb.
ACT NZ1-HDSS full disc Max Wheel Torque 455 ft-lbs.
ACT NZ1-HDG6 6 pad spring centered disc Max Wheel Torque 580 ft-lbs.
ACT NZ1-HDR6 6 pad Solid hub Max wheel Torque 580 ft-lbs.
Old May 30, 2012 | 05:05 PM
  #742
laze1's Avatar
laze1
this kit?
http://www.jimwolftechnology.com/cus...asp?PartID=454
PART NUMBER: L3503-NC000
PART DESCRIPTION:
350Z / G35 HIGH CLAMPING FORCE CLUTCH SET. 1200KG clamping force and a smooth organic disc makes this the best choice for street / track 350Z-G35 including boosted cars! This clutch set also works on some other JWT specific flywheels.
PRICE: $485.00
I can get this for $399 locally, and a good price on the install...
Originally Posted by SE5spd
^ why not the JWT combo?
Old May 30, 2012 | 05:22 PM
  #743
SE5spd's Avatar
SE5spd
https://my350z.com/forum/drivetrain/...-shipping.html
Old May 30, 2012 | 05:38 PM
  #744
laze1's Avatar
laze1
Part of the issue is we must run a Nismo or OEM Flywheel...only the Clutch & PP are open...I have already ordered the Nismo Flywheel...
Old May 30, 2012 | 10:37 PM
  #745
scotts300's Avatar
scotts300
I have had good success with the JWT clutch you referred to. My NISMO FW is going in this week!
Old May 31, 2012 | 02:06 AM
  #746
laze1's Avatar
laze1
That is good news!
I think I will go that way then...JWT FTW
Old Jun 5, 2012 | 04:19 AM
  #747
paulwalshnissan's Avatar
paulwalshnissan
hey laze1 did you get that flywheel in yet!!!!
Old Jun 5, 2012 | 05:18 AM
  #748
laze1's Avatar
laze1
Not yet....taking the car to Jason Plante @ Balanced Performance today to install the new clutch/flywheel and new transmission. Jason will also perfom my NASA annual Tech Inspection and Dyno test. Then I should be good-to-go for the June Jam.
WOW...this has been a long and expensive year to get converted 100% to Spec Z configuration.
BIG THNX TO YOUR TEAMS HELP!!!!!!!!!!
Old Jun 5, 2012 | 05:21 AM
  #749
laze1's Avatar
laze1
BTW: I ended up going with a Stage 2 "Competion Clutch" based on Jason's recommendations. This is a full-faced clutch disc....looks like a stock unit.
Old Jun 5, 2012 | 08:04 AM
  #750
scotts300's Avatar
scotts300
Cost?
I just threw my used stock one back in to pinch the costs some. This was getting out of hand. NISMO FW ain't cheap!
Old Jun 5, 2012 | 08:23 AM
  #751
Waco Racer's Avatar
Waco Racer
FYI - A question was asked on the NASA forums about whether or not you can replace the exhaust manifolds with a header.
Factory exhaust manifolds are required. That will be corrected in the next rules revision. If there's not a revision out by Nationals then a Tech Bulletin will be issued.
Old Jun 6, 2012 | 11:40 AM
  #752
Fixxxercask's Avatar
Fixxxercask
7 Spec Z cars on the entry list for Nats
http://www.nasaproracing.com/nationa...ylist_2012.pdf
Old Jun 6, 2012 | 12:26 PM
  #753
mhoward1's Avatar
mhoward1
Sorry guys, but I think I am going to back out of my plans for Spec Z. But I am still going to watch it mature.
Old Jun 6, 2012 | 12:43 PM
  #754
laze1's Avatar
laze1
U just skared ain't ya????
Old Jun 6, 2012 | 12:45 PM
  #755
laze1's Avatar
laze1
I doubt that I can make it...done spent all my money and have not even made a Regional race yet....reality sux!!!!
Old Jun 6, 2012 | 12:48 PM
  #756
mhoward1's Avatar
mhoward1
terrified!!!
Actually a more "interesting' opportunity has come up.
Old Jun 6, 2012 | 01:40 PM
  #757
scotts300's Avatar
scotts300
SpecZ issue #2, page 56: http://www.snmagcurrent.com/publication/?i=114117
Old Jun 6, 2012 | 02:15 PM
  #758
scotts300's Avatar
scotts300
Just sent my request in for more BFG and NISSAN/NISMO banners for the #219 car.
Old Jun 6, 2012 | 04:22 PM
  #759
laze1's Avatar
laze1
Thunder Roadster?
terrified!!!
Old Jun 6, 2012 | 04:24 PM
  #760
mhoward1's Avatar
mhoward1
no,
something a little newer but still in STR-2
The 818-R. Talking to Jim S and David S about betting one of the first 818-R full spec cars to run.
