New NASA Class for 2012: Spec Z
Old Jul 2, 2012 | 01:44 AM
  #861
Fixxxercask's Avatar
Fixxxercask
The NASA Great Lakes/Midwest director asked me about possibly being the Spec Z director since we don't have one yet. There are hardly any Z's in my region, but the few that I've seen, I am at far more events than the others and I always podium (ran faster this past weekend at MO than I did at Nats and it was way hotter)
I am heavily considering it, but I do not know what all is involved and how much time I have to dedicate to it. I think it will be a great opportunity.
Old Jul 2, 2012 | 01:51 AM
  #862
reserved's Avatar
reserved
Do it!!!!!!!!!!!
Old Jul 2, 2012 | 02:04 AM
  #863
laze1's Avatar
laze1
Do it!
it doesn't require much extra time... now that Spec Z is off the ground this should be like be being a normal director.
and with the Nationals being in your Region...
Old Jul 2, 2012 | 01:00 PM
  #864
Fixxxercask
I am heavily considering...I will get back about it soon hopefully.
Old Jul 2, 2012 | 01:35 PM
  #865
scotts300's Avatar
scotts300
Non-NISMO, NISMO V2, or NISMO V3 front bumpers. ? . ? Discuss. . .
Old Jul 2, 2012 | 02:11 PM
  #866
Zazz93's Avatar
Zazz93
Do you think the V2 stuff would be worth arguing to include? I would assume the V3 stuff is a fair bit better.
Old Jul 2, 2012 | 03:21 PM
  #867
scotts300's Avatar
scotts300
I've been informed that any V2 stuff is NOT legal since it was never used in a production Z33. Aftermarket NISMO is not allowed, just OEM stuff produced as part of factory production. So V3 (front) or nada. I believe the V2 rear wing (dog ear), which was on the early NISMO, is allowed of course.
Old Jul 2, 2012 | 05:53 PM
  #868
dkmura's Avatar
dkmura
General & DIY Moderator
Sorry Scott- if you go by the intent of Spec Z rules, the V2 wing (and the entire V2 kit) was never sold as an actual USDM Z33 model. It was an aftermarket NISMO offering, and isn't allowed either.
That's not to say the rules couldn't be changed in the future. But for now, as you say, it's the V3 bodykit or nothing...
Old Jul 2, 2012 | 09:26 PM
  #869
scotts300's Avatar
scotts300
Thank you, David, for your comments and insight! V3, stock, or bust.
Old Jul 3, 2012 | 06:36 AM
  #870
laze1's Avatar
laze1
...ask about "FREE" track time...
Old Jul 3, 2012 | 07:10 AM
  #871
Fixxxercask
I definitely plan on it. That will help me out a lot.
Old Jul 4, 2012 | 05:01 PM
  #872
laze1's Avatar
laze1
Installing diff cooler to help the Wavetrac make it thru the season...a real PIA..but worth it I suppose...
Old Jul 4, 2012 | 05:39 PM
  #873
N80's Avatar
N80
Who makes it? Got pics?
Old Jul 5, 2012 | 02:05 AM
  #874
laze1's Avatar
laze1
Don't know...the stuff came on the car when I purchased it. But I removed it as it was leaking from the pump...that I rebuilt yesterday. Looks like it was missing a O-ring from the factory
I am not installing in the same configuration as it was...so it will take a little while...but pics to follow..I am moving the cooler and fan under the car...this should lower the heat level inside the car...the pump and maybe the filter will be the only thing inside the car.
this is what it looked like before:
Old Jul 6, 2012 | 06:10 AM
  #875
laze1's Avatar
laze1
So, I was thinking (warning warning warning ) if I can increase the amount of fluid that is circulating thru my diff via the pump/cooler, I should be better able to control (lower) the Diff temps...right????
So if this is true, I wonder if I should create a storage tank in my Diff cooler plumbing? This should not be hard to do since I am already re-installing my Pump/cooler and making up new hoses...and this already adds some-to-be-determied amount of fluid to the system...and more fluid appears to be better than less fluid. I am thinking of adding a small tank like a dry-sump engine might use...
Note: As you know, the Nissan Diff only hold 1.4 liters of fluid...that appears NOT be enough to provide any cooling affects.
Comments plz!!!
In this pic mentally replace the engine with a a Diff...and note that we are not presurizing the Diff with Oil like tha engine requires...
http://www.drysump.com/LS%20Plumbing%20Schematics.htm
Old Jul 6, 2012 | 06:25 AM
  #876
Pelle51's Avatar
Pelle51
Has anyone recorded any base line temps for the diff fluid without a cooler? I am wondering if a 30 minute session (NASA race time limit) will generate enough heat to even bother with a cooler. Warm thinner fluid uses less horsepower.
Old Jul 6, 2012 | 07:09 AM
  #877
terrasmak's Avatar
What size line is to the cooler , looks like -6 , and why didnt you keep the cooler under the car in the oil flow?
Old Jul 6, 2012 | 07:29 AM
  #878
laze1's Avatar
laze1
Let me assure you heat is an issue with the Wavetrac Diff.
Using an infared style thermometer, I was around 265 Degrees about 10 mins after a 20 minute qualifiing session. (~ 85 deg ambiant temps) My buddy Clark who has a Temp sensor in his diff was getting ~300 Degs...and 255 Deg external temp using the same infared style thermometer ( no idea if it is accurate) He had a Nismo diff cover but no Diff cooler. I had a stock cover and no Diff Cooler.
After a 30 minute race, I was puking large amounts of Motul 75-140 Comp Diff fluid out the breather. And OMG does the remaining Diff fluid stinkl (Burned Poo smell)
The WaveTracs are dying due to heat they generate...
Old Jul 6, 2012 | 07:32 AM
  #879
laze1's Avatar
laze1
I think they are -8.
And the pics you see are how the cooler was set up when I purchased it, but removed because it leaked from the pump so I never ran it that way.I plan to move as much hardware under the car to Diff level that I can.
Old Jul 6, 2012 | 07:33 AM
  #880
laze1's Avatar
laze1
Boiling Diff Oil does't do much for speed/friction/HP
