The 2TH PWR Track Car conversion
Old Apr 9, 2012 | 04:19 PM
  #101
GT-Rob's Avatar
GT-Rob
Yes R12 (freon) was the very harmful one, and has been banned since the 90s.
That compressor is heavy eh. Plus now you have free air flow into the rad
Old Apr 10, 2012 | 04:25 AM
  #102
kart14's Avatar
kart14
Guess my grade 12 science is out of date. But R134A has a green house effect and shouldn't be released. Glad 2th had it dealt with by a pro. I had mine purged at the garage but just cut it out once purged. Didn't have the patience to sort out the connections.
Old Apr 10, 2012 | 07:57 AM
  #103
GT-Rob's Avatar
GT-Rob
Oh I agree the new stuff still should be disposed of properly, I was just saying its not as bad as the old stuff used to be.
I also just cut mine near the MC. That line that went behind the engine towards the passenger side looked very painful to remove.
Old Apr 15, 2012 | 12:14 PM
  #104
2TH PWR's Avatar
2TH PWR
More weight loss today. A few hours with an angle grinder, 5 cutting discs, and a grinding disc and I took out most of the metal housing unit behind the seats.
Before... (damn I only took rear shots pre-op)
After.
You can see I chose to leave some metal around the seat belts.
The pile. Weighed it in a Blue Bin on a bath room scale using myself holding the bin as a tare weight just as I have for everything I've taken off. I was able to weigh 27.2 lbs of scrap. I'm not concerned about loss of strength. Those plates with the black metal with the gold coloured bolts seem to provide the bulk of the strengh and rigidity. That brings total weight of things taken off the car so far up to 324.2 lbs.
Old Apr 15, 2012 | 01:42 PM
  #105
Bloodtype:Z's Avatar
Bloodtype:Z
WOW lookin good man!! So clean in there now
Old Apr 15, 2012 | 03:54 PM
  #106
tioga's Avatar
tioga
Brazilian :P
Old Apr 15, 2012 | 04:40 PM
  #107
2TH PWR's Avatar
2TH PWR
Thanks bros
I found a better comparison shot. (someone elses car)
now
Old Apr 15, 2012 | 04:58 PM
  #108
axial_pro's Avatar
axial_pro
Damn! That's a pile of work you have put in this winter. Can't wait to see what times you set this season. The bar will certainly be raised!
Old Apr 15, 2012 | 05:14 PM
  #109
tioga's Avatar
tioga
You throwing in a rollcage? That would look sick not to mention really stiff up that body.
Old Apr 15, 2012 | 06:54 PM
  #110
GT-Rob's Avatar
GT-Rob
Damn you! Nice to know the weight though, I figured it was about 30lbs. Even if you put an alum bar across it would be 1/4 the weight with just as much or more strength.
Old Apr 16, 2012 | 12:08 PM
  #111
2TH PWR's Avatar
2TH PWR
Mini Update.
Safety First
Shipment just arrived at work. 1 more shipment to go.
Old Apr 16, 2012 | 02:33 PM
  #112
Smasher's Avatar
Smasher
Wow, that's a lot of extra space in there now. It looks like you could fit an extra set of wheels in there if you wanted to take them to the track.
I guess this now makes it the point on no return to a dedicated track car if you were not there already before.
Nice work there 2th.
Old Apr 16, 2012 | 02:49 PM
  #113
2TH PWR's Avatar
2TH PWR
Yeah, definitely not selling it. Been with me since 2004. Might as well get it the way I want it.
Now I need to fix this power problem I have lol. Let's swap motors!
JK
Old Apr 16, 2012 | 02:52 PM
  #114
SirSpeedyZ's Avatar
SirSpeedyZ
Staying NA or going FI?
Old Apr 16, 2012 | 02:54 PM
  #115
2TH PWR's Avatar
2TH PWR
Toying with the thought of swapping in an aluminum block LS. But on the fence. Going to go through at least this season without changing anything else.
Old Apr 17, 2012 | 09:52 AM
  #116
2TH PWR's Avatar
2TH PWR
Last thing I plan on getting for 2012 arrived today. Swift Spec R.
Now I will get to work installing
- Shocks
- Springs
- Sway Bars with endlinks.
- Brakes with new Wheel studs.
Old Apr 17, 2012 | 04:28 PM
  #117
tioga's Avatar
tioga
Did you get that from Adam? I noticed your name in this .... https://my350z.com/forum/my350z-com-...ml#post9701502
I stumbled onto it and read it and **** wish I did back in Oct=Nov. When did you put your order in for him?
Old Apr 17, 2012 | 05:04 PM
  #118
SE5spd's Avatar
SE5spd
correct me if im wrong but isnt the swift spec R blue and the normal swift black?
Old Apr 17, 2012 | 05:08 PM
  #119
mw9's Avatar
mw9
in for updates
Old Apr 17, 2012 | 06:29 PM
  #120
2TH PWR's Avatar
2TH PWR
I asked Adam the same question and he told me these were the right ones.
part # 4N014RS-R rear
4N014RS-F front.
If anyone could please confirm let me know.
As for when I placed my order... Jan 4th.
I originally ordered powergrid endlinks but when I couldn't get them I switched to swift spec R.
