question for those that have run on Big Willow
Old Mar 19, 2012 | 01:36 PM
WetDreamZZZ's Avatar
WetDreamZZZ
Default question for those that have run on Big Willow
So there is a track day event on Big Willow this weekend and I am debating going or not. I have only been on Streets of Willow which is a much slower track. My question to you guys that have been on both tracks is which track (big or streets) gives your brakes more of a work out? I'm asking this because my stock Brembos get pretty bad brake fade at Streets about 10-15 minutes of going around the track. If Big Willow isn't as hard on brakes as streets then i'm comfident I will have no trouble at all but I just wanted to make sure before I make the 3.5 hour drive up from San Diego.
Old Mar 19, 2012 | 03:10 PM
XSpeedAddictX's Avatar
XSpeedAddictX
Well, I have ran both of them and I would say I brake less on the Big track. However, you will be stopping from 120+ mph coming into the first turn out of the straight. If you are getting brake fade on streets, I would suggest getting some better pads for track only, like Carbontech. Anyways, hope that helps you a bit
Old Mar 19, 2012 | 03:11 PM
terrasmak's Avatar
Streets is a lot harder on brakes. There is only 1 heavy braking zone on Big Willow, that is the enterance of turn 3
130 mph on GPS into the breaking zone into 1, but its only a slight braking zone, enough to downshift from 5th to 4th. Turn 3 is the biggest braking zone, banging down from 5th to 3rd.
Old Mar 19, 2012 | 04:32 PM
WetDreamZZZ
cool thats what i thought. I figured since the track was a lot longer and faster there would be plenty of time to let the brakes cool down between braking zones. I have also upgraded from oem fluid to AP Racing super 600 brake fluid but I have not been to a track since then to actually see if it made a difference or not.
Old Mar 19, 2012 | 07:57 PM
jnathan68's Avatar
jnathan68
The fluid should help with the spongey pedal issue you get from fluid boiling but the issue of pads "over heating" is just your need to get a higher temp track pad as you know
Lots more brake cooling time on Big Willow so you should be fine. If you run into issues just cut your sessions short as you start to notice fade...still worth it to run the big track...so much fun.
Old Mar 19, 2012 | 09:41 PM
thespottedcow's Avatar
thespottedcow
agreed, streets is a lot harder on brakes, fluid and some pads you should be good to go
Old Mar 20, 2012 | 01:44 PM
WetDreamZZZ
Sweet! Any of you guys going to be at Willow this weekend?
Old Mar 20, 2012 | 02:16 PM
terrasmak's Avatar
Wife got knee surgery, I'm lucky to be able to hit spring mountain next weekend.
Old Mar 20, 2012 | 03:46 PM
jnathan68's Avatar
jnathan68
My dad is coming into town this weekend so I am doing the family thing...no track for me.
Old Mar 21, 2012 | 07:36 AM
betamotorsports's Avatar
betamotorsports
I'll be at Buttonwillow for the SCCA Double Regional.
Vigman
Nov 17, 2015 04:34 AM
sccarally
Meet-Ups / Events (Texas)
Sep 27, 2015 01:06 PM
_koubie_
Sep 20, 2015 06:34 PM
