And so it begins/full track car prep
Old Aug 30, 2012 | 08:35 PM
  #41
Voboy's Avatar
Voboy
When you pull stuff off the doors, do you mind weighing them? Im curious how much weigh each piece is. Like the metal skin, and glass. Any ideas on how to mount the door handle securely?
Old Aug 31, 2012 | 12:53 AM
  #42
mw9's Avatar
mw9
No problem, I just made supports out of stainless tubing for the door handles and ran a bolt through the tubing and used the factory attachment points on the handle
Old Sep 5, 2012 | 12:58 AM
  #43
mw9's Avatar
mw9
couple of interior parts that will be up for sale, also will be selling both window motors and both driver, passenger, module for airbags if anyone is interested.
Old Sep 6, 2012 | 09:29 AM
  #44
2TH PWR's Avatar
2TH PWR
Looks so familiar. Ahh the memories of flying tar bits landing on everything.
Old Sep 13, 2012 | 11:49 AM
  #45
Jagerz's Avatar
Jagerz
Originally Posted by mw9
2003 DE motor
test pipes
Y-pipe
custom 3in exhaust
pop charger
5/16 plenum spacer
light crank pulley
AC delete
Path finder mod
new plugs
new coil packs
new Amsoil motor oil l
Aluminum radiator and fans
Are you running any resonators in your exhaust or just a muffler?
Old Sep 13, 2012 | 12:13 PM
  #46
reserved's Avatar
reserved
preparing for full NASA TT
Are you planning on TTA or TTB?
If you are aiming for TTB, you may have to put weight back in again!!!!
(I have to add 52 lbs. to make TTB, and that is after a dyno re-class!)
Just something to think about.
Old Sep 13, 2012 | 12:53 PM
  #47
terrasmak's Avatar
Can't believe your still running the idler pulley (the one everyone thinks is the water pump) Just remove it and get the shorter belt.
Old Sep 13, 2012 | 02:49 PM
  #48
mw9's Avatar
mw9
I am using this in the y pipe
http://www.carchemistry.com/shop/index.php?l=product_list&c=3
Old Sep 13, 2012 | 02:53 PM
  #49
mw9's Avatar
mw9
Don't care about adding weight, I just think it looks so much cleaner
Old Sep 13, 2012 | 04:26 PM
  #50
reserved's Avatar
reserved
I understand. I'm still curious which class you are aiming for though.
Old Sep 13, 2012 | 04:43 PM
  #51
terrasmak's Avatar
Add weight with cage if needed.
Old Sep 13, 2012 | 05:00 PM
  #52
Z33_Taxi's Avatar
Z33_Taxi
I'm about to start ripping out my sound deadening material. However, I won't have the money to repaint the inside of the car. Could I just lay down some clear coat on any bare metal?
Old Sep 13, 2012 | 06:15 PM
  #53
2TH PWR's Avatar
2TH PWR
Just buy some primer and spray paint for a few dollars
Old Sep 13, 2012 | 07:03 PM
  #54
mw9's Avatar
mw9
That's what I am prepping the car
  #55
mw9's Avatar
mw9
It will be TTB
Old Sep 14, 2012 | 09:27 AM
  #56
Voboy's Avatar
Voboy
another nice thing is you can just put the ballast weights in the back to help with weight distribution/corner balance.
Old Sep 14, 2012 | 01:54 PM
  #57
mw9's Avatar
mw9
I will take a look at that thanks. What letter is the one you are talking about
Attached Thumbnails And so it begins/full track car prep-large.gif
Old Sep 14, 2012 | 02:20 PM
  #58
Bruno350z's Avatar
Bruno350z
Damn looking good, in for the pics
Old Sep 14, 2012 | 02:22 PM
  #59
mw9's Avatar
mw9
Thanks, winter project. Can't wait to get the inside sprayed white, should look awesome
Old Sep 14, 2012 | 05:19 PM
  #60
terrasmak's Avatar
B , stock belt is a 465 , you need a 450 to do it. 1 bolt does need a spacer available for $3.85 from infinity or make your own from the removed part.
Search idler , there is a 3 to 5 page thread about this
