And so it begins/full track car prep
Old Sep 15, 2012 | 08:23 AM
  #61
Z33_Taxi's Avatar
Z33_Taxi
B , stock belt is a 465 , you need a 450 to do it. 1 bolt does need a spacer available for $3.85 from infinity or make your own from the removed part.
Search idler , there is a 3 to 5 page thread about this
Can this be done for all years?
i remember wanting to this and read somewhere it was 05+
http://www.z1motorsports.com/350_g35...oducts_id=5640
Old Sep 15, 2012 | 10:07 AM
  #62
terrasmak's Avatar
O3 to 06 only , HR does not need it , and Nissan already did it on the 07+ cars that still had a DE
Old Sep 17, 2012 | 08:01 AM
  #63
mw9's Avatar
mw9
Old Sep 18, 2012 | 08:15 PM
  #64
SoCal07HR's Avatar
SoCal07HR
It's looking great! Anymore updates? I'm right behind you with preping mine.
Old Sep 24, 2012 | 01:24 AM
  #65
mw9's Avatar
mw9
2/3 of electrical pulled out, one more harness.
relocating everything to passenger side
Old Sep 24, 2012 | 08:01 AM
  #66
Voboy's Avatar
Voboy
^-is all that long enough to be relocated? Won't need to extend?
Old Sep 24, 2012 | 10:12 AM
  #67
Z33_Taxi's Avatar
Z33_Taxi
Where'd you get that shift boot? I <3 it
Old Sep 24, 2012 | 10:20 AM
  #68
terrasmak's Avatar
OEM , it's under the leather one
Old Sep 24, 2012 | 10:33 AM
  #69
Z33_Taxi's Avatar
Z33_Taxi
Well now I just feel retarded.
Awesome job on the interior. Any to clue to what color you're going to paint it?
Old Sep 24, 2012 | 11:09 AM
  #70
mw9's Avatar
mw9
Flat white enamel
Old Sep 24, 2012 | 11:12 AM
  #71
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Just curious, but what shift **** is that?
Old Sep 25, 2012 | 04:39 AM
  #72
mw9's Avatar
mw9
Razo
Old Sep 26, 2012 | 12:45 AM
  #73
mw9's Avatar
mw9
Down to the shell
Old Sep 29, 2012 | 06:59 AM
  #74
Fixxxercask's Avatar
Fixxxercask
Nice dude. Keep the pics coming. You took yours a step further than mine. Can't wait to see it all painted and caged
If for some reason I decide to not do spec Z I will remove the speaker boxes and most of the steel bar under the dash along with CF hatch and all that. ST3 might be a possibility later down the road with a motor build. At this point, it would almost be cheaper to rebuild my motor than buy all the crap I need for Spec Z.
Hurry up and come play in TT
I may not be doing it much longer. W2W FTW
Old Oct 6, 2012 | 03:08 AM
  #75
mw9's Avatar
mw9
So I decided to delete ABS and brake booster, going to a dual master cylinder with bias bar, started to draw it up. The most difficult part is modify stock pedal to get correct ratio. I have a good fab guy at work, so anything is possible with him, current pedal is around 4:1 and I need to get it around 6:1 with manual brakes
The picture on the left is just an example of the pedal box
the picture on the right I am starting to draw it up
I am in and out of town with work, so this might take awhile
Attached Thumbnails And so it begins/full track car prep-1.jpg   And so it begins/full track car prep-kit.jpg
Old Oct 6, 2012 | 04:56 AM
  #76
mhoward1's Avatar
mhoward1
Similar setup to what I have. What bore sizes are you thinking about for each?
Old Oct 6, 2012 | 05:07 AM
  #77
Fixxxercask
How much is it going to cost you to do that?
Old Oct 6, 2012 | 05:56 AM
  #78
mw9's Avatar
mw9
Under $250 I think $75 per MC, $60 for bias bar, and what ever fittings I need
Have to calculate them, I am going to pull the brake pedal off tomorrow and figure out my ratio
Old Oct 6, 2012 | 06:28 AM
  #79
mhoward1's Avatar
mhoward1
Ours is a completely different setup than a 350Z, but to give you a point of reference.
The single MC Setup was a 1" Wilwood.
The new one is a 7/8 and a 5/8 Wilwood with a 6:1 ratio. We intalled a ratio balance bar so I could tune it via the cockpit ****.
Old Oct 6, 2012 | 07:28 AM
  #80
mw9's Avatar
mw9
is the 5/8 the front and 7/8 the rear?
so now you just tee off the single line coming from the MC, for each wheel?
Thanks for the pictures, appreciate it
