Track Day Z Project
Old Jun 9, 2016 | 07:47 PM
  #241
SilverGLE's Avatar
SilverGLE
I was/am mildly torn between BC's with Swift springs or off-the-shelf Koni Yellows and Swift springs. I have the Yellows, but keep debating it!
Those SBC RPF1s sure do look pretty!
Old Jun 15, 2016 | 07:14 AM
  #242
Blurvision's Avatar
Blurvision
Back from pocono!
LOVE the new stiffer springs, took me a good few laps to get used to it. No more roll and wait for the car to hookup in the corners. Super tight and controlled.
new best lap 1.48.2
Untitled by mhulbrock, on Flickr
Old Jun 15, 2016 | 11:14 AM
  #243
CK_32's Avatar
CK_32
You are where I plan to be in a years time!
Hopefully my project Z will go according to plan.
Happily subbed.
Old Jul 25, 2016 | 10:48 AM
  #244
Blurvision's Avatar
Blurvision
Summit point weekend in the books. 95+ deg out here now, crazy heat wave going on. Need to get more AIR into the cockpit. It was crazy hot.
The Z ran with out issue. Love this car.
New best time here. 1.28.6
Usual crew ready for action.
Summit point 16 by mhulbrock, on Flickr
All used up
Club racing!
Old Jul 30, 2016 | 02:46 PM
  #245
Blurvision's Avatar
Blurvision
Old Aug 1, 2016 | 09:53 AM
  #246
camposrod's Avatar
camposrod
Great driving, Mark! Looking good!
Old Aug 1, 2016 | 12:05 PM
  #247
rizeld's Avatar
rizeld
Sweet dude, thats 12 seconds faster then me! Love to know your setup
Old Aug 1, 2016 | 12:46 PM
  #248
03threefiftyz's Avatar
03threefiftyz
I don't have any video of me around Summit (in fact I pretty much never take video.....I'm vain enough as is ), but I can give you a few speed data points, etc for reference if you want, Bluvision.
Old Aug 2, 2016 | 11:52 AM
  #249
Blurvision's Avatar
Blurvision
Yea love to see your data, more areas I can improve im sure.
Old Aug 2, 2016 | 11:54 AM
  #250
Blurvision's Avatar
Blurvision
Its all very detailed in this thread, check it out. The highlights. Stock motor. BC ER coliovers. Bushings all around. NT01 275. Stillen sway bars. No driver aids or ABS.
Old Aug 2, 2016 | 12:04 PM
  #251
Blurvision's Avatar
Blurvision
Some glamour shots
Summit Point BMWCCA by mhulbrock, on Flickr
Old Aug 3, 2016 | 12:27 PM
  #252
GodISmE's Avatar
GodISmE
Nice! I only know this track from iRacing
What is your current wheel/suspension set up: rims, camber and hight?
Old Aug 3, 2016 | 02:45 PM
  #253
03threefiftyz
Pretty solid lap overall. I actually ran pretty close to that in my foci, which is a surprisingly spry car when it is cool out (it would have been a DOG in 100 degree temps)....
Bullet Points from my 1:18.9 lap (TT3 car on Pirelli's/Aero):
Front Straight: 136mph (no draft) Brake at the 3
2-3: 110 Brake at the end of the first road
4: 112 min to 114 through the 'chute before the brakes
5-8: You average about 8mph less through the section. Should never get completely off throttle, even on the Nt01's. Best to run out all the way to drivers side curbing and almost "diamond" off the section so you are backsiding the following two elements. Allows you to get the best run and angle through 9.
9: Min speed on entry is 91-92mph at apex and max of 116-117 (limiter in 4th)
10: Min 90 on entry 103-104 as curbing ends and you avoid the hole in the dirt if you track out too far.
Old Aug 12, 2016 | 04:55 AM
  #254
Blurvision's Avatar
Blurvision
Z1 Anti fuel starvation Kit is installed. Similar idea to whats been posted with the aux fuel pump, but now using the new Holly hydramat. Z1 also provides a simple bent hard line that fits just so, inside the oem fuel bucket. Using the bent hard line and the hydramat, the extra fuel should keep the fuel bucket full.
PITA working inside the gas tank. Note you will need new orings on the top of the tank.
Hopefully I fixed my fuel gauge not working issue thats been going on. Replaced the fuel bucket with another from the junk yard, they gauge seems to function better now.
Z1 anti starve kit by mhulbrock, on Flickr
Old Aug 12, 2016 | 12:15 PM
  #255
GreyZ's Avatar
GreyZ
Holly Hydromat is some crazy voddoo magic kinda stuff. We run it in a autox/FSAE car and its rediculous how little of the mat needs to touch fuel to get full flow.
Old Aug 17, 2016 | 12:29 PM
  #256
camposrod's Avatar
camposrod
this will definitely be my next upgrade. looking forward to seeing this in action
Old Aug 17, 2016 | 01:42 PM
  #257
HRMoneyPit's Avatar
HRMoneyPit
That mat stuff is awesome!
By no abs did you actually remove the whole system or just take fuses?
Old Aug 18, 2016 | 08:50 AM
  #258
Blurvision's Avatar
Blurvision
Yea all the ABS is gone, look back a few pages to see. Made some ABS delete fittings and proportion valve.
Old Aug 18, 2016 | 10:18 AM
  #259
HRMoneyPit's Avatar
HRMoneyPit
That sounds interesting. Abs tries to kill me mid turn on track sometimes when I make a mistake that is easily correctable. Then abs comes in and tries to throw me into the dirt
Old Aug 18, 2016 | 10:29 AM
  #260
Blurvision's Avatar
Blurvision
Yea man, ABS does funky things. And After killing a ABS pump with no solution in sight, it had to go.
