It's time: BSP Solo car to NASA TT3 Build
Old Jul 2, 2015 | 08:41 AM
  #121
03threefiftyz's Avatar
03threefiftyz
Going to shake the car down at the Wilmington ProSolo at the end of the month. Should be running by then. It is a known environment where I can at least throw the car around and make sure everything is put back on correctly (at a relatively low speed). Decided to convert the car to true coil rear as well.
Old Jul 6, 2015 | 09:22 PM
  #122
christoc's Avatar
christoc
You still got my arms?
Old Jul 7, 2015 | 03:36 AM
  #123
03threefiftyz
Sitting on a shelf.
Old Jul 8, 2015 | 04:19 AM
  #124
03threefiftyz
Decided to convert the car to a rear coil-over.
7" spring is too short, so I'll have to wait until the 8's get here to put it on the ground.
Going to start out and shake the car down with 1000 front/ 450 rear. Still no bar out.
Old Jul 8, 2015 | 11:28 PM
  #125
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ Why no lockout washer for the camber arms?
Old Jul 9, 2015 | 12:15 AM
  #126
superlim9's Avatar
superlim9
mmmmm... thats purty... do you make any adjustments to the drag link to adjust toe steer or do you keep it set to stock length?
Old Jul 9, 2015 | 03:39 AM
  #127
03threefiftyz
Eh....I have 'em. The camber arms were put in a hurry a few months back. I've been pretty lazy on this build the past 6 months. Probably going to pull the roll bar out and run XP at the Pro Solo in Wilmington at the end of the month. I need to get the old ethanol out, make sure the pump/injectors are healthy, get it aligned and a few other odds and ends done first, though. I think I'll spare the new bumper/splitter cone damage and run the old BSP front bumper, though.
Old Jul 9, 2015 | 07:48 AM
  #128
SirMichael's Avatar
SirMichael
Well that's exciting, I've been considering making the switch to XP. I'll be in to see how you do at the Pro Solo.
Old Jul 9, 2015 | 08:21 AM
  #129
03threefiftyz
Oh, I'll get crushed. I'm 750lbs overweight for XP and just going to run A7's....not real slicks. Not too mention I make probably 200whp less than most of the XP cars.
Old Aug 5, 2015 | 04:06 AM
  #130
03threefiftyz
Didn't run the car at the Wilmington Pro. Plan to get the suspension done this week and get back to all the little projects that have mounted up. Probably have a shake down run on the dyno in 6 weeks or so and try and run 3-4 events before the snow starts to fall.
Old Aug 5, 2015 | 06:08 AM
  #131
DaveSB's Avatar
DaveSB
Any particular reason you went racepak over Motec?
Old Aug 5, 2015 | 06:17 AM
  #132
03threefiftyz
Ran out of miracle grow for my money tree...
Old Aug 5, 2015 | 11:23 AM
  #133
KingBaby's Avatar
KingBaby
Hardest Setting
I know the feels....love the build!
Old Aug 10, 2015 | 10:53 AM
  #134
DaveSB's Avatar
DaveSB
Is this how you gained your inch on your front fenders for the 315? I'm gonna assume you chewed them larger
Old Aug 10, 2015 | 04:08 PM
  #135
03threefiftyz
What....cutting them? If so, yes. I cut about an inch off them and pushed them out. Cleared just fine.
Update:
Rear Suspension is done, except I think I am going to have to get some sort of spring spacer. Even with an 8" spring, helper and the collar almost all the way up, the car is a bit too low.
No more spring buckets...
It's been a pretty crummy week personally, so I'm finding distraction in the car again. Hope to get a bit a done this week, then away autocrossing a vette in Wilmington, OH for the weekend. Really want to have this car buttoned up and ready to go before Solo Nationals so I can hit the ground running with it once that is over.
Old Aug 11, 2015 | 05:42 AM
  #136
DaveSB's Avatar
DaveSB
are your axles level with the car on the ground? I can't tell in the pic, but they should be. I could probably make you aluminum spacers at work, get with me on dimensions if you need them.
Old Aug 11, 2015 | 06:10 AM
  #137
03threefiftyz
Ride height is still about .5" too low in that pic. Axles are almost level as is. I ran YEARS with the car lower than it is now on the big gum ball tires and never broke an axle/diff (knocks on wood).
Old Aug 11, 2015 | 04:27 PM
  #138
03threefiftyz
Little smokey, but started up on the first crank with 10 month old E85. First start since November.
<iframe width="560" height="315" src="https://www.youtube.com/embed/nl8TXoNFpmU" frameborder="0" allowfullscreen></iframe>
Old Aug 11, 2015 | 07:02 PM
  #139
terrasmak's Avatar
How about an upper spring cup, to remove the spring from the mount. That would help you in a few ways
Old Aug 12, 2015 | 03:42 AM
  #140
03threefiftyz
Thought about it and I actually have a pair of ones from Penske, but I don't like the idea of the weight being largely on the center of the mount with that solution. Honestly, I measured the ride height and it is about where it was before and the wheel rate is higher now, so I'll toss it on the scales in a few weeks and see where it is. If it has to go up more than a 1/4" on the drivers side I will probably have to do that.
