ST/SU Build
Old Apr 16, 2018 | 08:34 AM
  #401
Dblock55's Avatar
Dblock55
Originally Posted by bealljk
with my mild steel hood vents my OEM hood is down to ~19lbs ... 4lbs less is the best I could do...
Do you run lexan windows? Trying to figure out how to delete the 40lbs of window motors/regulators, glass, panel and still have a hard-mounted/non-opening lexan window.
The rear window on the hatch is lexan. Front isnt worth the hassle (scratches) for the 1-2lb weight savings... dont run side windows at all. Just run a door skin that i made.
Old Apr 16, 2018 | 09:13 AM
  #402
bealljk's Avatar
bealljk
yea - front wouldn't be smart ... I think the OEM glass windshield is structural as well.
Great progress!
Old Apr 16, 2018 | 12:50 PM
  #403
iideadeyeii's Avatar
iideadeyeii
contemplating gutting the hood but a little hesitant, dont want to save 8lbs and have a world of problems... id run it with hood pins obviously but is that enough?? Has anyone ran a gutted hook with pins for a substantial amount of time? Worth it?
Old question and kind of useless now since you went fiberglass, but I've gutted a hood before/used pins and regretted it. Made it very flimsy, didn't save a significant amount of weight and would bend by it's own weight with the hood rod only holding one side. Never flew open on me though
Old Apr 17, 2018 | 07:15 AM
  #404
Dblock55's Avatar
Dblock55
Yea i know a few ppl that have gutted the stock hood and same thing happened... most of them ended up taping up the front of it to the bumper to prevent it from wobbling at speed... this is just a bad idea and still comes in heavier than just biting the bullet and going fiberglass.
Old Apr 17, 2018 | 07:17 AM
  #405
Dblock55's Avatar
Dblock55
Mounted it yedterday and got 1 aerocatch instslled... doesnt flex at all...
Old Apr 17, 2018 | 07:27 AM
  #406
iideadeyeii
You can weld a small piece to hold the stock window in the closed position and gut everything else.
Old Apr 17, 2018 | 08:32 AM
  #407
bealljk's Avatar
bealljk
^I want to move in that direction...I want to eliminate the OEM glass/reg/panel all-together ... If I can pin-in a cloned lexan I think that's optimal. I have a few ideas on this process ... I'll post it up in my build thread as to not hi-jack Dblocks thread!
Old Apr 17, 2018 | 01:23 PM
  #408
Dblock55's Avatar
Dblock55
haha no worries.go on and post in here if u want... interested to see what you come up with.. I have enough spare lexan to make some windows but not planning on it anytime soon... would be nice as a plug for towing in the rain
Old Apr 25, 2018 | 05:30 PM
  #409
Dblock55's Avatar
Dblock55
GREAT SUCCESS
Old Apr 26, 2018 | 06:07 AM
  #410
BluestreamDE's Avatar
BluestreamDE
That is super light! 2682lbs is the lightest ive seen so far.
Old Apr 26, 2018 | 06:09 AM
  #411
Dblock55's Avatar
Dblock55
This is without driver.... add 170lbs. Theres a few LS swapped Z's that ive seen weighing in 50ish lbs more. So technically theyve taken more weight out... i just dont know where
Old Apr 26, 2018 | 02:03 PM
  #412
bealljk's Avatar
bealljk
simply impressive ... I need to get on a scale but I think I'm around 2950lbs ...
Sorry for so many questions -
do you know how much your cage weighed?
Did you weight your door assembly when your removed them?
How did you paint your rear hatch and hood??
Old Apr 27, 2018 | 04:58 AM
  #413
Dblock55's Avatar
Dblock55
No problem! I dont know exactly what the cage weighs... i used 1.75'x.095 DOM. Its pretty heavy.
I think the 350z door assembly with everything in and on it is around 90lbs.
The hood i wrapped with CF wrap... the rear hatch I sprayed with a paint gun but since i didnt use any body filler on the fiberglass it looks like shat and im most likely just going to throw rap on that too. Same goes for the doors although those came out really nice!
Old Apr 27, 2018 | 10:04 AM
  #414
bealljk's Avatar
bealljk
I've got that fiberglass hatch and I'm mostly done with bondo'ing it and I'm at a cross roads of spending $500-$800 to have it professionally sprayed/cleared or should I diy with my qx1 color matched paint, a 2k kit with base/mid/clear is $120.
My hold up is that the hatch isnt awesome, it was sorta a 'rescue', unbranded and it may just get thrown in the trash at some point...
Old Apr 27, 2018 | 12:28 PM
  #415
Dblock55's Avatar
Dblock55
Honestly a cheap wrap on amazon or ebay is like 20 bucks as long as you're willing to do the work and it covers up a lot of crap... just a PITA to install. Lets see some pictures of this hatch. What does it weigh?
Old Apr 27, 2018 | 02:37 PM
  #416
bealljk's Avatar
bealljk
you think it'd stick to bondo and/or sanded fiberglass? I didnt even think about a wrap and I dont mind doing the work at all.
the hatch is 19lbs +/-
Old Apr 28, 2018 | 03:35 PM
  #417
Dblock55's Avatar
Dblock55
**** the finish on that is better than my hatch... what I did is hit it with primer, then wrap on that.
Old Apr 28, 2018 | 06:35 PM
  #418
bealljk's Avatar
bealljk
encouraging...I think I want to do a last round of bondo’ing to fill in some minor dips and I’ll hit it with some fine grit paper...I’m leaning towards a color matched spray paint...the base, mid, and clear is $70 off eBay ... I sorta want the experience of rattle-can’ing it.
Old May 3, 2018 | 03:57 PM
  #419
Dblock55's Avatar
Dblock55
Oooooo gigedeeeee
HipHop615
Suspension
Dec 8, 2015 10:17 PM
silencedeyes
Nov 29, 2015 06:15 AM
FixthatF-16
Oct 21, 2015 07:02 PM
Justin100
Oct 7, 2015 06:01 AM
