Track build Z to race the nordschleife
Old Nov 21, 2019 | 12:50 PM
  #61
guitman32's Avatar
guitman32
The point I was reinforcing was the same as yours, that venting to the rear of the hood by the windsheild likely not beneficial. Leaving the OEM gasketing in place is the best long term option for this area, instead utilizing hood vents/louvers to evacuate the air in a low pressure region of the hood. And if done in conjunction with limiting rad inlet area can result in a significant improvement in cooling and downforce.
Old Oct 16, 2020 | 12:19 AM
  #62
Harry Jackson's Avatar
Harry Jackson
Hey Marcel, been trying to get in contact with you for a while. Can you drop me a PM (I cannot due to only just joining this forum) need to discuss some stuff with you 😀 thanks
Old Oct 16, 2020 | 12:57 AM
  #63
GodISmE's Avatar
GodISmE
Originally Posted by Marcel Roehrl
Yes that's true, but some also think that removing that has no negative influence and could even suck out the air from the engine bay. I'll test that with some cameras and some wool threads.
What weight distribution did you end up with Marcel and what springs rates are you on? Your car's current weight is similar to mine and I'm wondering if cutting all that metal out in the rear of the chasis would make the distribution much worse.
Old Oct 16, 2020 | 04:59 AM
  #64
Marcel Roehrl's Avatar
Marcel Roehrl
Hey, the weight was distributed 54.5% to the front axle (with 50kg fuel and me in the driver seat (55,4% without me)). But I raised the front suspension, that should make it a little bit better. Don't know the spring rates out of my head, but they are the stock KW clubsport springs.
@Harry Jackson I can't pm you either
Old Oct 16, 2020 | 12:38 PM
  #65
Harry Jackson
ive spoke to Bennett and I believe he’s dropped you a message to pass on your number so we can talk via WhatsApp.
Old Oct 22, 2020 | 05:17 AM
  #66
Harry Jackson
@Marcel Roehrl I have PM’d you on here.
Old Oct 22, 2020 | 02:41 PM
  #67
260DET's Avatar
260DET
54.5% front weight distribution is pretty good, I thought that the front would be heavier than that.
Marcel Roehrl
Dec 14, 2017 05:52 AM
nkohler
Feb 21, 2011 08:43 AM
leojang
Jul 7, 2009 04:06 AM
