NoVa 350Z track build
Old Apr 20, 2022 | 08:01 AM
  #281
Aeneas137's Avatar
Aeneas137
Originally Posted by Dr Hoon
No VDC, it's a base model. I don't care about the odometer, but I'm guessing the speedo probably runs off it too. I'd like to keep that.
Also, I wasn't happy with the clearance of the hose coming off the drain so I just ordered a banjo connector to replace it with, should give me much better clearance.
Here's what I found searching the web:
​​​​​​​The 4 ABS sensors and the rear speed sensors are associated with traction and VDC. the speedometer source comes from the transmission output shaft.
Old Apr 20, 2022 | 06:29 PM
  #282
Aeneas137's Avatar
Aeneas137
Tried posting a reply here earlier but it got deleted or something...
What I found out is the speedo on these cars gets its source from the transmission output shaft.
the the four sensors at each wheel and the sensors on the diff are for abs and VDC.
Old Apr 21, 2022 | 04:07 AM
  #283
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Ah, thanks for the reminder. Yes, I do want to keep ABS.
Old May 1, 2022 | 12:11 PM
  #284
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Here's the setup with the banjo fitting, way better clearance. I also ended up putting a larger washer on the speed sensor bolt and mounting if off vertical. I don't think it'll matter, since this is just a magnetic pickup. Filled it up and ran the pump, then filled it up agan. Ended up using 2.5L of oil vs. 1.9L capacity with just the Z1 cover. So far don't see any leaks, will check again tomorrow, but I think it's good to go. The pump is loud but that's ok, at least I'll be able to tell if it's actually working.
Old May 3, 2022 | 07:35 AM
  #285
Aeneas137's Avatar
Aeneas137
looks clean. race engineering solutions are very satisfying. you even have room for an air scoop. maybe like Porsche GT3 brake scoops? They're cheap, like $5. I'd like to adapt them to fit the 350Z. elegant vs brake ducting.
Old May 3, 2022 | 07:44 AM
  #286
Dr Hoon's Avatar
Dr Hoon
5 Year Member
So far I haven't had a need for brake ducting. My akebono setup works well and pads are lasting a long time with no discernable fade.
I just ordered 1/8" thick aluminum composite sheets to make a proper rear diffuser out of, that should also improve the flow around the cooler.
Old May 3, 2022 | 03:45 PM
  #287
Escobar's Avatar
Escobar
nice work! very clean
Old May 9, 2022 | 05:36 PM
  #288
Sundown72's Avatar
Sundown72
Nice diff cooler setup!
Old May 16, 2022 | 06:26 AM
  #289
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Been under the weather for the last week, but did manage to start work on the diffuser. Got the bumper cut out, front brackets installed and the general diffuser shape made up.
I'm using 1/8" aluminum composite sheets. The diffuser is 28" wide, which is the maximum that'd fit between the fuel recerculation box on the pass side and the muffler hanger on the driver side. The two fins in the middle are spaced at 9" apart. The cutout on top of the diffuser is for the diff cooler, the cutout on the right side is for the muffler. The fins will be cut down once I figure out how much ground clearance there is.
Old May 16, 2022 | 01:45 PM
  #290
Escobar's Avatar
Escobar
nice, cant wait to see how this turns out!
Old May 18, 2022 | 04:52 PM
  #291
Dr Hoon's Avatar
Dr Hoon
5 Year Member
I spent way too many hours fitting, reinforcing and mounting this thing, but it's finally done. Final form of the difuser painted same blue as my cage and stripes
Here's a shot of mounts I created to attach it to your rear crash bar. I setup 3 of them across the bar
and finally the diffuser mounted
Old May 23, 2022 | 12:48 PM
  #292
Escobar's Avatar
Escobar
looks pretty cool, how do you plan to test it? Just run some laps and see if you feel a difference?
Old May 23, 2022 | 01:21 PM
  #293
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Testing will be limited, since I'm replacing the wing also it'll be hard to tell what's what, but I'm hoping to see a few more mph at the top end.
Old May 23, 2022 | 02:04 PM
  #294
Aeneas137's Avatar
Aeneas137
I enjoy seeing custom fabrication work being done. Looks good.
Old May 25, 2022 | 03:36 PM
  #295
Dr Hoon's Avatar
Dr Hoon
5 Year Member
The 9lives wing has arrived. I'll probably vinyl wrap it this weekend, but at least it fits well, so that's a relief.
Old May 25, 2022 | 05:20 PM
  #296
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Duplicate
Old May 26, 2022 | 07:23 AM
  #297
GreyZ's Avatar
GreyZ
Im a big fan of 9lives as far as putting out a well designed wing and being straight forward about the performance and CFD on the wing. It looks great.
Old May 28, 2022 | 12:53 PM
  #298
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Vinyl wrapped wing
Old May 28, 2022 | 01:38 PM
  #299
Aeneas137's Avatar
Aeneas137
nice!
I would be satisfied at this point just to get the rear spoiler installed but I've had reservations about drilling holes into the CF hatch. I think I'll just do the two holes on the ends like you did and use the 3M tape in case I end up not liking the result.
Old May 29, 2022 | 01:50 PM
  #300
Dr Hoon's Avatar
Dr Hoon
5 Year Member
When I switch to cf hatch the duck tail will likely go, it really doesn't serve a purpose anymore, but without the wing it did provide some down force.
Cleaned the car today so it's ready to be in packed up for the next event.
