The Big LSD FAQ thread (About various Limited Slip Differentials)
Old Apr 16, 2013 | 06:22 PM
  #381
EvilCrayon's Avatar
EvilCrayon
SE5spd, do you have any updates as to the condition of your LSD?
Also, has anybody tried the Nismo GT Pro Carbon?
Old Apr 22, 2013 | 07:38 PM
  #382
SE5spd's Avatar
SE5spd
Its doing great. Perfect for DD, great for track, I use to put OSG fluid in but now I use AMSOIL fluid and its just as quite and just as good!
recommend OSG diff to ANYONE!
Old Apr 22, 2013 | 08:00 PM
  #383
terrasmak's Avatar
My OSG is still going strong, no problems since install.
Old Oct 3, 2013 | 05:10 PM
  #384
BarrettB's Avatar
BarrettB
Default LSD install
I’m going to put a Quaife diff in my 350Z Nismo, and I’ve got a couple of questions for you guys. I planned on getting new bearings for the new diff and leaving the old ones on the old diff. I plan on using the original gears. I am wandering about re-shimming the gears. Do you guys get away with just throwing a new diff in there and letting it roll, or should I go get a full set of shims before taking this thing apart? The situation I’d like to avoid is taking this thing apart and then having to go order more parts or a special tool. Should I get new clips, seals, or what ever? I already have new mounts for the pumpkin. This car has 30,000 street miles and 3 track day events on it, and no apparent problems. Any insight from you guys that have done this before would be really helpful.
Thanks
BB
Old Oct 4, 2013 | 12:33 PM
  #385
the3kgt2's Avatar
the3kgt2
Thanks
BB
You need proper shims.
Old Dec 20, 2015 | 11:58 AM
  #386
Frostydc4's Avatar
Frostydc4
Back from the dead.
Quick question, are the 1.5 way LSD still agressive under decel? Is it possible to induce oversteer when off the gas with a 1.5 way LSD? Also just to confirm when you adjust an LSD via the clutch discs is all you are you doing is adjusting the delay the LSD goes into full lock (not the amount it locks)? Thanks.
Old Dec 29, 2015 | 06:47 AM
  #387
armt350z's Avatar
armt350z
Could be depending how you tune it.
Yes.
No.
Your ramp up timing is done by center pressure ring springs.
loudtoyz
Apr 6, 2023 04:52 AM
