DIY: Black Housing
Old Mar 10, 2009 | 09:18 PM
  #201
M6SXTZ's Avatar
M6SXTZ
hope that dont happen to me...
i should be painting by tomorrow afternoon
Old Mar 10, 2009 | 11:05 PM
  #202
M6SXTZ's Avatar
M6SXTZ
hey just a quick question... once you get ready to reassemble the head light and you stick it back in the oven for the 3 mins and try and push the thing back together wont the water vapor get INSIDE the housing???
Old Mar 11, 2009 | 06:22 PM
  #203
M6SXTZ's Avatar
M6SXTZ
umm... there is no information in the thread regarding curing times? is that important or can i just install when the paint is dry?
Old Mar 11, 2009 | 07:14 PM
  #204
LaoSiFu's Avatar
LaoSiFu
You can install it when the paint is dry but I prefer to let it dry over days but that is just me. I understand everyone need their car right away.
~Robert
Old Mar 17, 2009 | 08:18 PM
  #205
Derek Dee's Avatar
Derek Dee
Originally Posted by Behemel
Has anyone had any problems with the inside of the lens after doing this? I had a shop do mine awhile back, and shortly after it developed this problem. I thought it was condensation, but it must have something to do with chemicals, heat or both. I took some pictures with my phone, so it's a bit hard to see.
Same thing happened to mine. The opaque haze is caused by the paint curing. If the paint is not dry (no smell) it will continue to release chemicals (VOC's?) that haze up the lens.
Depending on the paint, I would wait as long as I could for the paint to fully cure. With a rattlecan, I am letting mine sit for 4 weeks when I redo them this spring (before I reseal them).
GL to you.
Old Mar 18, 2009 | 06:51 AM
  #206
TheOtherRob's Avatar
TheOtherRob
I waited a full 24 hours and mine still developed the rainbow look some. I kinda like it though, looks cool at certain angles in pics.
Old Mar 21, 2009 | 12:50 AM
  #207
Zero+4's Avatar
Zero+4
Thanks for the write up!!
I'm painting my 04.5 single projector HID's tomorrow (hopefully).. One thing I was thinking was using a eco-friendly paint with low VOC's.. which means less fumes to fog up my lenses (assuming the fumes are to blame).
I am still allowing sufficient curing time, painting them this Saturday and re-assembling them Wednesday, but it wouldnt hurt to take any extra precaution.
The paint I found is Krylon H20 Latex Spray paint, which has 30% less VOC's than traditional spray paint. Being that its latex, it also should have some flex in it to reduce chipping or cracking.
Will post up pictures and reviews of the paint once my lights are all back together and installed.
Old Mar 21, 2009 | 10:18 AM
  #208
zman600's Avatar
zman600
Originally Posted by LaoSiFu
Glad folks here are still using my instruction not sure if i mention, these instruction goes well with the 06+ headlights too.
~Robert
this helped out alot! thanks
Attached Thumbnails DIY: Black Housing-0313091734.jpg   DIY: Black Housing-0313091734a.jpg   DIY: Black Housing-0313091734b.jpg   DIY: Black Housing-0313092048.jpg   DIY: Black Housing-0313092049.jpg
Old Jun 27, 2009 | 02:22 PM
  #209
LaoSiFu's Avatar
LaoSiFu
Clean
~Robert
Old Jul 21, 2009 | 08:49 AM
  #210
831_Z33's Avatar
831_Z33
quick question. Would the 03-05 headlight cover fit an 06-08 headlight. Reason for my question is that i have the 03-05 headlights and some local guy is selling the 06-08 lights but the covers are cracked. Would it still seal the same?
Old Jul 21, 2009 | 08:51 AM
  #211
LaoSiFu's Avatar
LaoSiFu
I am 99.99% positive that it should work. From my experience working with numerous headlights they are all design the same. But if you don't mind let me know how that turns out in case that .01% that I am wrong
~Robert
Old Jul 21, 2009 | 01:44 PM
  #212
831_Z33's Avatar
831_Z33
~Robert
lol for sure. yea it does look like it would work imma give it a shot it doesnt hurt to try. ill keep you guys updated.
Old Jul 30, 2009 | 10:49 AM
  #213
Jay'Z's Avatar
Jay'Z
Did this work? Im going to replace my lens because the inside of it either stretched or paint not curing led to the ugly rainbow cracking ****..
Old Jul 30, 2009 | 04:52 PM
  #214
tight350z's Avatar
tight350z
let us know if it fits...iv had both 03-05 and 06+ lights apart and i wanna say the mounting points for the plastic inside might be different...but im not 100% sure..lol..
Old Aug 12, 2009 | 07:59 AM
  #215
rgorajia's Avatar
rgorajia
Default Condensation in my headlight
hey guys - so i did the headlight mod back in Jan of 09 and i've never had an issue with my headlight because i washed the car myself and made sure not to spray to much water on the headlight. Well i took my car to the car wash for the first time and i guess their was just to much moisture and now my headlight is filled with moisture and the headlight wont turn on (probably because of the moisture)
can anyone tell me how to fix this?
thanks
(I know that the most obvious way is to open it all up and re-do the sealing but i thought maybe putting a hairdryer into one of the open holes from the back might dry out the moisture?)
Old Aug 14, 2009 | 08:10 AM
  #216
LaoSiFu's Avatar
LaoSiFu
thanks
I strongly suggest that you open it up and re-do it again. It is the best bet. I know it is a PITA. Well not PITA but time consuming. I must have done I don't know maybe a hundred by now
~Robert
Old Aug 17, 2009 | 03:18 PM
  #217
rgorajia's Avatar
rgorajia
Default Wanna do it?
How much would you charge to do it for me?
Old Aug 20, 2009 | 06:15 PM
  #218
LaoSiFu's Avatar
LaoSiFu
hmmmm I won't be able to get to it anytime soon. In the process of moving and stuff. In case you are in a rush check out CinCity.
~Robert
Old Aug 28, 2009 | 08:03 AM
  #219
TShepp's Avatar
TShepp
I painted mine yesterday, left about 25 mins between each coat, then after it was all done I set the painted pieces in the oven for 6 minutes to let them heat up and bake. I reassembled everything and when I got to work today I noticed mine had the rainbow effect as well....Im wondering if everyone is getting this??
Old Sep 1, 2009 | 12:04 AM
  #220
Allen331's Avatar
Allen331
Not sure if this will help at all, but my headlights, which are unpainted btw, also have the rainbow haze in certain angles.
