DIY: Black Housing
Old Mar 4, 2008 | 02:55 PM
  #121
Mr.'s Avatar
Mr.
Originally Posted by LaoSiFu
wait are you taking off the ballast or opening the ballast?
since there is water in the ballast, just shake off the water off and leave it out in the hot sun to dry. crossing my fingers for you that should work.
~Robert
I meant opening the ballast. I found out that the problem wasn't the HID after I switched the bulb into the working headlamp. So now it's narrowed down to the water in the ballast, or a blown fuse. Main connection is fine and supplying power. I've read through several posts in which people just dried the ballast and everything worked out. Hope my situation turns out that way. I'll keep you updated. Thanks for your help.
Old Mar 4, 2008 | 04:25 PM
  #122
Mr.'s Avatar
Mr.
Success! I dried the ballast with a hair dryer after i shook most of the water out, then wired everything up and it turned on. OMG what a relief!
Old Mar 16, 2008 | 08:19 PM
  #123
sno's Avatar
sno
FYI - You don't have to put the headlights in the oven. I just did mine with the help of a forum member and we used a heat gun.
Old Mar 19, 2008 | 05:12 PM
  #124
XERMAN2001's Avatar
XERMAN2001
the black housing 06 lights look hot!!!
how much is it to buy stock 06 lights, from where for how much?
why do you need to heat them again after you put the sealant on? wont the sealant just air dry, why do need to soften it to re seal it?
Old Mar 22, 2008 | 02:43 PM
  #125
omega6's Avatar
omega6
Heat guns works too , however u have a higher risk in warping the protective cover/other parts; the oven heats it evenly.
Old Mar 22, 2008 | 06:06 PM
  #126
citymunky's Avatar
citymunky
Originally Posted by XERMAN2001
SICK
Old Apr 6, 2008 | 09:09 PM
  #127
j3dz's Avatar
j3dz
Laosifu: thanks for the tips today bud....got Marco_Mendoza's Z's headlight unsealed and resealed without a hitch....Great freakin write up man!
Old Apr 6, 2008 | 09:11 PM
  #128
LaoSiFu's Avatar
LaoSiFu
No problem Jed. BTW did the ballast trick work?
~Robert
Old Apr 6, 2008 | 09:36 PM
  #129
j3dz's Avatar
j3dz
~Robert
It sure did buddy....we shook the water out and used a blow dryer on it....left it out in the somewhat sun for a bit....and voila his HID started working again. he's a happy camper. it wasn't too bad....so now i wanna black out mine too hehe...might have to hit up ricks2k for that clear strip when I'm ready to do mine.
Thanks again man,
Old Apr 8, 2008 | 09:50 AM
  #130
uhhtrayyou's Avatar
uhhtrayyou
so you didnt do anything with the orange reflector? you just left it out?
what abou the light that lights it up?
Old Apr 8, 2008 | 11:07 AM
  #131
j3dz's Avatar
j3dz
wat? who you referring to buddy?
Old Apr 8, 2008 | 02:57 PM
  #132
marco_mendoza's Avatar
marco_mendoza
Thanks a lot Jedz for working on this together over the weekend. The original intent was using these directions to take out the 1/2 cup of water inside my headlight.
My HID worked after drying everything and and resealing. I'm sure since we were able to experience this, the headlight blackout is next!!!
Old May 6, 2008 | 09:35 AM
  #133
evil_tt's Avatar
evil_tt
Anyone in SoCal want to get together and do ours? Could use some teamwork!
Old May 14, 2008 | 07:39 PM
  #134
nickZ33's Avatar
nickZ33
well after gawking @ this thread for what seems like an eternity now, ive finally gotten off my lazy *** and done it. ill post pics of it tomorrow. i started at 2pm today and finished at 9pm lol.
Old May 15, 2008 | 08:16 AM
  #135
LaoSiFu's Avatar
LaoSiFu
haha don't worry about it taking it that long. Sometimes when I work on headlights I take my sweet time. Never want to rush it and want it turn out smooth. Was it easy for you to completed the project? I see that a lot of folks are afraid to do their own headlights.
~Robert
Old May 15, 2008 | 01:00 PM
  #136
nickZ33's Avatar
nickZ33
it really wasnt that bad but it is very time consuming and does require a lot of percision
Old May 20, 2008 | 03:16 AM
  #137
omega6's Avatar
omega6
if u can build a gundam model, you can do this
have fun with your new lights!
Old Jun 12, 2008 | 07:57 AM
  #138
nothix's Avatar
nothix
anyone know where to buy LED headlight diffuser?
Old Jun 12, 2008 | 08:09 AM
  #139
LaoSiFu's Avatar
LaoSiFu
I am pretty sure Ares here makes them but also check with Mike @ Clear Corners.
~Robert
Old Jun 29, 2008 | 07:41 PM
  #140
350ZNME's Avatar
350ZNME
Great job on this thread, I just blacked out the lights on my friends G35. IMO it was pretty easy but a pain in the ***. When cookin the lights, i found that 7-8 min at 250 wasn't enough. I ended up trying that 3 times and it wouldnt budge, so i just said screw it and bumped it up to 15min and it opend right up. I can't wait to find the time to do this on my Z, and im also thinking of modding the tail lights since there the 03 editions.
