DIY 06+ remove and paint center console, cubby, guages
Old Feb 12, 2012 | 02:49 PM
  #41
e30cabrio's Avatar
e30cabrio
Nice write up. How has it held up?
Thanks
Old Apr 14, 2012 | 10:21 AM
  #42
ian99rt's Avatar
ian99rt
In the middle of changing led colors on my car and figured I should fix the nasty window switch panels. I'm going to use the same flat black dupli color vinyl paint but using an plastic adhesion promoter primer.
Halfway done sanding and prep of the panels.
Old Apr 14, 2012 | 04:56 PM
  #43
ian99rt's Avatar
ian99rt
Update:
Driver Side Windows Panel: Adhesion promoter eats the grey "primer" thats directly under the black rubber coating . So that made for great fun of sanding off the adhesion promoter. I wet sanded to 800 grit and sprayed top coat directly onto plastic out of frustration. Results are great except i didn't get some of the 220 grit scratches out, we'll see how well it holds up and refinish as necessary.
Passenger Side Panel: Used lacquer thinner soaked paper towels to remove the grey primer, and wet sanded with 220 grit sand paper. Sprayed 1 good coat of adhesion promoter, wait 5 minutes and spray 3 good coats of the dupli-color filler primer. Will wet sand with 800 grit tomorrow and spray top coat. I will be going this route when refinishing the "ping-pong", minus filler primer and sanding.
Old Apr 16, 2012 | 04:59 AM
  #44
ian99rt's Avatar
ian99rt
Passenger panel turned out exceptionally well. Will be redoing driver's side when time allows.
Old Apr 18, 2012 | 06:34 AM
  #45
RDs350z's Avatar
RDs350z
Default These Instructions laid out in a Word Doc
In case anyone wanted to have this on paper, I've taken these instructions and copied and pasted them into a Word doc.
File Type: doc
Old Apr 18, 2012 | 07:11 AM
  #46
fatrabitt's Avatar
fatrabitt
Thank you for this!
Old Apr 23, 2012 | 06:09 PM
  #47
D'sNuts's Avatar
D'sNuts
thank you
Old Jun 9, 2012 | 10:55 AM
  #48
F2CMaDMaXX's Avatar
F2CMaDMaXX
Thanks for this, just go the can from Amazon, about $7.
I'm wondering if i should just use a fine brush and touch it up rather than spraying the whole lot?
Old Jun 18, 2012 | 05:01 PM
  #49
dtowngreg's Avatar
dtowngreg
How do u remove it from an automatic ? There's no place to put ur hands in to pull up
Old Jun 18, 2012 | 05:22 PM
  #50
dtowngreg's Avatar
dtowngreg
And yea dude try a sponge brush. I might take that route. Post pics please
Old Jul 5, 2012 | 09:03 AM
  #51
bishop_98's Avatar
bishop_98
BTarb24 for President.
Thanks alot for this. I got an '06 complete dash conversion for $75 b/c the guy said it looked "unrepairable". As the scratches increase, it becomes more and more of an eye-sore. Thanks for taking the time to share.
Old Jul 5, 2012 | 12:15 PM
  #52
BTarb24's Avatar
BTarb24
Haha, you're welcome. Congrats on the cheap 06 dash! I actually need to find the big piece that goes around the radio cubby and gauges. Mine got a crack in the thin piece above the radio. It's about $200 for just that piece from a dealer.. a bit overpriced so i'm hoping to find one for sub $100.
Old Jul 12, 2012 | 10:27 AM
  #53
BoriBlanco17's Avatar
BoriBlanco17
Nice job, I need to get this done ASAP!!!
Old Aug 12, 2012 | 07:54 PM
  #54
lithiumaneurysm's Avatar
lithiumaneurysm
I wanted to repaint the center dash as well, but in some areas the plastic is really scuffed up and the ping pong style pattern is no more. I was wondering what I should do to remove the texture completely. what grit sand paper should I use?
Old Aug 12, 2012 | 08:42 PM
  #55
mattleegee's Avatar
mattleegee
it comes off easier then you think, dont go to low of grit so you dont scratch into the plastic, probably even do a 600+ wet sand and it will probably come off then your close to a good finish
Old Jan 4, 2013 | 08:03 AM
  #56
e30cabrio's Avatar
e30cabrio
Thanks for this great write up. I was hesitant to r&r the cubby door and your post helped me do it. You are right. It was easy.
Now I just have to pull the damn dash again because the 08 console's gauges aren't giving me TPMS.
Old May 1, 2013 | 06:38 PM
  #57
l2iceman's Avatar
l2iceman
Thanks for this! I just spent the day doing this and it came out well! Only trouble was with the latch as I didn't have any sand paper. Ended up using a Mr Clean scrubbing pad I found in the washroom lol required extra "sanding" but it got the job done. I did multiple light coats, had no issues with botching or anything.
Old May 1, 2013 | 09:23 PM
  #58
F2CMaDMaXX's Avatar
F2CMaDMaXX
With the Duplicolor?
Old May 2, 2013 | 08:56 AM
  #59
pcguywilson's Avatar
pcguywilson
Default Thanks
Wanted to also say thanks. I went with red and love the turnout. Great write up
Attached Thumbnails DIY 06+ remove and paint center console, cubby, guages-11111111111111111111.jpg   DIY 06+ remove and paint center console, cubby, guages-22222222222222222222.jpg
Old May 3, 2013 | 05:31 AM
  #60
Z33Garage's Avatar
Z33Garage
wait so you used a glossy clear? The stock seems matte to me....
