How-to: Change Brake Pads
Just wanted to say thanks for this post as it helped me tremendously with feeling confident doing my install. I installed 4 new rotors (cross-drilled, slotted & cryogenically treated) and the NISMO pads. I did have some trouble with getting off the rear rotors but once I quit playing around and got serious with the rubber mallet they came off. I recently did a track event (from Z Fest) at Gainesville Raceway and the brakes worked aweZome! I had the 2nd fastest time in the Novice class and my brakes felt great. Also one more note with the NISMO pads I am seeing a lot less brake dust on the outside of the wheels
Z Ya!
Z Ya!
Cool, glad it helped. The stock pads are the dustiest thing's I've seen. Although the Acura TL I just got for the wife will have it's pads changed out as well. They are shading up the wheels in a single drive to/from work as well. Thinking of going with the Ceramic's from Tirerack as the Hawks I put on the Z are about $90/axle for some reason.
I called Hawk to ask about the difference in shims on their HPS pads versus stock. They said not to try and place the stock shims on their pads. They said to install them exactly as they come out of the box.
I installed the Hawk HPS pads last Saturday. It was very easy. The only thing to remember the is that the little spring clip on the outside of the caliper inserts into the wear indicator "loop" on the outboard pad, just like on the stock pads. There is only a wear indicator on one of the Hawk pads ( the outside one), unlike the stock pads that have an indicator on both. So far, no noise, and it looks like greatly reduced brake dust.
I'm preparing to do this myself for the first time. How much and where do you put the high-temp grease? I am installing Performance Friction Carbon Metallics, and they appear to already have a backing plate, do I assume I do need the shims. If I dont use the shims, so I even still need the high-temp grease anywhere?
The grease goes on the backing plate where the piston contacts the plate. This is a very light coat only. Also, I put a small amount on the outside pad where it contacts the caliper. Be very careful to keep all grease off the fiction material side of the pad.
After a week of driving on the Hawk HPS pad, they are perfectly quiet and produce almost zero dust. I'm impressed!
New to DIY brake maintenance - I noticed when checking out the front brakes that there is worn area into the rotors and I'm preparing to install Hawk HPSs. I've got 30k on the car. Is this a case where I need to have the rotors turned? Is there some threshhold of allowable rotor-indentation-depth?
Additionally, this depth results in a narrow edge coming back out at the outer edge of the rotor. HokieZ, I noticed in your photos that you had a little edge there too but it's difficult to tell exactly how big that is...
Originally Posted by G Monster
For those like myself who simply will not do anything without the proper torque settings for projects; the rear 14mm bolts get torqued to a max of 22 ft-lbs and the fronts to 36 ft-lbs.
Would you happen to have the torque range for the caliper bolts? What about the caliper bracket torque values?
Thanks.
How many times can you safely change out the pads, without them being turned or replacing the rotors. I'm sure they should be measured and checked as to the specifications, but does anyone have a decent estimate.
It seems like the shops will turn or replace the rotors 90% of the time, although I'm sure that is a profit center.
I've got a question. What is the name of this high-temp grease? I used some of that sticky orange substance between the shims for my Accord, but it's not working out too well.
Is it something like this?
Where can you get these? I went to NAPA and didn't see anything like it (only the orange brake quiet thing I already have).
Sorry if this has been answered in this thread, but I'm looking to replace my break pads with Hawk HPS. I've changed front breaks in the past without any problems, but have never replaced the rear break pads. My main concern is the emergency break connection. Did anyone recently replaced their rear break pads and can give some feedback?
Thanks.
Thanks.
Thanks.
Thanks.
