How-to: Change Brake Pads
Old Jul 9, 2006 | 12:26 PM
  #141
DZeckhausen's Avatar
DZeckhausen
Originally Posted by basam350z
Do I have to bleed all four if I am only changing the front pads?
Nope. In fact, you don't have to bleed any of the brakes if you keep the bleed screw closed while retracting the caliper pistons. Not that I'm advocating this. I always bleed a caliper when I change the pads in it. Since you're right there anyway, it's only an extra 5 minutes. And it's easier to retract the piston(s) if the bleed screw is opened.
Old Aug 25, 2006 | 01:31 PM
  #142
genxnympho's Avatar
genxnympho
Originally Posted by mikeg8r
Also having one of these is very handy:
I picked one up from sears for $10.
Front calipers: 17-22 ft-lbs
Rear calipers: 28-36 ft-lbs
Got one of these myself after using clamps and a rag for years.
Thanks for the tourque settings.
Old Oct 19, 2006 | 09:37 AM
  #143
CRIDDA's Avatar
CRIDDA
Good looking out> i second puting up a diy for all members, since we all know how big of di*ks the dealerships can be. And anyways who wants someone else working on there baby if they can do it themselves.
Old Oct 25, 2006 | 04:51 AM
  #144
Eazzy's Avatar
Eazzy
After u install ur pads, its a good idea to open each bleeder and just let it gravity bleed for a minute, While I do this, I tap the caliper with whatever I have handy to dislodge any bubbles clinging to the interior of the Caliper. U will almost always get a little air,----Calipers get hot ,they get cold, they can suck a little air yet not leak. Takes a minute is all.
Old Oct 26, 2006 | 06:24 PM
  #145
ashadiow's Avatar
ashadiow
My question is this:
What size are the bolts that hold the pads to the rotor? My set runs out at 21mm and that wasn't big enough. I got the caliper piston off and then went to remove the rotor and those two bolts were too big for my tool kit. I need to buy a new socket, but don't know what size to buy.
Old Oct 26, 2006 | 06:34 PM
  #146
Eazzy's Avatar
Eazzy
Jeez --I dont know ---I just grab a socket ---But the set I use, goes up to 22mm
And I dont understand--Pads to the Rotor ?? Caliper Piston ??? Im not bustin on ya but a caliper is a caliper---U take off the caliper and the pads come with it ----U then compress the caliper piston(s) and after cleaning and lubing ur sliders and balancers, and spraying some anti-squeal on ur pads u reinstall them and put the "loaded" caliper back on-- "crack" a bleeder, and ur ready to go.
Old Oct 26, 2006 | 06:39 PM
  #147
Eazzy's Avatar
Eazzy
I wasnt bustin on ya either ---I was just confused as to ur terms. I do so many brakes I just dont recall all the sizes for all the different ones. If u are in fact taking off the bolts that hold the caliper in place and ur 21 dosent fit ---then a 22 will
Old Oct 26, 2006 | 07:07 PM
  #148
ashadiow's Avatar
ashadiow
Sorry, should have clarified, I am replacing the rotor and I need to remove the caliper mount bracket that the pads slide into. But I gotcha, I have done plenty of brakes in the past, but they were all on mitsu's and the bolt was 19. This car is B-A-S-I-C to do, just need the right socket.
Old Oct 31, 2006 | 07:18 PM
  #149
DMK's Avatar
DMK
Is there a write-up on how to bleed the brakes and refill them? I am replacing my brake pads soon and want to bleed the entire system and replace the fluid with Motul brand. Can someone also recommend which Motul brake fluid to go with if I auto-x frequently and track twice a year on a daily driver? Thanks.
Old Nov 1, 2006 | 07:49 AM
  #150
TotalChaos's Avatar
TotalChaos
I just wanted to drop a quick thankyou to the writer of this. I just did this today per your write up and it went 100% smooth. No hangups at all.
Thanks again!
Old Nov 21, 2006 | 06:25 PM
  #151
nicolaycastro's Avatar
nicolaycastro
Great write up. Thanks!!!
One question, I plan on replacing the break fluid as well and bleeding the lines.
Does anyone know if this is the bleeder balve? And if it is do you take the black cap off?
(Right of you wrench)
Old Nov 21, 2006 | 06:39 PM
  #152
Eazzy's Avatar
Eazzy
The bleeder is to the right of the rachet and socket and has the rubber cap u just pull off, What the tool is on is the slider assy that compensates for Pad wear and keeps the caliper assy centered on the rotor---It needs to be lubed with hi-temp grease so as not to "freeze' up
And if u are serious--- The rubber cap is to keep moisture and debris out of the valve
  #153
DZeckhausen
That is indeed the bleeder valve. You remove the rubber cap and place a clear plastic tube on the end of the bleeder valve nipple, routing the other end into a catch can - either a soda can or a dedicated brake bleeding catch bottle.
Then you follow these instructions for bleeding the brakes: http://www.zeckhausen.com/bleeding_brakes.htm
Old Nov 21, 2006 | 07:36 PM
  #154
nicolaycastro
Great, thanks for the fast response.
One more question...
I have read that the shimmeis (metal that goes between pad and caliper) can be left off. But my question is, if the pads are completly naked (nothing in between the pad and the caliper/piston, wont there be any damage to the piston or to the bad?
Old Nov 21, 2006 | 07:44 PM
  #155
Eazzy's Avatar
Eazzy
If the new pads come with antisqueal shims , I use them, if not, I dont. But I always spray a liberal coat of anti squeal and let it "tack" before I load the calipers
No damage will be caused what so ever
Old Nov 21, 2006 | 11:11 PM
  #156
SS21CA's Avatar
SS21CA
On my brembos, the dealer had changed the pads a year and a half ago to Hawk HPS. When I went to swap my pads and rotors, I used the same shims that were used before by the nissan dealer. AFter a while of debating in my head I realized the shims dont make sense to me. They are an angled design, meaning they cover maybe 70% of the pad from behind. I am not sure if anyone has seen the shim I am talking about, but I would like to know if I should continue using them, or remove them?
Thanks
Old Nov 22, 2006 | 06:12 AM
  #157
Eazzy's Avatar
Eazzy
I'll just repeat what I said ---If the pads come with them use them , if not ---Dont. If u happen to reuse them as in ur case --Dont loose any sleep over it
Old Nov 22, 2006 | 08:36 AM
  #158
nicolaycastro
I decided to leave them off, since they were kind of hard to fit. I guess I'll enjoy the extra sound eventhoiough thet'll be making ebough of it since they are Hawk HP plus.
Old Dec 23, 2006 | 08:36 AM
  #159
bigwilly03's Avatar
bigwilly03
I am attempting to change my brake pads starting with the rears first. I can't for the life of me get the rear caliper bolts to even budge. At first I thought I had it moving turns out I just ended up cracking the socket ( Lesson don't buy $10 socket sets. Seemed like a good idea at the time.) I moved onto some wrenches and nothing. Next to the air rachet with the impact sockets, no snapping this time but the stupid bolt still won't move. I've just sprayed a bunch of WD-40 on the bolt to let it sit for a while. Any ideas will be greatly appreciated.
Old Dec 23, 2006 | 09:47 AM
  #160
HokieZ's Avatar
HokieZ
Are you sure you aren't turning them the wrong way? Sounds stupid but if you are looking at it from the opposite direction, could be. And are you talking about the bolts holding the caliper or the bolts holding the bracket the calipers are mounted to? The bolts holding the caliper should not be on that tight.
