Cost to change springs.
Old Feb 2, 2005 | 02:19 PM
Badmonkey's Avatar
Badmonkey
Default Cost to change springs.
How much should it cost for me to have my springs changed? I have the eibach springs and was basically looking for a ballpark figure on how many hours a shop might take to do the swap. I may just do it myself if it isn't too hard.
Thanks
Old Feb 2, 2005 | 03:26 PM
hndumafia's Avatar
hndumafia
do it yourself! no better feeling than completing a mod on your own. and if you dont have the tools, spend the money on tools instead of the install.
Old Feb 2, 2005 | 05:10 PM
Chicken's Avatar
Chicken
I was quoted $350 from a professional alignment shop. It ain't cheap, that's for sure. they said 2-3 hours, plus a bit more to check alignment, though I'm going to have that done after a month or so to see if things have settled.
Old Feb 2, 2005 | 05:53 PM
tractng's Avatar
tractng
Badmonkey_1,
I am thinking of lowering my car too. My dad in law has the tools.
Let me know so we can get together for the install.
I don't know what springs to get at this point. Tein S or hotchkis.
hndumafia,
How is the hotchkis springs? Were you able to get the alignment back to spec or close to it? Any camber kits needed?
Would i be fine just getting the springs? I don't really need to sway (looking for more looks now).
Tony
Old Feb 2, 2005 | 09:33 PM
hndumafia's Avatar
hndumafia
i am happy with the hotchkies springs. the car feels good around turns and i feel no bounce. i actually haven't gotten the car realigned since i installed the springs because my tires were pretty worn anyway. but i have new tires on order, and they should be on next week. i'll be getting an alignment then so i'll know for sure if it goes back into spec or not. but since the drop is only like .6-.7 inches getting back into spec should not be a problem. and yea you would be fine with just the springs. i actually just put the sways on a couple weeks ago, and ive had the springs since august. the sways really do make the car feel more responsive when turning and keep it flat, and i'd recommend upgrading at a later time if you want the increase in handling.
Old Feb 3, 2005 | 04:49 AM
King Tut's Avatar
King Tut
A good shop should be able to do it in less than 2 hours. So I wouldn't pay more than $200 to have them installed. As for doing it yourself the only real special tool you need is spring compressors and you can normally rent those from automotive parts stores like Pepboys.
Old Feb 3, 2005 | 06:18 AM
rvshehata's Avatar
rvshehata
If you don't have a spring compressor, you could alway use the 'base of a tree, pray, and release' method.
Old Feb 3, 2005 | 07:03 AM
hndumafia's Avatar
hndumafia
it's pretty hard to get some of the bolts out with only hand tools, at least i thought so and im a decently strong guy.
Old Feb 3, 2005 | 07:17 AM
rvshehata's Avatar
rvshehata
a breaker bar/wrench helps increase torque, it's usually about a foot and half to two feet long.
Old Feb 3, 2005 | 08:11 AM
hndumafia's Avatar
hndumafia
good point...i didn't even think of using a breaker bar.
air tools still sound cooler though .
Old Feb 3, 2005 | 08:33 AM
protocav's Avatar
protocav
i have done springs or coilovers on about 20 Z's/G's and i charge 60 bucks for a spring install. it takes me about an hour and a half.
the Z doesen't need a spring compressor, because the springs aren't under very much preload at all.
Chad
Old Feb 3, 2005 | 09:49 AM
nicolaycastro's Avatar
nicolaycastro
Does the car have to be lifted too much, or can it be don just with the car jack for every wheel. Sorry if the quetion is too dumb.
Old Feb 3, 2005 | 10:54 AM
hndumafia's Avatar
hndumafia
you should put the car on jack stands while changing out the springs. it's not safe to just leave the car on a floor jack.
Old Feb 3, 2005 | 12:44 PM
Badmonkey's Avatar
Badmonkey
Thanks for the replies. I am going to do it myself. I have an air compressor and a garage full of tools. On the other hand, if I could find somebody around here to do it for $60, I would go that route. Just to not have to take the time.
Old Feb 3, 2005 | 12:48 PM
King Tut's Avatar
King Tut
Breaker bars are superior to air tools. I have seen many a bolt that an air tool wouldn't get but a 2 foot breaker bar with a 3 foot cheater pipe would (Honda 32mm axle nut).
Old Feb 3, 2005 | 12:57 PM
rvshehata's Avatar
rvshehata
It also help conserve knuckel skin, what an added bonus.
Old Feb 3, 2005 | 01:37 PM
Bertg's Avatar
Bertg
A local tuner shop charged me $150. Took a couple of hours.
Old Feb 3, 2005 | 04:57 PM
Chicken's Avatar
Chicken
BertG, hmmm I believe I'm in your area (unless you're in the other South Bay). Would that be Torrance area? If so, which shop did you take it to? I might have another place install the springs.
Old Feb 4, 2005 | 06:48 AM
Bertg's Avatar
Bertg
Chicken, yes I'm in Torrance. The shop is ES Technical Roadsports in Gardena.
Old Feb 4, 2005 | 07:31 AM
Chicken's Avatar
Chicken
Thanks, I'll give them a ring and see...
Justin100
Nov 25, 2021 06:26 AM
