Hotchkis swaybars - clunking
Old Sep 5, 2008 | 09:52 AM
trodis's Avatar
trodis
Originally Posted by Rowlett
mmm, I thought i saw, Upgraded Endlinks was the fix?
+1
It is the fix. There are vendors that sell the endlinks here.
Stock endlinks cannot handle the stress from the stiffer settings that aftermarkets produce
/Thread
Old Sep 5, 2008 | 09:59 AM
350Zenophile's Avatar
350Zenophile
ah yes, the unspoken truth about aftermarket sways....you'll need aftermarket endlinks to go with them.
My Powergrids go on Monday. woot!
Old Sep 5, 2008 | 02:42 PM
DukeEntDotCom's Avatar
DukeEntDotCom
blah
Originally Posted by trodis
+1
/Thread
Yes, but again - I have SPL endlinks...so I do have upgraded endlinks.
Old Sep 8, 2008 | 10:15 AM
350Zenophile
UPDATE: Had the PowerGrid endlinks installed today. Zero clunking and a much more compliant ride. I highly recommend them!
Old Sep 8, 2008 | 12:38 PM
WTX350Z's Avatar
WTX350Z
Might recheck the torque on them.
Old Sep 9, 2008 | 08:03 AM
DukeEntDotCom
blah
I'm getting my brake pads done soon, so I will have them check the torque on everything, and see if they could grease the bushings.
Old Sep 9, 2008 | 09:19 AM
trodis's Avatar
trodis
How much did u pay?
Did you install urself? Easy?
Old Sep 9, 2008 | 10:08 AM
350Zenophile
I paid a shop to do it for a few reasons;
1. I was having issues with the nuts falling off early on, so I used loktite to keep them on. Used the wrong kind (Red instead of Blue) and so they would need a torch to remove them. I could do it, but would be a royal PITA trying to do so while laying on my back.
2. After lowering I can no longer get my car on my ramps and while you can install them on jacks, they need to be adjusted for length (zero preload) while the car's weight is resting on the tires. A shop can install and adjust all in one step on an alignment rack.
I went to a local shop, Vortex Motorsports, known best for working on Porsche racing cars. They charge $98/hour and although it took them 2, they kept to their estimate of 1 hour so I ended up paying $106 with tax and shop supply charge. Money extremely well spent IMO seeing as It would have probably taken me 4 hours at least with a sore back, busted knuckles and a lost Saturday to boot.
Old Sep 9, 2008 | 10:25 AM
WTX350Z's Avatar
WTX350Z
For 100.00 I can understand your thoughts there!
kinda cool how @ home the Z looks in a group of Porsche's
Old Sep 9, 2008 | 05:37 PM
Slow*Jim's Avatar
Slow*Jim
Just FYI, on a car that is at stock ride height (like mine) you can install the endlinks with the front end jacked up and hand tighten, then lower the car and torque them down. I did my fronts in about an hour with basic hand tools and zero know-how or experience working on cars.
Not knocking you for taking it to a shop or anything, with the loctite issue and the car lowered, $106 is a steal.
Old Sep 18, 2008 | 02:06 PM
DukeEntDotCom
blah
Got my front brake pads changed today. The guy checked the torque on everything, and said he didn't find anything loose. He also greased the bushings...
Still got the clunk.
Old Oct 18, 2008 | 03:19 PM
DukeEntDotCom
blah
Took off the SPL links and put OEM on today - clunk gone.
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
fernandito7
May 3, 2011 08:51 AM
350Zteve
Jan 23, 2004 01:39 PM
Stu E
Dec 30, 2003 05:47 PM
