Looking for a 1.5" drop, what springs should I go with?
I am planning to get the kinetix front a-arm and rear camber arm with the drop. I am going for looks not performance so I probably will not get sways, also my Z is daily driven but I don’t mind a ruff ride as long as it doesn’t get insane.
I just need help picking out a set of springs to meet my needs, as I don’t know anything about them! TIA for any help!
Tanabe, They Are Great. Make Sure You Don't Lower The Profile On Your Tires, Or You Will Scrape Going Over Bumps. I Am Running 275/35/19's In The Rear With No Problems. (toyo T1r's) But I Ran Pirelli Assemetrico's 30 Series Originally, And Them Were Too Low.
I am going to drop it 1.5" on my stock track rims for now. I am running 225/45/18 in front and 255/45/18 in the rear. I am curious though, how would lowering your tread height make the tire rub? Wouldnt it make it rub less since there is less total diameter? Thanks for the sugestions!
Originally Posted by HockeyZ39
Where did you guys buy your springs from? All I can find is the TANABE springs that drop 1.2" all around. Thanks
I've got a G, and did not have to do anything....
Got mine via Performance Nissan.
Good-luck,
Progress Technology makes an exceptional set of performance springs for the Z and G Coupe. Manufacturer quoted drop is 1.2" front and rear, but we have seen 1.5" easily once installed on a Z.
Reference to our Vendor Classified:
https://my350z.com/forum/showthread.php?t=137531
I would not drop the car that much on just springs - it is a bit extreme. Lowest I am comfortable with is an Eibach level drop, which is about an inch - anything more and should be looking into coilovers
And yes, you will absolutely, without question need front a arms and the SPC rear camber kit to dial back into near stock camber levels and toe levels (rear)
