Lowering springs affect stock shocks
Old Nov 20, 2005 | 01:48 PM
mikerz's Avatar
mikerz
Default Lowering springs affect stock shocks
Just wondering, if I change my springs to the Hotchkis or Tein S-Tech springs and still use stock shocks.
Will my stock shocks wear faster?
Or should I just go with aTEIN 350Z / G35 Type BASIC Damper
Old Nov 20, 2005 | 02:00 PM
Vamos_Rafael's Avatar
Vamos_Rafael
get coilovers
same amount of work
just u have to do it 2nd time if u upgrade shocks or go coilovers from springs
Old Nov 21, 2005 | 05:08 AM
RedRicer's Avatar
RedRicer
I am running S-Tech's and I like them alot with the stock dampers. I believe they will wear a bit faster than with stock springs but not more than 5-10 k miles. IMO, with a damper that lasts 50-60 k miles, whats 5-10?
However, I am currently planing on ordering a set of Tokico D-Specs because I would like some more rebound. Overall it will be a bit less money than coil overs but it will lack the adjustability. I honestly wouldn't adjust my suspension that much so coilovers seemed like an invitation to setup disaster.
Old Nov 21, 2005 | 12:47 PM
mikerz's Avatar
mikerz
Anyone installed aftermarket springs and still use their stock shocks?
How many miles did you put in and how's the ride?
Old Nov 21, 2005 | 01:29 PM
TruBluZ's Avatar
TruBluZ
I have the Eibach Pro Kit with the stock struts. Only had it for about 1500 miles. No problems yet. The ride is stiffer than stock. But I like it that way.
Old Nov 21, 2005 | 02:19 PM
dirtroad's Avatar
dirtroad
Been using this setup for about a year now, ride is stiffer but handling improved. It's a good option for those who want to lower the car, improve handling, but not spend very much. Never regretted it at all. RS*R TI2000 springs.
Old Nov 21, 2005 | 04:42 PM
350ztoronto's Avatar
350ztoronto
what about camber and toe ? did it effect that in anyway?
Old Nov 21, 2005 | 07:08 PM
.Sin.'s Avatar
.Sin.
I am planning on Tanabe NF or GF series with stock shocks...
Dunno if this is a good idea...
Anyone can estimate how long my shocks will last??
just dun wanna spent that much on coilover as my car will not go on track anywayz...
Old Nov 21, 2005 | 07:30 PM
palepony's Avatar
palepony
everybody's answer in this thread has to be qualified with information on whether they have a 2003-04 or a 2004.5+ OEM shock/damper
the damping specs are different depending on the OEM years
to the OP, hotchkis can be handled by either the old or revised OEM specs. on the other hand, S-techs have an increased front spring rate that i would only run if you were going with aftermarket dampers. you might be able to pass s-techs if you have the revised OEM suspension, but the front rates may not be handled well.
pp
Rowlett
Misc.
Oct 2, 2015 10:38 AM
