Rotora rotors not up to spec?
I just went this morning to turn the front rotors... Turned out my rotors were not up to spec even in parts that were not touched by brake pads. The standard thikness for 350z is something like 1.181 and my were 0.900 or something originally...
When you buyig rotors online nobody shows the specs... now I'm paranoid about what to buy....
I send a question to Rotora and that's what I got back
Vlad,
Hello. All Rotora discs are with OEM specifications. There are 2 types of front discs for your Z:
1.
Non-Brembo caliper rotor.
2.
They both have different thickness. The rotor that goes with the Brembo calipers obviously is the thicker one.
hope this clarifies for you.
regards,
Tech
So I went into research mode again and found this
http://350zmotoring.com/2003_nissan_...fications.html
Which says that non-brembo should really be 0.95. As new Rotora was. Still no idea about how low can I go when resurfacing them...
Vlad,
1.
2.
regards,
Tech
