NEW Stance SUS Coilover Review
Old Aug 10, 2006 | 12:14 PM
  #181
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Originally Posted by anotheraznguy
give me a pm and i'll let you know =)
also...
the reason z guys hear more than the g guys is simple...
w/ z's there isnt much sound deadening where the rear struts are compared to the g's
you got pm..
Old Aug 11, 2006 | 06:59 AM
  #182
jinsei888's Avatar
jinsei888
Originally Posted by hatchboi
hey GTNPU Z what side are you having the noise? cause i have the same problems with the squeaking on the rear right side. i duno what to do to make it stop, if you find a way to make it stop tell me man cause this **** is annoying me.
my noise is from the rear right also, and it is NOT the oem TSB issue, because I've heard that noise before many times on other peoples' cars distinctly
try the rubber gasket thing and tell us james!!!
Old Aug 11, 2006 | 10:29 AM
  #183
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Yeah...I'll try to mess around with a few things.
Old Aug 11, 2006 | 11:50 AM
  #184
twenzel's Avatar
twenzel
Also try a bit of WD40 where the spring perch touchs the spring. Any metal to metal contact is going to make noise.
The problem I am having with the dynamat on the upper mounts, is that the bolts won't stay tight. I will tighten them but then the dynamat will compress when heated and the bolts come loose again. grrrr.
Old Aug 13, 2006 | 08:36 PM
  #185
Vq.turbo.DremZ
Bump where'd the Autornd guy go... pmed him awhile back...
Old Aug 14, 2006 | 04:11 PM
  #186
IslandZavage's Avatar
IslandZavage
what ever happened to the dampaning adjustable cable for the rear? Is that still in the works?
Old Aug 14, 2006 | 04:49 PM
  #187
drumma022's Avatar
drumma022
I will check at Stance tomorrow with the cable adjuster. I also heard of a new EDFC type controller in the works. We'll See!
Old Aug 14, 2006 | 05:01 PM
  #188
Vq.turbo.DremZ
Anyone want to give me a price quote, drumma002 can you me a quote? Anotheraznguy hasnt been on recently.
Edit: NVM i thought you were a dealer.
reEdit: Wait are you?
Old Aug 14, 2006 | 11:03 PM
  #189
anotheraznguy's Avatar
anotheraznguy
hey sorry...
everyone...
the internet at work died...
so i havent been able to do much recently...
+ throwing in v8 with full rebuild into rx7 in 2 weeks is a chore in itself =)
anyways...
damping adjustment cable have not heard much about it..
Old Aug 15, 2006 | 02:48 PM
  #190
IslandZavage
I called them up, and they said they were in the works of a EDFC like unit and they are working up the prototype..
They also said in the mean time that you could drill a 6mm hole in the rear plastic strut bar and be able to adjust the rears with a allen wrench. im not sure how easy that would be though. But the Greddy has a similar setup for their adjustable cable..
Old Aug 19, 2006 | 06:28 AM
  #191
twenzel's Avatar
twenzel
See my thread here. I think I may have the answer for the noise problems.
https://my350z.com/forum/brakes-and-suspension/211475-the-real-problem-with-true-coilover-rear-suspension.html
Old Aug 19, 2006 | 08:30 PM
  #192
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
https://my350z.com/forum/showthread.php?t=211475
Nice find! Anyone know if there is an aftermarket replacement for this or something similar? Does Nismo have one?
Old Aug 25, 2006 | 08:02 PM
  #193
three_fitty's Avatar
three_fitty
Just a pic for ya'll after the track. Found a few issues with the coilovers but i'm workin on it. Overall its an awsome coilover.
Old Aug 29, 2006 | 12:35 PM
  #194
dewuser's Avatar
dewuser
It doesn't look like we can easily access the "REAR ADJUSTER DIAL" from the top.
As mentioned that would require drilling thru the plastic outer-cover and the metal rear brace. (see pic below)
Anyone has a better idea?
Or should we always dismount the rear suspension to get to the "REAR ADJUSTER DIAL"
Old Aug 30, 2006 | 11:23 AM
  #195
twenzel's Avatar
twenzel
I can remove the rear coilover in under 15 minutes to adjust the dampening... The only other way is to drill into the plastic cover up top and adjust with a long allen wrench.
Old Aug 30, 2006 | 07:00 PM
  #196
BloMyS14's Avatar
BloMyS14
I have some action pics, I'm on Stance. It's a little lower now.
Old Aug 30, 2006 | 07:09 PM
  #197
jinsei888's Avatar
jinsei888
Originally Posted by BloMyS14
I have some action pics. It's a little lower now.
thats how you gotta roll low! pimp!
Old Aug 31, 2006 | 08:29 AM
  #198
daytona350z's Avatar
daytona350z
it seems as though your rubbing your front tire on your fender well here.
Old Aug 31, 2006 | 10:38 AM
  #199
drumma022's Avatar
drumma022
A little rubbing doesn't hurt
Old Aug 31, 2006 | 03:28 PM
  #200
skidmarq's Avatar
skidmarq
If any of the sponsors/vendors would like some business, PM me some pricing on the Stance coilover kit. After lurking in this thread I'm very intrigued to say the least
