Do I need to replace my shocks?
Old Mar 7, 2006 | 10:16 AM
derek173's Avatar
derek173
Default Do I need to replace my shocks?
For the past month my car has started to squeak on bumpy roads. Thinking it was a bushing I checked and lubed them all and still squeaking. So here is a description of the problem.
after the car has been sitting for a while, lets say overnight. I will not hear the squeaking for a few minutes of driving but once it starts it doesnt go away. So one day I pull into the garage right after I just started to hear the squeak so I start to shake the car and I hear it loud and clear coming form the front of the car. If I get out of the car and start to shake it I will hear the squeak but if the car is parked for a minute of two it cant be replicated anymore.
03 G35c, 60k miles, Daily Driver with track days Stock suspension.
Old Mar 7, 2006 | 10:52 AM
Struts will outlast regular shock absorbers, but still will no last forever.
Here is a simple test for the front and rear. Push down the bumper and let it go. The bumper should travel up once the back to the original position. The road is a better test but because of familiarity, it is difficult to remember what the car used to ride like. Another test is to drive a new G35 and make a mental note of the handling.
Old Mar 7, 2006 | 12:18 PM
imseksy's Avatar
imseksy
just get new shocks... get koni adjustables or bilstein.
Old Mar 7, 2006 | 12:22 PM
derek173's Avatar
derek173
well I want to be sure its the shocks, could it be some kind of strut mount? The car does not bounce at all
Old Mar 7, 2006 | 12:26 PM
mdracer76's Avatar
mdracer76
could be a bad bushing ... just a thought
Old Mar 7, 2006 | 12:28 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Check & make sure your rear & front strutbar bushings are properly lubed. I've encountered several people who had squeeking problems & it ended up being their strut bar.
Old Mar 7, 2006 | 12:34 PM
derek173's Avatar
derek173
i have been under the car a few times and lubed all bushing I could see, especially the sway bar bushings
if any of you guys can tell me a number from this diagram I could check I think its #1 that could be a problem
Old Mar 7, 2006 | 12:38 PM
imseksy's Avatar
imseksy
well in that case i dont think its the shocks. i had a similar problem with my civic and it was the rubber bushings... but honda replaced it under warranty
Old Mar 7, 2006 | 02:28 PM
derek173's Avatar
derek173
I SWEAR GUYS, After 5 minutes of driving it begins and if you park it right a way and start to shake the car you can hear it. After a minute of being parked I am not able to reproduce it, it goes away after the car is settled??
Old Mar 7, 2006 | 03:10 PM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
Your car is telling you that it's time to replace it with an '06 G35 coupe with the sport tuned suspension package.
Old Mar 7, 2006 | 03:38 PM
Isolating squeaks is a headache as you know. Is it possible to put the car on a lift, and have someone push the bumpers up and down to try to get it to squeak? And you stand by with a can of WD40?
Old Mar 7, 2006 | 04:04 PM
derek173's Avatar
derek173
well that was the best idea cause just before I read this I asked soemone to listen to it and they were like it sounds like its coming from the hood
So I sprayed everything the hood touches with............WD40 , the latches and even the rubber lining so far so good. However I will report back after some more driving.
Old Mar 7, 2006 | 06:30 PM
Good luck. Not to be a Smart Alex but WD40 is the most worthwhile item in my tool box.
Old Mar 8, 2006 | 08:37 PM
derek173's Avatar
derek173
well seems like its gone, Funny the first thing is says on the bottle is :
-Stops Squeaks
Rev_Night
Nov 7, 2020 06:00 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
350z82
Oct 1, 2015 06:25 PM
