View Poll Results: Stoptech: Yes or No
Thumbs Up
58
82.86%
Thumbs Down
17.14%
Voters: 70. You may not vote on this poll
Stoptech BBK
Old Apr 19, 2007 | 09:41 PM
  #161
r0mey's Avatar
r0mey
Originally Posted by Bubble
my vote to Rotora.
+1
Old Apr 19, 2007 | 10:12 PM
  #162
AroundMyHorn's Avatar
AroundMyHorn
i dont know about their past but they were very helpful and were pretty much dead on concerning the timing on my brakes. Thanks Stoptech
Old Apr 20, 2007 | 07:50 AM
  #163
__jb's Avatar
__jb
Z + Rear Seat
Here is a quote from StopTech that might help answer a few questions.
Originally Posted by StopTech
Correct...ST40 is sort of a generic term for our standard 4 piston caliper body, even though there are a variety of piston sizes, 28mm, 32mm and 35mm caliper widths and varying clearance cuts that are performed to the caliper surfaces for wheel clearance, mouting location and caliper stiffness. There is a stamp on the caliper that we can use to determine what calipers are installed but short of measuring the piston diameters, you would not be able to tell what exact caliper you have without our help.
We are now taking orders for the 05+ G35 and 06+ 350Z kits, but the parts have not yet finished production. We are expecting them to be ready for shipping near the end of this month.
The factory drum style parking brake is maintained and requires no modifications.
-Erik-
It would seem that anybody that bought a StopTeck BBK for an 05+ G35 or a 06+ 350Z before now, got the older brakes that were not proportioned correctly for these models.
I don't think that would be terrible. I don't see any other BBK manufacturers making separate calipers for the newer Gs and Zs... But, if you have the choice, and you're going to get a StopTech BBK, you might as well get exactly what they designed for your car.
Old Apr 23, 2007 | 10:43 AM
  #164
mistico's Avatar
mistico
I was a bit worried about this since I have an 06 with the 03-05 kit but I called both Brembo and AP brakes and they both use the same kit for 03-06. They have not made any updates for the 06+ models.
It doesn't mean that the updated kit from stoptech won't be better balanced, but at least I know it'll work as it should and should perform fine on track, which is why I got them.
As far as I know the 06+ has bigger rotors up front only(12.6") and the rear rotor and calipers are the same as previous years. So if you're doing all four wheels, why would you need different piston diameters if the weight distribution of the car has not changed when compared to pre 06 models?
Old Apr 23, 2007 | 12:43 PM
  #165
__jb's Avatar
__jb
Z + Rear Seat
Maybe the master cylinder is different? I dunno?
Good time for the StopTech guy to pop in with the answer...
Old Apr 25, 2007 | 09:44 AM
  #166
mistico's Avatar
mistico
Do any of the Stoptech employees have an answer to the question above?
Basically, if you have a pre 06' 350Z 4 wheel BBK on an 06+ Z, why does it have to be different if you're changing all four sides? I understand if you do only the fronts and you want to keep the balance, but if you do all four, shouldn't it work properly balanced?
Did weight distribution or master cylinder dimensions change on the 06+ Z?
The reason I ask is because I have a pre 06 14" STOPTECH kit on all four corners with ST40F/ST45R on an 06 350Z.
Thanks!
Old Apr 25, 2007 | 11:48 AM
  #167
Chebosto's Avatar
Chebosto
*hocus pocus*
i am summoning Howard@StopTech....
Ommmmmmmmmmmmmmmmmmmmmm... oommm..........
Old Apr 25, 2007 | 12:09 PM
  #168
StopTech's Avatar
StopTech
Vendor - Former Vendor
Thanks!
You'll be fine balance wise.
The 06+ Z's and 05+ G35's have larger rotors, and larger piston sizes creating more brake torque all around. Our design intention is to match stock brake torque. So if OE goes larger, it's best that we go larger as well.
On a 2 wheel kit, going with the new kit is absolutely essential. On a 4 wheel kit, the newer kit should be used whenever possible.
Old Apr 25, 2007 | 12:10 PM
  #169
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Ok, then, how is the progress on the new kit. When are you looking on having the kits for the 05+ G35's available?
Dave
Old Apr 25, 2007 | 12:38 PM
  #170
StopTech's Avatar
StopTech
Dave
The kits are ready for sale. Stock and lead times will depend on your exact color and size choice.
Old Apr 25, 2007 | 01:20 PM
  #171
mistico's Avatar
mistico
Thank you for your replies.
One more reason to use your products!
Old Apr 25, 2007 | 03:08 PM
  #172
Chebosto's Avatar
Chebosto
see? my spell works.
Old Apr 25, 2007 | 03:23 PM
  #173
Fleet Z's Avatar
Fleet Z
I have a 2006 Z and just installed Stoptech 4 piston calipers and 14" drilled rotors on all four wheels. I have one word to describe the brakes...Fabulous....
The brakes are ultra powerful and smooth as silk.....
I waited for the kit engineered for the 2006+ models and I'm glad I did. The entire kit "bolted on" and the only fab work was cutting away the original dust shields on both the front and rear brakes. No ABS issues, no warning lights, no noise.....The quality of the calipers, brackets, rotors, hats, lines is second to none. You get what you pay for.
Old Apr 25, 2007 | 03:57 PM
  #174
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Awesome! Thanks for the quick answer!
Dave
Old Apr 25, 2007 | 03:59 PM
  #175
AroundMyHorn
did you shave off the original caliper moutning bracket so that it matched the fronts?
Old Apr 25, 2007 | 06:12 PM
  #176
__jb's Avatar
__jb
Z + Rear Seat
Where did you order the new brakes?
Direct from StopTech?
Old Apr 25, 2007 | 09:58 PM
  #177
StopTech's Avatar
StopTech
There is no need to do any cutting of the brackets to install our kit...it is a direct bolt on.
-Erik-
Old Apr 29, 2007 | 08:45 AM
  #178
Ztalker's Avatar
Ztalker
pics are appreciated.
Old Jul 26, 2007 | 12:01 AM
  #179
DMK's Avatar
DMK
So there are two versions of the 355mm 4 wheel kits? How can you tell a difference between the ST40 and ST45 calipers?
Old Jul 26, 2007 | 07:44 AM
  #180
__jb's Avatar
__jb
Z + Rear Seat
The thread that never dies...
The st45 is a 4 piston caliper used on the rear only. Since the ST45 is a different caliper than the ST40 and uses different pads that the ST40, I suspect you could tell the difference by looking at it.
