Lowering Springs
Old Sep 10, 2006 | 09:48 AM
kelechi77's Avatar
kelechi77
Default Lowering Springs
Anybody have the Tein H tech springs? I'd like to see the drop?!
Old Sep 10, 2006 | 12:00 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
not a noticeable drop... go with S-tech or hotchkis. I'm on hotchkis and usually never have problems scraping if I'm careful.
-Mike (is assuming you're thinking about H-tech because you don't want to lower too much and scrape)
Old Sep 10, 2006 | 12:01 PM
michaeljr6's Avatar
michaeljr6
s-tech are awesome
Old Sep 10, 2006 | 01:00 PM
Jason021174's Avatar
Jason021174
maybe this will help http://www.tein.com/ti/p26.html
Old Sep 10, 2006 | 06:11 PM
kelechi77's Avatar
kelechi77
Got a pair of S tech's on the way from ebay. Will I need new shocks? I'm thinking of just going with stock shocks and seeing how it goes
Old Sep 10, 2006 | 09:25 PM
Jason021174
Default new shocks
depends on how well the spring rate of the teins match with the stock specs. shocks and struts are valved to certain compression and rebound specs to match spring rates. i think?
Old Sep 10, 2006 | 09:34 PM
kelechi77's Avatar
kelechi77
I'd like to know. Anybody here running stock OEM shocks with Tein S techs or any other lowering springs with stock shocks?
Old Sep 10, 2006 | 09:45 PM
norapat01's Avatar
norapat01
didn't it said design to use with OEM shocks?
Old Sep 11, 2006 | 01:53 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Yep... still going strong at 8k miles
Old Sep 11, 2006 | 06:50 AM
z-u-later's Avatar
z-u-later
Installed Tein S with mine and no problems with my stock shocks. I did quite a bit of research on the springs and there were two primary reasons I went with Tein S: (1) I did not have to replace my OEM shocks, and (2) I did not have to mess with alignments (over 1" drop requires you to do so). PLUS, I picked up my used Tein S for $75!
Old Sep 11, 2006 | 02:50 PM
kelechi77's Avatar
kelechi77
Cool, I'm feeling better about the tein S already. Just have to install them when they arrived. Won a set off of ebay for $80.00 shipped. I just hope the seller comes through.
Old Sep 17, 2006 | 01:29 PM
zzz350's Avatar
zzz350
According to the Tein website, Tein S drop the car over 1", I thought you needed a camber kit if the car is dropped over an inch, any comments.
Old Sep 21, 2006 | 09:43 AM
Old School's Avatar
Old School
Shift_Boost
Anytime you mess with suspension, like changing the springs or changing the shocks, you should re-align your car. Dropping it over an inch has nothing to do with it. If you drop your car at all, depending on how much and if you don't want to eat up tires, you should get a camber correction kit. Just FYI
Old Sep 22, 2006 | 02:26 AM
Mathys's Avatar
Mathys
But if you stick with lowering 1" max, it's more likely that the camber/toe/.... can be alligned to stock specifications. No real need than for a camber correction kit if it's all within spec again.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
