One more BBK ? 13 vs 14 ?
Old Nov 10, 2006 | 11:18 AM
Drift_corners's Avatar
Drift_corners
Default One more BBK ? 13 vs 14 ?
How much more effective are the willwood 14 inch kit over the 13, is it worth the $
Old Nov 10, 2006 | 01:43 PM
dklau33's Avatar
dklau33
Depends on what you are doing? Are you talking about in terms of street driving only? Tracking?
Old Nov 10, 2006 | 01:49 PM
Drift_corners
street driving, but assume track speeds, i raced cart my whole life, i just cant allways afford the track but eventualy yeah track alot. facotr price in 14 inch is 1900 13 inch is 1300 both 6 piston
Old Nov 10, 2006 | 01:57 PM
THE TECH's Avatar
THE TECH
Brakes are only as good as the tires that are on the wheels.
Old Nov 10, 2006 | 04:01 PM
dklau33's Avatar
dklau33
The only advantage of the 14" rotors is that they have more mass to absorb more heat so that you would be less likely to fade. Read this article where they test stock Z brakes, Z Brembos, 13" Stoptech, and 14" Stoptech.
http://www.zeckhausen.com/Testing_Brakes.htm
You can see that the stopping distances between the 13" and 14" were marginal. But the front temps were noticably lower on the 14" kit.
Old Nov 12, 2006 | 10:52 AM
Drift_corners
yeah i know all that about heat, and brakes, ok i will be more clear, i am running 275 front 295 rear, on light wheels, i just need to know if i will find shortcomings with the 13, they are alot cheaper, will they still be alot better than say the factory brembo's, opinions, i know why 14 is better, i just dont know by how much, i drive fast, and i will track often in the future. ok hope that helps. I more am looking for something like this, but obviously your opinions.
"If you are tracking you car semi often, i think you will find that the 13 inch kit will be adiquite, it will operate better than the stock brembo's which many people find ok on the track, unless you pushing very hard you will be happy with the 13.
Old Nov 12, 2006 | 12:36 PM
350Z84's Avatar
350Z84
Awsome read dklau33, very informative. I'd like to see the same testing done on AP as well.
Old Nov 12, 2006 | 12:39 PM
Drift_corners
yeah it is i had seen that many times before
Old Nov 12, 2006 | 02:13 PM
dklau33's Avatar
dklau33
Originally Posted by Drift_corners
"If you are tracking you car semi often, i think you will find that the 13 inch kit will be adiquite, it will operate better than the stock brembo's which many people find ok on the track, unless you pushing very hard you will be happy with the 13."
I think you hit it right on the head. The 13" kit will suit most trackers just fine for a very long time. Go with the 14" right off the bat if you feel that you may need them in the future as your skills progress or if you just want peace of mind. Just remember the 14" requires 18" wheels which makes tires more costly, especially when you step into R comp rubber.
Old Nov 12, 2006 | 02:14 PM
Drift_corners
yeah i want to be running 295's in te back which they dont have in 17
seagrasser
Oct 11, 2015 03:27 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
