Brakes: r1concepts
Old Jun 19, 2008 | 10:43 PM
  #121
shinkuu's Avatar
shinkuu
ive been using centric rotors since i found out thats what stoptech uses.
i laugh at all my friends who pay 200-400 for rotors for any car. i get a set almost as cheap as turning used rotors.
Old Jun 22, 2008 | 08:19 AM
  #122
Originally Posted by OnADimePBS
Instead of having to wipe off the excess paint you can let the pads burn it off during bed-in. That way it'll be coated in only the areas that are not touched.
Usually a semi-flat looks nice. It's purely cosmetic and nothing will happen to performance. It might have been said before, but it's not just R1concepts rotors that rust as it's natural and happen to all iron rotors sooner or later. Hope this helps those who've had this problem in the past.
Alex
The pad will not touch the painted area. I was careful cutting and overlaying a heavy paper template.
The color is semi-flat black engine enamel similar to the OEM rotor.
Old Jun 22, 2008 | 11:49 AM
  #123
OnADimePBS's Avatar
OnADimePBS
Sounds good man, what I was saying is that you wouldn't even need to use the heavy paper template. You can just paint the whole rotor and let the pads burnt it off during bed-in. Either way, she'll last and look good
Old Jun 26, 2008 | 10:08 AM
  #124
Master Shake's Avatar
Master Shake
So did anyone with an OEM Brembo setup try these R1's (for Brembo) and have 10K miles or more? What's your impressions? Same as those without the Brembo package? What pads did you go with?
Old Jun 26, 2008 | 10:32 AM
  #125
B5I8's Avatar
B5I8
I just ordered the R1 Premium Discs for my 05 Z w/Brembo's. I should get them this Tuesday according to them. I'm also putting some StopTech SS brake lines, PosiQuiest pads, Project Mu Inner Shoes, and some Motul RBF600. I'll be sure to post my impressions once I get them done.
Old Jun 26, 2008 | 10:34 AM
  #126
Nexx's Avatar
Nexx
badass, i was thinking about doing this as well. let us know how it goes.
Old Jun 27, 2008 | 08:01 AM
  #127
Gilley's Avatar
Gilley
I have the R1 rotors with my Brembos. They work and fit great. I'm not overjoyed with the PosiQuiet pads though. They lack good initial bite, but they are low dust and are quiet.
Old Jun 29, 2008 | 11:20 AM
  #128
Ztalker's Avatar
Ztalker
i've had RI concept rotors all around for over a year using green stuff pads. These 170$ rotors are holding up just fine, better than the stock ones for sure.
Old Jul 3, 2008 | 04:57 PM
  #129
B5I8's Avatar
B5I8
I just got my car back today from Rob. My first impression of my new brake setup is pretty good. The pedal feels a lot stiffer with the SS lines, the rotors look dead sexy with stock Brembo's, and the Posi Quiets are a bit soft but they seem like a great daily driving pad. The Project MU inner shoes work as they should, they keep my car stopped in one place. The feel of the e-brake when you yank on it feels much better but that's also because they adjusted it. Overall I'm satisified on day 1 with these new brakes. One more thing, the Posi Quiet's definitely live up to their name, there's no brake noise coming from them whatsoever.
Old Jun 14, 2009 | 11:47 AM
  #130
Default 20,000 mile critique
Pads are several mm thick. Rotor wear is unnoticeable. Brakes are quiet as a mouse. Pads are virtually dust free.
See you in another 10,000 miles.
Old Jun 18, 2009 | 11:34 PM
  #131
350ZTheStandard's Avatar
350ZTheStandard
GUess I should look at mine over the weekend also as I will being doing a plenum & high flow cat install over the weekend. I spose my brakes are almost shot because I am hearing a small scraping sounds.
Old Jun 19, 2009 | 06:44 AM
  #132
GeauxLadyZ's Avatar
GeauxLadyZ
+1 on the R1... i love mine and they look great as well. Why go Stoptech when you can get the same exact thing but cheaper.
Old Jun 19, 2009 | 11:30 PM
  #133
350ZTheStandard
Stoptech are Centric prods, not nec. unless you are a fancy name brand *****. R1 is also made by Centric.
Old Nov 28, 2009 | 12:31 PM
  #134
Thumbs up 25,000 mile critique
Traded the 350Z for a 370Z but:
Pads are several mm thick. Rotor wear is unnoticeable. Brakes are quiet as a mouse. Pads are virtually dust free. Smartest $200 I ever spent.
Old Jan 15, 2010 | 08:25 PM
  #135
Ztalker's Avatar
Ztalker
R1 concept drilled/slotted rotors are holding up just fine....a big giant thumbs up.
Old Jan 15, 2010 | 09:07 PM
  #136
drivessidewayz's Avatar
drivessidewayz
Zombie thread ftw, lol.
I love my drilled and slotted R1 rotors; GREAT customer service. I called them two months after I got mine to complain about the rusting around the inside of the rotors and they sent me out a new set of rotors coated entirely with Zinc or whatever it is. Unlike paint it doesn't damage the pads when you burn it off.
I put them on immediately and spend the next hour burning off all the crap under the pads. I have to admit that watching and smelling my brakes smoke as I drove I found rather entertaining for some reason.
Old Jan 21, 2010 | 05:00 PM
  #137
misterniceguy's Avatar
misterniceguy
Daaaaaamn, looking through this thread, I remember seeing some of these same guys saying they would never put ebay crap on their sweet rides! lol You know who you are.
Old Feb 8, 2013 | 10:04 AM
  #138
Jbakes727's Avatar
Jbakes727
http://www.r1concepts.com/p-168433-p...rake-pads.aspx
Can anybody clarify on these pads? Like do they have very minimal dust, little to no noise, and do they brake better than OEM?
I have a 04 enthusiast std brakes.
http://www.r1concepts.com/c-121-brake-pads.aspx
These are basically all my choices. I'm trying to order the rotors and pads on the same site so its cheaper. Does anyone have any experience with any of these pads? Also which ones match best for the stuff I'm looking for (no noise,no dust, better performance than OEM) at a good price?
Old Feb 8, 2013 | 12:23 PM
  #139
ericjackson's Avatar
ericjackson
Old Feb 8, 2013 | 12:30 PM
  #140
Jbakes727's Avatar
Jbakes727
Appreciate the help, now I know what to get. ^^
seagrasser
Oct 11, 2015 03:27 PM
Varaxious
Jul 30, 2007 03:26 AM
MySunset350Z
Dec 3, 2003 02:30 PM
