alignment with wrong car specs?? advice please!
Old Jan 10, 2007 | 11:32 PM
Cloud's Avatar
Cloud
Default alignment with wrong car specs?? advice please!
I drive a G35C 6MT (OEM 19" rims)
I had my alignment done at big o tire and they used the factory settings for the 350z with 18" wheels.
I was in a hurry so I dind't look at the printout until I got home(2 hours away)
here's the speccs
LF(left front) -> RF -> LR - RR
camber -1.7 -2.5 -1.9 -2.0
caster 7.8 8.0 0.04 0.04
toe 0.03 0.05
SAI 6.1 6.0
included angle 4.5 3.5
don't look good to me.. why do the camber of the front left and right side differ so much. even if they were out of camber they should technically be the same??
Cloud's Avatar
Cloud
also does anyone know the max drop u can do to a 350z/g35 without having to buy a camber kit?
Old Jan 10, 2007 | 11:41 PM
Amiricanmade's Avatar
Amiricanmade
+1...Just Tire did my 19's on my Z with Tanabe springs to factory setting. What setting should we ask for?
Old Jan 11, 2007 | 03:31 AM
sam30540's Avatar
sam30540
I was told the front camber is not adjustable unless you buy adjustable control arms. The only adjustment the front has from the factory is the toe and i believe one other but i cant think of the name of it right now.
Old Jan 12, 2007 | 01:14 AM
Cloud's Avatar
Cloud
can anyone tell me why the left front camber differs so much from the right front camber if they're not adjustable at all? they should be the same if they're not adjustable right?
Old Jan 12, 2007 | 08:47 AM
Q45tech's Avatar
Q45tech
As you lower or raise the body height the front camber changes roughly 0.83 degrees per inch, so a side to side difference of 1/4" will create a camber difference of 0.2 degrees.
Was your weight in driverseat when the alignment was done? If not I would expect the driverside to be higher and thus have less camber.
Camber/body height varies with load [passengers, trunk, fuel amount] you must decide at what conditions you want the numbers to be.
Ideal front camber is negative 0.5-0.75 degrees........you BADLY need camber adjustment arms to correct!
Old Jan 24, 2007 | 09:47 PM
Cloud's Avatar
Cloud
So is -1.6 rear camber good enough not to cause excessive wear?
Old Jan 25, 2007 | 05:55 AM
Q45tech's Avatar
Q45tech
Tires are designed to function well with up to -0.75 degrees of static camber beyond that amount, the tread contact shape becomes more and more trapezoidal.
Remember oem alignment specs are actually the amount of MISALIGNMENT necessary to correct for rolling thrust forces which at highway speed push the tire away from the ideal..................so they misset the system to have minimal toe at 60mph going straight.
The oems measure alignment at speed and develop the amounts necessary STOPPED to correct the situation..............unfortunately brand new is not used rubber bushings so the correction numbers change as the miles accumulate and the bushings wear and become sloppy.
In a stop the front dives a few inches and thus acts the same as a not lowered non braking car. 0.5 static becomes -2.1 [-2 become -3.6].
Ideal braking requires the maximal squarish [not trapezoidal] contact patch so too much static negative camber can significantly increase braking distances.
On rear tires too much static negative camber can reduce acceleration friction and increase launch time and quarter mile because the rear drops [the converse of braking].
A tire with 1000 pounds on it inflated to 35 psi will have a 28.57 square inch contact patch regardless of camber. However excess camber will concentrate the forces on the inside were the area is smallest, raising the interface temperature and increasing scrub wear there!
Old Jan 25, 2007 | 07:08 AM
Gsedan35's Avatar
Gsedan35
Their is the answer that is geared towards at what point will any given FM platform variant be out of oem alignment spec when lowered (Z, G coupe and G sedan all have different oem alignment specs). In which case the answer is .8"
Their is the answer that is geared towards the question, so I'm a little out of spec, can I justify the expence to correct that end of the car? Only the owner can decide that one.
Their is the answer that is geared towards at what point will a given modified chassis not roll over and ruthlessly eat up the insides of the tires. I have found that by controlling roll, I work the tires better and have no complaints about inner tire wear at a 1.5" drop (equal to a coupe dropped 1").
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
Mattg350z
Oct 2, 2015 06:51 AM
Mw870
Sep 10, 2015 07:50 PM
Darkspy
Sep 7, 2015 09:09 PM
