Can I swap my my regular calipers with the Gold OEM Brembo?
Hi everyone,
I'm a newbie here and just joined the forum. Just got my 2003 350z, and I'm looking to make my first upgrade.
Can I swap my regular calipers with the gold brembo without changing the rotors? What about the caliper bolts, do i need to buy a new set, or can i use the original bolts to mount the brembo calipers?
Thanks in advance.
P.
Thanks in advance.
P.
I did This swap today.
you will need: everything that ZU L8R said, plus some good brake fluid.
Three of my rotors were stuck and I had to use a puller to get them off. To be on the safe side i would make sure you had one before starting the job.
I used tin snips to cut off the dust sheilds but a small grinder would have been nice.
Bleeding everything out is a good time.
I know this doesn't apply to the OP because he has an 03, but the rear caliper bolts on my 06 Base were the same length as the track model rear caliper bolts I bought. I used the new bolts anyway but it wasn't necessary. Although, the part numbers for the 2 sets of bolts were different in my Nissan dealer's computer.
Chris
Originally Posted by zand02max
Not gonna work, you need everything not just calipers!
Just paint them gold and put some Brembo stickers on them!
Anyway, that's beside the point! I would go for the entire package, but the guy selling it on ebay was only offering the calipers without the disc. The bid is up to 900 bucks now.
Thanks for the constructive input.
Regards,
P.
you coulds till get them.
just get a stoptech stage 2 kit which has lines pads and fliud and expensive (but cool) rotors
or a stoptech stage1 kit which has lines pads fluid but no rotors and buy some other rotors like EBC's
