This noise normal for a Z?
Old Apr 17, 2007 | 01:50 AM
Chad68's Avatar
Chad68
Default This noise normal for a Z?
I'm gonna post it here too since I'm not sure if it's actually brakes or what................
Kinda hard to explain but....
If you roll the backwards and apply the brakes, come to a stop, then roll forward and re-apply the brakes, is it normal to get a clunk sound from the rear wheels?
Also does it vise versa too.
It sounds like the brake pads shift a tiny bit then stop/clunk. Then when you go in the opposite direction and re-apply the brakes they shift the other way and clunk again.
It makes no other wierd noises when driving or stopping as long as you're going foreward and stopping like yer driving and drivng backwatds and stopping..
It also clunks the same as above if I lightly apply the parking brake and rock the car back and forth by hand. It does not make any noise simply moving back and forth, only when either brake is applied.
I could understand if it was the front to back play in the pads but the e-brake does it too, so I'm not sure if it's brakes or driveline now or what.
Think it's driveline lash?
Old Apr 17, 2007 | 06:40 AM
VO...'s Avatar
VO...
Administrator
https://my350z.com/forum/brakes-and-suspension/264792-is-this-noise-normal-well-for-a-z-anyway.html
Why did you start 2 threads about the same topic?
Old Apr 17, 2007 | 11:29 AM
DJMatrix1067's Avatar
DJMatrix1067
read your owners manual. specifically a section called ABS brakes.
it informs you that whenever you are rolling out at slow speed or transfer from forward to reverse, the ABS system performs a check the first time you hit the brakes after transferring. it is common to hear this clunking noise which you described.
Old Apr 17, 2007 | 11:32 AM
DJShan209's Avatar
DJShan209
+1 someone asked me that the other day actually...
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
