Replaced the brakes/rotors
Old May 17, 2007 | 11:55 PM
igetgreens's Avatar
igetgreens
Default Replaced the brakes/rotors
So after about 17k miles I had to replace my brakes, but when I took it to the Cerritos dealership they said I had to replace the rotors too when replacing brakes. I am just wondering, did i get gyped or is this true?
Old May 18, 2007 | 12:15 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
It depends. Does your car vibrate or shake when you brake? If so the rotors may be warped. If they are warped then many times they can be resurfaced if you have enough disc thickness left. Have the mechanic show you the mic. readings that he took. They should be in 32nds. You will want to see how close your rotors are to minimum safety specs. Sometimes you might be too close and cutting the rotors afterwards would put you over or too close to the minimum spec. You can always get a second opinion if you don't trust them.
Old May 19, 2007 | 04:21 PM
PJ 32's Avatar
PJ 32
Yes it's true, I just went through the same thing. I replaced my front rotors but they are still squeaking I am taking it back monday morning so they can fix the job.
Old May 19, 2007 | 09:12 PM
will350z's Avatar
will350z
Did you Bed-In your new setup after having the dealer install them?
Old May 21, 2007 | 08:57 AM
PJ 32's Avatar
PJ 32
I did..... but I took it the car in this morning and told them about the sqeaking and they upgraded me to ceramic pads for FREE. So I now I have new ceramic pads and no sqeaking.
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
