ABS .... help
Old May 20, 2007 | 01:26 PM
ameer_4_u's Avatar
ameer_4_u
Default ABS .... help
hi there
i have 2004 6MT , stock brembo brakes. stock suspension. i am facing problem with the ABS, once i get to a U-trun and i apply brakes and turn the steering right (while braking) i feel a sound and i vibration from the brakes. only on the right side. when i turn left that doesnt happen.
i took the car to the dealers in Cal. and they checked with the Computer and it showed that all the sensors are fine. the guy there told me that this is normal.. but i never felt it before.
any ideas guys...
EDIT: small corerction LEFT NOT RIGHT
Old May 20, 2007 | 05:26 PM
ameer_4_u's Avatar
ameer_4_u
help help .......
Old May 20, 2007 | 06:37 PM
DavesZ#3's Avatar
DavesZ#3
I guess I'm confused because I've never heard of a right-handed U-turn.
What tires do you have on the car? Size and brand?
Does it happen all the time or just at higher speeds?
Old May 20, 2007 | 07:23 PM
nightcrawler_8's Avatar
nightcrawler_8
could it be the sensor.. i guess so.. cause u mentioned that only in the left side.. so for sure something is wrong
Old May 20, 2007 | 07:28 PM
ameer_4_u's Avatar
ameer_4_u
sorry by mistake.. its the left hand side.
and no . even in slow speed the sound still there with vibration on the brake pedal...
nightcrawler_8: the nissan dealers checked the sensors and they working fine. no errors at all.
Old May 21, 2007 | 03:44 AM
DavesZ#3's Avatar
DavesZ#3
If it was at moderate speeds, I would guess it was VDC kicking in rather than just an ABS problem. You can test that theory by turning off VDC next time(s) you make a U-turn and see if it still occurs.
Old May 21, 2007 | 11:48 AM
ameer_4_u's Avatar
ameer_4_u
still same.. even when VDC is OFF or ON... what would be the problem?
any ideas ?
Old May 21, 2007 | 01:51 PM
spacemn_spiff's Avatar
spacemn_spiff
Unless you live in Britain or former British colonies.
Old May 21, 2007 | 02:41 PM
DavesZ#3's Avatar
DavesZ#3
any ideas ?
In that case, it probably is the ABS.
What brand of tires do you have on the car?
What sizes?
Was the dealer able to reporduce the problem or did they just hook it to the machine and magically declare that all was okay?
Old May 21, 2007 | 03:18 PM
ameer_4_u's Avatar
ameer_4_u
Yokohama
What sizes?
rear 265/35/18 front 235/35/18
thats exactly what happened.. they hooked the ECU console and they did ABS check and it showed that all sensors OK.
so
Old May 21, 2007 | 03:45 PM
DavesZ#3's Avatar
DavesZ#3
It could be an intermittant problem with one of the sensors, especially if it only occurs when driving it. They can test it on the machine all day long and not get an error. If the tech doesn't go out and drive the car and actually see/hear/feel the problem, he's not going to do much digging.
Another remotely possible problem might be in the tires sizes you are using. The stock tires are 26" diameter on the front, 26.7" on the rear. Your tires are only 24.5" and 25.3" diameter - significantly "shorter" than the OEM tires. I don't see how that could be causing the problem though.
Have you ever bled the brakes or replace the brake fluid?
What about brake pads? Ever replaced them or do they have a lot of pad left?
Old May 21, 2007 | 09:41 PM
ameer_4_u's Avatar
ameer_4_u
he did... and he was a bit shocked of the results.
all done and checked. everything seems ok in that.
changed them 1 month back and had 5K miles on them
man appreciate your help at least you trying to help me.
Old May 22, 2007 | 03:44 AM
DavesZ#3's Avatar
DavesZ#3
I'm shocked that the tech took the car for a drive, recognized the problem, then essentially didn't fix it because the test computer says it's alright.
At this point, I'm stumped.
Old May 23, 2007 | 05:11 PM
nightcrawler_8
thats really wiered .. they should at least check whats wrong.. maybe some wires are gone.
Old May 26, 2007 | 01:42 PM
Q45tech's Avatar
Q45tech
Not sure if we determined that the tires were newish oem in brand, in model, and in size...............are wheels oem [weight].
Old May 26, 2007 | 03:00 PM
ameer_4_u's Avatar
ameer_4_u
well the tires are not same brand not same size not same model.. .. but i was riunning on those tires from more than 8 months and this issue was not there.. i dont think its becuase of the tires...plus the sound starts when am in veyr looow speed and very gentel brake..
hope someone can help me out .. am totaly stuck in this
aarrgghh
May 1, 2022 11:04 AM
pslamp32
Feb 8, 2017 09:07 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
D-ray
Sep 17, 2015 07:27 PM
og_silver_350z
Dec 25, 2002 04:04 AM
