Squeak!
Old Jun 2, 2007 | 10:24 PM
kobalt's Avatar
kobalt
Default Squeak! UPDATE: FIXED !!
UPDATE: Squeak resolved, head down a few posts for solution.
Driving around slowly on local streets I hear a faint squeaking sound originating somewhere from the front end. While this sound is only audible during slow speed driving, it is quite annoying and a bit embarrassing as well. Thought it might be the end links but the sound cannot be reproduced turning the steering wheel from side to side. However I found I can reproduce the sound when I open the door, climb on the sill and rock the car hard. The squeak sound definitely originates from the front end and it does seem to (very) temporarily diminish after going through a car wash. Any ideas? Thank you in advance!
Old Jun 3, 2007 | 07:41 PM
kobalt's Avatar
kobalt
bump... anyone?
Old Jun 3, 2007 | 08:43 PM
rythex's Avatar
rythex
I dunno,shock going? :P
Old Jun 3, 2007 | 09:10 PM
terrasmak's Avatar
Rocking the wheel does nothing for endlinks. Put the car up on ramps and have someone rock it while you try find the noise.
Old Jun 4, 2007 | 06:08 AM
kobalt's Avatar
kobalt
I climbed on the door sill and rocked the entire car with my body weight. The squeak originated from the front wheel area but I could not pinpoint the wheel - rocked the car on both sides and it sounded the same. Had the struts needed replacing I should have heard more of a banging sound or at least some leaking. What else could this be?
Old Jun 4, 2007 | 08:32 AM
mistico's Avatar
mistico
Do you have after market sway bars?
Sway bar bushings are known for squeaking and require periodic greasing, specially the hotchkis ones.
Old Jun 4, 2007 | 09:00 AM
kobalt's Avatar
kobalt
I doubt my swaybar is aftermarket but I'll grease the bushings as I have no other leads at this time. Will report back with findings.
Old Jun 4, 2007 | 10:02 AM
bbs350z's Avatar
bbs350z
mine does the same. i often wonder what it is. please let me know, because it annoys the **** outta me
Old Jun 4, 2007 | 04:19 PM
kobalt's Avatar
kobalt
UPDATE: With the help of a friend I was able to pinpoint the sound much closer to the source - it originated from the passenger side and not the middle after all. The sound seems to be originating from the upper control arm bushings. Hard to tell, sound was bouncing around in the wheel well. I'll use a stethoscope to pinpoint when I get a chance. Once located I'll spray some silicone and if the noise does not leave off to the dealer it goes for bushing replacement...
Old Jun 13, 2007 | 06:00 AM
kobalt's Avatar
kobalt
Default dissapointing update
The car went in for service - The Nissan guys kept it for two days and said while they could replicate the squeak, two days worth of searching proved fruitless. They told me that the shocks were tested for leaks and that the suspension is tight all around (but who knows for sure). Is that a bunch of bs or what? A qualified Nissan mechanic could not find a squeak in two days worth of work?
Anyhow, I guess I'm on my own in trying to pinpoint this mouse squeak of mine. I'll see what I can find when I get home from work. In the meantime, any, absolutely any ideas would be appreciated. Once again, the noise seems to originate from the front passanger side wheel well. Could a loose bolt somewhere cause the suspension to squeak like a mouse? A shot mount or bushing would likely knock or groan, not squeak, correct? Gentlemen, please pitch in - I am getting desperate
Old Jun 13, 2007 | 07:10 AM
kobalt's Avatar
kobalt
Could inadequately lubed axle spline cause mouse squeaks / chirps?
Old Jun 13, 2007 | 08:32 AM
eez's Avatar
eez
are you on stock suspension and wheels?
Old Jun 13, 2007 | 08:53 AM
kobalt's Avatar
kobalt
Yes oem non-track 18s. May I add that I can replicate the sound by simply kicking the the tire: Kick ---> squeak!
Old Jun 14, 2007 | 03:39 AM
kobalt's Avatar
kobalt
UPDATE: Squeak resolved!
The Nissan tech had to be full of it, with some help from a friend I diagnosed the problem in about 15 minutes. Our strategy was simple: Jacked up the Z , grabbed a rubber mallet and started tapping on just about everything trying to replicate the noise. Turns out it was the passanger side engine mount. Sprayed the base of the mount with some penetrating oil - no more mouse squeaks. It's most intresting that the mount looked fine and was not loose. We'll see how long the lube job lasts, might have to replace the mount if the mouse squeaks come back.
Old Jun 14, 2007 | 03:57 PM
Phenom's Avatar
Phenom
Toasty
Good to hear you fixed it...my car is doing the exact same thing
How long ago did you first notice it sqeaking? I first noticed mine was squeaking yesterday, and I was hoping it would just go away on its own. If not I'll have to try what you did.
Old Jun 15, 2007 | 03:42 AM
kobalt's Avatar
kobalt
So far the noise has not returned. I noticed the squeak the night I got the car. You have good access to the mount through the oil drain cutout in the front undercarrige cover. Good luck!
RWDBajan
Sep 17, 2015 04:52 PM
Suffolk350z
Sep 13, 2015 02:43 PM
joust75
Jul 8, 2004 12:32 AM
03 Z for ME
Apr 10, 2004 08:23 PM
richhoward
Mar 24, 2004 10:18 AM
