tanabe springs please help
Old Jul 27, 2007 | 10:13 AM
QM888's Avatar
QM888
Default tanabe springs please help
I dont know much about this brand
anyone had experiences w/ on your car.
differences between NF210 & GF210 OR EIBACH PROKIT?? PLEASE HELP
Old Jul 27, 2007 | 11:28 AM
timmays350's Avatar
timmays350
tanabe is great stuff, and affordable. The GF210's are great I have them on my car, and there are a lot of other guys on here that do to. A little stiffer than stock, but the perfect drop without having to get other supporting suspension mods like adjustable upper control arms and what not.
Old Jul 27, 2007 | 11:36 AM
ofl0926's Avatar
ofl0926
i have the GF210 springs and love the ride.
Old Jul 27, 2007 | 09:11 PM
Gsedan35's Avatar
Gsedan35
Could you post a scan of your after GF210 install alignment results?
Old Jul 27, 2007 | 09:29 PM
Gsedan35's Avatar
Gsedan35
Here's how they differ spec wise.
Your oem spring rate baseline for a 03/04 car is 314/342
Your oem spring rate baseline for a 04.5/07 car is 314/427
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” higher
Spring rates in LBS 314/353
Eibach 350Z progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
I'm not a fan of a lot of aftermarket spring choices marketed for the Z, but if I to pick from your list I'd go with the pro-kits because of their higher peak spring rates vs the others, especially vs the NF210. Reason why is to hopefully keep the suspension off the bump stops as much as possible. This matters since they are rather unforgiving and cannot be trimmed. (Though 04.5+ rear shocks do have a soft foam insert that was part of the revised suspension change that can be trimmed).
Old Jul 28, 2007 | 03:33 AM
zzz350's Avatar
zzz350
I have nfs and they have been great. Nice drop, easy to install, haven't hit the bump stops once. However, I don't track my Z, just drive it on the roads. The ride is only slightly stiffer than stock (which is exactly what I wanted). Oh yeah and i am riding on 18's and the gap is perfect now.
Old Jul 28, 2007 | 06:16 AM
Gsedan35's Avatar
Gsedan35
Cinch a zip tie tight on every shock piston shaft and drive around for a few days then look at where the zip ties get pushed to, then you'll know wheather or not your hitting the bump stops, that way you rule out missing not being able to sense what's going on with the suspension. I ran Tokico springs which have the same 1" drop which have more spring stiffness and that setup was frequently into the bump stops. And I was running modified aftermarket bumpstops that were about 1" shorter then the oem units.
Old Jul 28, 2007 | 06:20 AM
RanFerr_350z's Avatar
RanFerr_350z
Old Jul 28, 2007 | 08:20 AM
metal_gear350's Avatar
metal_gear350
i got the gf210 and love them. Very comfortable and handles very well too.
Old Jul 28, 2007 | 10:35 AM
hkman78's Avatar
hkman78
I got the GF210 also. I have no complaint so far!!
Old Jul 28, 2007 | 11:24 AM
Ruthless18x's Avatar
Ruthless18x
Tanabe is a good brand, great jdm quality.
Old Jul 28, 2007 | 11:33 AM
2TH PWR's Avatar
2TH PWR
Tanabe!
michaeljr6's Avatar
michaeljr6
go over to 350zmotoring.........they sure have lots of Tanabe info over there lol
michaeljr6's Avatar
michaeljr6
Originally Posted by 2TH PWR
Tanabe!
here's a tanabe member lol
Old Jul 28, 2007 | 11:38 AM
Smawg350's Avatar
Smawg350
Tanabe!!!
Old Jul 28, 2007 | 11:40 AM
michaeljr6's Avatar
michaeljr6
http://www.350zmotoring.com/forums/s...134#post695134
Old Jul 28, 2007 | 11:46 AM
BaTMan_4's Avatar
BaTMan_4
I got some NF's....great stuff
Old Jul 28, 2007 | 11:56 AM
2TH PWR's Avatar
2TH PWR
michaeljr6, why you causing trouble?
Old Jul 28, 2007 | 01:02 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the Tanabe's do work great...nice drop, and behave very nicely with stock struts, and aftermarket
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
