evo calipers on a z
Old Sep 14, 2007 | 09:41 AM
bbs350z's Avatar
bbs350z
Default evo calipers on a z
i recently came across a friend who is getting rid of his factory evo brembos, and will give them to me for a cheap price. will these fit on a z? they probably require some alterations to fit, but can it be done?
Old Sep 14, 2007 | 09:42 AM
fast kiwi's Avatar
fast kiwi
this is a good question.. bump to find out???
Old Sep 14, 2007 | 09:43 AM
SuperBlack350z's Avatar
SuperBlack350z
it most likey won't. You will need custom brackets for the caliper to bolt up. Also, not sure if the size inbetween where it clamps the rotor fits. YOu don't want it to loose.
IMO, i dont' want anything custom when it comes to brakes.
Old Sep 14, 2007 | 09:57 AM
Triple8Sol's Avatar
Triple8Sol
You'd need some custom brackets fabricated.
Old Sep 14, 2007 | 11:10 AM
bbs350z's Avatar
bbs350z
is there a place that makes custom brackets?? seeing as evos and z's have the same bolt pattern, couldnt i use evo rotors??
factory evo rotors are:
"THE STOCK THICKNESS OF THE OEM ROTORS IS 32MM FRONT 22MM REAR.
ROTOR DIAMETER FRONT 320mm REAR 300mm
PISTON SIZE FRONT 40mm & 46mm / REAR 40mm
THE MEASUREMENT CENTER TO CENTER OF THE MOUNTING HOLES IS FRONT 6 ¼” REAR 5 ½” "
could we make this work??
Old Sep 14, 2007 | 11:23 AM
simonfencer's Avatar
simonfencer
I think some of the points made in this thread apply here too,
https://my350z.com/forum/brakes-and-suspension/301170-cadillac-cts-v-brembo-in-06-350z.html
unless the piston diameter of the evo calipers matches up to that of the Z, and it really is a matter of fabricating mounting adapters.
Old Sep 14, 2007 | 12:11 PM
bbs350z's Avatar
bbs350z
well i think motormouth just summed it up for me. looks like its a no go. ill just shell out the extra cah for a bbk
Originally Posted by Motormouth
^ about everything I was about to type.
if you transfer over the whole shebang and get a brake valve proportiner (found in race cars) you could get it to work.
but then you have to figure out if the pedal travel is the same, then modify your pedal assembly, etc, etc, etc, etc,
NOT A GOOD IDEA. I've thought about it as well. the upgrade kits are designed to be within ratio of the stock kit in terms of the piston size and f/r balance and to work with the master cylinder.
you will get terrible pedal feel, longer stopping distances, possible wheel lockup, etc.
Old Sep 17, 2007 | 06:32 PM
reallyredZ's Avatar
reallyredZ
I think it would throw off the balance of the car. You would probably end up spending more money converting the brakes than if you were to just buy an off the shelf big brake kit. I really wouldn't mess with the geometry of the braking system.
Old Oct 15, 2007 | 06:49 PM
PhiSig's Avatar
PhiSig
Wheel Whore
Yeah I had the same idea too when I saw a set of red evo brembos on ebay for cheap. Gosh they look so similar, minus the color that is
Old Oct 15, 2007 | 07:20 PM
redlude97's Avatar
redlude97
Looks don't mean anything, the piston sizing will be different because of the master cylinder setup, brake line length, weight distribution etc.
Old Oct 15, 2007 | 10:12 PM
bbs350z's Avatar
bbs350z
yea, i would have to get a new brake master cylinder, custom brackets, etc. itd end up coasting as much as a bbk. f' that.
Old Oct 16, 2007 | 11:39 AM
PhiSig's Avatar
PhiSig
Wheel Whore
I know this may sound like a stupid question, but is there no difference between the 350z brembo brake master cylinder and a non-brembo brake master cylinder?
Old Oct 16, 2007 | 11:58 AM
97supratt's Avatar
97supratt
I think the part numbers are different so the assumption is there is a difference.
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
seagrasser
Oct 11, 2015 03:27 PM
dcains
Sep 21, 2015 09:28 AM
