Dealer Installed New Brakes, Now Spongy Feeling!
Old Nov 17, 2007 | 01:56 PM
robcassell's Avatar
robcassell
Default Dealer Installed New Brakes, Now Spongy Feeling!
I just had new brakes installed on my '03 Track (Brembo), and now they feel all spongy and seem like they aren't good at all.
Do they need like a wear in time? I am concerned they did not install the Brembo ones, but the stock ones, or something worse, is that possible?
Old Nov 17, 2007 | 02:00 PM
SuperBlack350z's Avatar
SuperBlack350z
that's impossible to install the wrong brake pads.
The OEM brembo calipers are harder to bleed. You have to really get all of the air bubbles out. You need to take the car back because it's not a good thing or safe to have a spongy brake pedal feel. They need to rebleed the entire brake system.
Old Nov 17, 2007 | 02:55 PM
Grey Ghost's Avatar
Grey Ghost
and that includes the ABS pump which is a ***** when i did it on my friends FD rx-7... took me 2 hours
Old Nov 20, 2007 | 08:55 AM
robcassell's Avatar
robcassell
Default Follow-Up
Took car back to the dealership, they said the brake pads were not seated properly, will let you know if that helped!
Old Nov 20, 2007 | 09:38 AM
VO...'s Avatar
VO...
Administrator
* subscribing for follow up
VO(doesn't know how a pad can not be seated properly)
Old Nov 20, 2007 | 10:17 AM
DMK's Avatar
DMK
You should probably bed them in when you get your car back. It will help the pedal feel and you car will brake better after.
Old Nov 20, 2007 | 11:27 AM
robcassell's Avatar
robcassell
Got the car back they seem better. The dealer said the pads were not sitting right w/ the rotor, and that was causing the slow response when bedding the pedal. The invoice says they re-seated the pads.
Old Nov 20, 2007 | 01:01 PM
DVFlyer's Avatar
DVFlyer
Speed of White
I'd like to know how they re-seated them......
Perhaps a few hard stops?
Old Nov 20, 2007 | 01:07 PM
Lawn Dart's Avatar
Lawn Dart
Reseated them? Sounds like they're covering something up and trying to blow smoke up your @$$.
Old Nov 20, 2007 | 01:36 PM
z350boy's Avatar
z350boy
^^^^ Cigarette anyone????????
07ZEKE
Aug 23, 2021 09:15 PM
